Promax DC-310 disc brake manual
Quoted: 5234 Post(s)
Liked 3,609 Times
anyone have access to an old manual for the 310 model? the oldest I seem to be able to find on the internet is for #717
Liked 3,609 Times
what screw adjusts caliper proximity? (I think it's the big one in the middle of the bump-out, but on the inside near the wheel)
do I need to back it off before swapping pads or can I just push the piston? with a screw driver?
do I need to remove the assembly from the bike?
Generically, you have a screw on the inside, for the fixed pad , and its wear adjustment ..
Outside . moving pad , I just use the cable clamp on the actuating arm ..
although you do have that cable adjuster .. for a little adjustment of the outside pad.. (Avid BB5, etc. , same idea)
Quoted: 630 Post(s)
Liked 369 Times
2. Release all tension from the cable and then back off using the adjustment screw. It is not a hydraulic brake so you don't need to push the pistons in...and if you had to, you definitely would not use a screwdriver.
3. Depends on how fine your motor skills are but probably not.
Liked 3,609 Times
thanks guys
Liked 3,609 Times
for my future reference when I come back to this thread to do it again
the clips come out the top with thin pliers & the pads come out the bottom, one at a time
putting them back in, again one at a time. takes a little while to get one in, in such a way that there's room for the other to slide in. best to do it sitting down rather than hunched over. good lighting helps
used a small thin screwdriver to help tuck one pad in on one side, so I could get the other in
visually, they look pretty good compared to the new ones. the front pads measure 2mm or better. some guide said replace them at 1.5mm or thinner, so I put them back in
I did mark them so I would know which was inside & outside, but at this point they seem fairly equal
front
one side
other side
rear: did not bother taking them out, cuz they look fine too. maybe I'll pull them when I mount up the summer tires
put the wheels back on & everything spins & stops perfectly. like I said originally, wasn't having any issues. but feel good about checking them so closely. hopefully, I won't lose the new pads before I need them!
front
one side
other side
Liked 3,609 Times
