Adaptive Cycling: Handcycles, Amputee Adaptation, Visual Impairment, and Other Needs Have a need for adaptive equipment to ride to compensate for a disability or loss of limb or function? This area is for discussion among those of us in the cycling world that are coming back from traumatic circumstances and tell the world, "No, you are not going to beat me down!"
Bike help for a handicapped neighbor
Old 07-26-21, 01:47 PM
Senior Ryder 00
Old bikes, Older guy
Senior Ryder 00's Avatar
Location: Fiscal Conservative on the Lefty Coast - Oregon
Bikes: A few modern, Several vintage, All ridden when weather allows.
Quoted: 251 Post(s)
Liked 167 Times in 115 Posts
Hi folks,
I’d appreciate some guidance on building a bike for a neighbor who was born without forearms. His fingers came out at the elbow on both arms. Thru constructive surgery he has short forearms, but his elbows don’t function & are set at ~100 degrees. He has no thumbs, so gripping brake levers, handlebars, etc. could be an issue. Considering all that he’s been through​​​​​, he has a great attitude.
He has been asking me about a bike for a few years now, but I took it as just being friendly. Since the Covid-19 restrictions have been relaxed, he has gotten more serious. Plus, his doctor told him he needs more exercise.
The other issues are that he just turned 70 & is only 4’10” tall. He’s OK with a trike as long as it is not one of “one of those low slung” things. I was thinking about a multi speed coaster brake set up with laid back riser bars.
More suggestions?
Thanks & regards,
Van
Remember: Real bikes have pedals.
...and never put a yellow tail on a Red, White and Blue kite!
Senior Ryder 00 is online now
Old 07-26-21, 02:23 PM
CliffordK
CliffordK's Avatar
Quoted: 18376 Post(s)
Liked 4,511 Times in 3,353 Posts
Do you know if he has ever learned to ride a 2 wheel bicycle?
I like the "low slung trikes"
The "Delta" trikes are a bit more of a mid height and might be worth considering.
How flat is your riding area? Parks?
I think you're on the right path with coaster brakes. Many of the trikes are set up with an idler pulley, and could easily be converted to a small IGH with minimum expense, but it might not hurt to just try out a single speed trike and see if he likes it.
4'10 is a bit short, depending on the actual body proportions. Large kid trikes seem to be rare, but there are a few adult trikes with smaller wheels and a bit smaller size.
CliffordK is offline
Old 07-27-21, 09:28 PM
Senior Ryder 00
Quoted: 251 Post(s)
More info
CliffordK
Hi,
My neighbor says he got his first bike, a Schwinn Stingray, when he was 7 1/2 and rode it until he was ~12. Then, he moved up to a 24” wheeled cruiser that had been his older sister’s and rode that until he was 14. He’s only ridden sporadically since then.
We’re in Salem and have lots of bike paths/lanes, but there are some hilly areas. Fortunately, all of the necessities like groceries, fast food & drug stores are within a few blocks and the terrain is fairly flat.
Now, all I have to do is get the co-op manager’s support & buy in on this.
Thanks for the feedback.
Regards,
Van
Old 08-06-21, 12:31 AM
force3T
There are quad grips that he could potentially use that handcyclists use so you might consider starting there. You might consider looking at the basic setup for a handcycle because there are quads who are able to shift, I've ridden with them only raced so don't really know anything other than it is possible, but your would have to reconfigure for standard bike handlebars.
force3T is offline
Old 08-06-21, 03:38 AM
CliffordK
CliffordK's Avatar
Ahh... I'm not sure if I noticed you were in Salem.
The Eugene co-op manager is somewhat unique. Jan VanderTuin. He has Parkinson's disease, and rides a custom Delta trike. I think he has interests in accessibility. I thought I may have seen the co-op open a few days ago, but Google lists it as "temporarily closed", so I don't know. Perhaps closed once again. I don't know if they still do any fabrication. If they do, it may be quite limited.
Let me know if there is anything you need help with.
It is at least good that your neighbor has ridden some. He might be able to ride a regular bike, but I'd probably still put him on a trike.
