Sticky Uniglide freehub
Hi all,
I have an 87 Peugeot road bike which has always had a sticky freehub. When I move the bike forward the pedals move too, sometimes the chain jumps, etc. It seemed to get a bit better with use. I didn't ride it for a few years and now it is quite bad (chain jumps quite a lot) wheel hub assembly.
I soaked the freehub in mineral spirits for ~24 hours, taking it out every once in a while to spin it around a few times. Sometimes it spins relatively freely, but it frequently 'catches' on something internally and spinning stops. If I press in on the inner cylinder of the freehub (sorry not familiar with this term) while attempting to spin I can free it up. It sounds/feels vaguely metal-on-metal -- not gummy like dried up grease. I hoped that applying lube might make it fully free but no, the 'catching' persists. I tried to flush it again, this time with WD-40, then mineral spirits, then lube, but nothing improved.
I haven't tried putting everything back together yet as I'm waiting on some grease in the mail. I feel like there is a small chance
I was just wondering if the problem I'm facing sounds familiar to anyone. E.g. is the hub body perhaps dying? If so, am I able to convert to re-use the 'inner' part of the tube and convert to a hyperglide system, or is the problem going to persist if I do that? Or maybe it's bad bearings inside the freehub?
Any feedback appreciated.
Quoted: 504 Post(s)
Liked 437 Times
Thanks for the response. And I suppose I'm asking for trouble if I try to take it apart and then put it back together? I'm not very mechanically knowledgeable and any problems that require creative solutions might be too much for me. My understanding is that putting the freehub back together properly isn't super straightforward and requires a bit of general know-how.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Will any hyperglide freehub be compatible with my uniglide? I am fairly certain it is not first generation. And then I can just slap any 7 speed cassette on?
I did a search of ebay and amazon and unless I'm missing something it seems that 7 speed hyperglide freehubs are pretty hard to come by. I see only two different ones on ebay from the same seller with no part number. Maybe I'm better off just taking apart and cleaning the one I have, assuming there is no major damage to the body itself.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,406 Times
It would be a good idea to post pics of the part you are describing into your gallery (you can't post 'em yet) to ensure that answers are factually correct.
1987 was a period when manufacturers were slowly moving from freewheels to freehubs.
I'm not personally familiar with Peugeot bikes of that model year but would not be surprised if your bike was equipped with a freewheel.
Which would be good for you as they are MUCH easier to replace as a unit.
Thanks for the response. I've just created an album with two pictures of the freehub/freewheel. I don't know how to link to it (I tried to "Share" but nothing happened) but hopefully you can see it in my profile. The dustcap says "Shimano 6D".
aka: Dr. Cannondale
Liked 3,406 Times
Well, that's definitely a Shimano 7 speed UG freehub.
I happen to have one of those in my parts stash and it's practically new.
Yours for the cost of postage, e-mail me at rccardr@cox.net since you can't PM yet.
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 185 Post(s)
Liked 206 Times
I have one from an Arabesque group that was like that and soaked it in a peanut butter jar for a couple of months shaking frequently and occasionally removing and spinning and it cleared up nicely. I then repeated the process in straight 30w oil for a shorter period.
Old example was not removable or it would be 7 speed now.
Hm I never thought of just leaving it in solvent for a while but maybe it's worth a shot. I had given up on solvent as it seemed like there was metal stuck inside but I could easily be wrong about that. I guess I have nothing to lose by trying it.
