campy, ferrulles inside of shifter??
I was asking because somebody asked me that question, time ago a friend with a store saw a campagnolo veloce shifters with ferulles in both derailleurs cables, I have never put ferrulles at the lever level, I have no idea if somebody is doing it.
Campagnolo instruction clearly states that ferrules should be used on the Ergopower end of the cable housing. If one is installing new Campagnolo cables, the end of the housing with the pre-crimped ferrule should go into the Ergopower and the other open end should be trimmed and ferruled (presumably onto the cable stop).
WAG: The Campagnolo cables that come with the pre-crimped ferrules are also pre-lubricated with grease at the pre-crimped end, as the instructions alluded to. Therefore, it appears that putting the pre-crimped end into the Ergopower serves only to ensure that the grease is pushed in the correct direction, when the inner cable is installed into the Ergopower and threaded through the rest of the cable housing. So, it further appears that the reference to the pre-crimped ferrule is a red herring. The important bit is that there is a ferrule in the Ergopower.
¡Senor Member!
Brake and shifter ferrules are cheap and I use them unless it's physically impossible to on every component...
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
I just checked on a new campy cable set and it comes with 5 ferrules
but when I look at the instruction for setting up brake shifters, it doesn't show the ferrules at the brake shifters. I use the ferrules at the housing stops on the frame
Quoted: 2604 Post(s)
Liked 1,933 Times
I've done it both ways. Both ways worked. Of course, you need a really thin ferrule to fit inside the brifter -- those plastic ones work well. I think this is why Campy housing is 4.5 mm vs. 5 mm.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
11 speed requries NO such ferrules in the shifter body for shift housing, or brake housing.
cab horn
Quoted: 42 Post(s)
Liked 26 Times
Well, I don't know then!
Not the Slowest
Bicycle Mechanics
0
03-31-16 01:25 PM
Tequila Joe
Bicycle Mechanics
11
02-28-16 01:13 AM
Harlan
Classic & Vintage
25
03-08-12 05:54 AM
