Water stuck in tubular rim
Bikes: Cannondale Slate 105 and T2 tandem, 2008 Scott Addict R4, Raleigh SC drop bar tandem
Quoted: 22 Post(s)
I can hear it sloshing around in there. Seems to slowly be draining through the base tape so I think it will come out. The tire is well, well glued and as long as it stays that way, I will roll with it.
Any tips on getting it out? It won't come back out through the eyelets. I will turn the wheel a quarter turn every few hours to spread out the seepage and see what happens.
Quoted: 18378 Post(s)
Liked 4,512 Times
I would think it would evaporate out.
What kind of rim do you have? Fully socketed rim? The only escape hole might be the valve stem.
Personally, I'd probably just pull the tire to get it out.
Quoted: 22 Post(s)
I found that I could shake some water out of the spoke holes and after sitting overnight a few tablespoons of water has come out. I can still hear a little but am not that worried about it. I will hit each spoke nipple with some wd-40 and in a few day, put of drop of oil on each one as well.
Bikes: 90's Bianchi Premio, Raleigh-framed fixed gear, Trek 3500, Centurion hybrid, Dunelt 3-spd, Trek 800
Quoted: 2167 Post(s)
Quoted: 22 Post(s)
Rode through a crazy rainstorm last evening.
Quoted: 4806 Post(s)
Liked 3,932 Times
It goes in fast because once you are in a deep puddle, it is driven in by pressure. To getit out fast, you have to reverse the process. Put the wheel in a vacuum. Sorry, I don't have good ideas on how best to achieve that. Strap it on to the outside of a space station?
Ben
Ben
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Quoted: 22 Post(s)
Nope but I want to keep my nipples clean
Liked 2,568 Times
In that case, you should definitely skip the drop of oil on each one. All that will do is attract dirt. I only clean and add oil to mine when I need to true a wheel.
got a heat-gun? get one, make steam.. or at least speed the evaporation ..
Bikes: Lynskey Twisted Helix Di2 Ti, 1987 Orbea steel single speed/fixie, Orbea Avant M30, Trek Fuel EX9.8 29, Trek Madone 5 series, Specialized Epic Carbon Comp 29er, Trek 7.1F
Quoted: 12 Post(s)
Bury the wheel in uncooked rice.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
leave it in as balancing fluid
