Giant TCR Pro Disk 1 - which accessories?
Hi all!
New to forum and getting back into cycling. (More of a runner, but dealing with injury. Used to cycle back in my early 20s, now 37.)
Just bought the above bike and awaiting delivery. Few questions re. accessories…
1) Do people still use cycling computers? Ie. “dashboard” mounted. Or is it mostly watches these days?
2) This bike comes with a power output monitor. Will it be compatible with only specific cycling computers/watches? I’ll likely upgrade my Garmin235 to something more cycling appropriate, but still Garmin.
3) Will it just be best to stick to Giant accessories or will most brands work?
4) What, if anything, would you suggest carrying in way of a repair kit? I understand tubeless tyres are less likely to puncture, but not infallible. What are the essentials?
Thanks in advance!
Thanks in advance!
Quoted: 20810 Post(s)
Liked 9,456 Times
Yes, people use computers. If you're comfortable with, and already within the Garmin ecosystem, I'd look at an Edge 530 or the 830, which is very similar to the 530 but adds a touchscreen.
Your power meter likely broadcasts in both ANT+ and BT - it'll be compatible with the above computers.
My tubeless flat kit is the same as my tubed flat kit, I just don't have to use it nearly as often: spare tube, a couple patches, a pump (some prefer CO2), and tire lever. The only additions are a few plugs ("bacon strips" in my case) and a tool to insert them.
I can't think of any reasons to stick within Giant accessories except for anything that'll go over the steerer tube, like a new stem or possibly a computer mount; Giant uses an oversized steerer that's larger than the industry standard.
Quoted: 6196 Post(s)
Liked 4,811 Times
Let your experiences cycling in the areas you want to ride tell you what you need.
Thanks! Great points, very informative.
Sage advice I think. Been thinking similarly, e.g. not rushing out to buy accessories. For example, going into summer here and don't suspect I'll need lights for a little while. Also probably won't be riding long enough to need hydration so will forego a bottle for the moment.
Quoted: 1820 Post(s)
Liked 1,696 Times
Likes For alcjphil:
Liked 4,811 Times
I drink not quite a liter every hour I ride.
Likes For Iride01:
