3D Printer Stuff
Quoted: 966 Post(s)
Liked 1,629 Times
3D Printer Stuff
Is there, or can ya all make an area for us to post and exchange information dealing with bicycle 3D printer stuff?
I have a couple of .stl files I would like to post for use but there really is not a place... Yet...
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
Why not post the files somewhere that specializes in that such a thingiverse (or maybe somewhere else with better license terms) and then mention them here in the thread you just created, or in threads relevant to the particular use.
Also keep in mind that parametric designs (OpenSCAD, etc) are a lot more universally useful that .stl files, since they can be customized in details like changing that light mount to a different seatpost size or angle or whatever.
And FDM 3D printed stuff is going to be mostly light / phone / GPS mounts rather than functionally mechanical - maybe water bottle cage adapters at the outside.
Likes For UniChris:
Liked 2,971 Times
Another option might be to create a thread. Then members post there profile link with a brief description of what the files are to the associated "Visitor Message" area. The "Visitor Message" area would contain the description & print files.
additional option to include, is a link in your sig to the aforementioned thread that your supporting.
-Oh Hey!
-Oh Hey!
Quoted: 966 Post(s)
Liked 1,629 Times
Cheap 3D printers are going for about 200 USD and I expect that soon we could see table top CNC machines that could work aluminum and other soft metals for a little more.
Quoted: 930 Post(s)
Liked 393 Times
But if you go to Thingiverse it can be tedious to find Bicycle related objects. You may have to wade through pages of useless objects that have nothing to do with real bicycles. I just would like to see an area where we could post those printable items that are useful and proven.
First, cutting force is very much a thing - designing a machine that can resist that is drastically more complex than designing one that can move what's basically a miniature hot glue gun around
The other problem is the geometry of machining: many useful parts would require a cutter to come in from multiple angles. That requires either pricey 5 or 6 axis setups, or having a whole plan of re-fixturing the workpiece in a different angle partway through.
There's a reason desktop plastic fabrication has taken off, and apart from some very constrained applications like engraving, key cutting, programmed drilling, or (just barely) milling simple circuit boards, desktop machining is mostly a curiosity.
Likes For UniChris:
Quoted: 6193 Post(s)
Liked 4,809 Times
There has been a 3D printed thread in the gadgets and dodads forum for quite a long time.
And it gets regular updates. Is that not good 'nuff? You could start your own, I'd think that forum the obvious place though.
Likes For Iride01:
Liked 2,971 Times
That's why I'm suggesting you post links in the thread here, to the files there or on some other 3d printing repository site.
Indeed, though they can be finicky
Nope. For two main reasons:
-Oh Hey!
-Oh Hey!
Quoted: 966 Post(s)
Liked 1,629 Times
