Quick links / powerlinks are a single use item?!
Quoted: 1461 Post(s)
Liked 1,486 Times
I've been running quick links (or SRAM power links) on my 11sp Shimano and SRAM chains for a few years. I like being able to quickly remove the chain for cleaning.
I was listening to Cyclingtips "Nerd Alert" podcast over the weekend and they were talking about chain waxing - and during that segment someone mentioned that you should not re-use the quick link after you've unlocked it. I was super confused by this, as I've unlocked and re-locked the quick links on my chains many times and never noticed an issue. I assumed it had something to do with chain waxing (which I've never done), but after reading more I'm now seeing that manufacturers say these are single-use items and once you've unlocked, you should remove and replace with a new one.
Does anyone know why? Have I just been super lucky that I've never had an issue with mine? I definitely do not want to risk breaking a chain while out riding and will start tossing these after one use, but I'm curious if this is common knowledge or if anyone has seen one break after re-using?
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
I use Shimano single-use quick-links for the lifetime of the chain with no issue. I open them up and re-close them twice a month. I still need the chain pliers to do so. If I had any hint that this created any real danger, I would not do it. I am very paranoid about falling.
Likes For Polaris OBark:
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Depends on manufacturer and model/speed.
https://www.kmcchain.us/Frequently-A...s_ep_43-1.html
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
I reuse all of them, it’s fairly easy to tell when they’re bad
Likes For Germany_chris:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
The story I've heard is that SRAM (or some other brand) grabs the patent for reusable quick-links whenever a new chain "speed" comes out. In order not to infringe on that patent, other brands must mark theirs as one-time-use only. Of course, in reality, people find that they can re-use quick links from many brands without dying. (Ever notice that this issue seems to follow the chains with the highest number of speeds?)
If I'm wrong, I expect Cunningham's Law to kick in...
RUSA #7498
Originally Posted by noglider
Likes For ThermionicScott:
Liked 1,486 Times
Liked 1,486 Times
Just for the sake of people who may be slower on the uptake than others... what exactly should one look for when determining if the link is bad or not?
I typically use a Park Tools Master Link Pliers (MLP 1.2) to remove and re-install. They don't need a lot of effort to unlock, but seems like enough that I've never worried (until now) that it might come undone while riding. They kind of "snap" back in pace on re-install.
I would worry if they didn't snap back in place or seemed really easy to unlock, but so far I've not encountered that. I've got 1500-2000 miles on one now that has been opened/closed at least a dozen times for cleaning.
Liked 3,443 Times
Wippermann Connex are advertised as multi-use quick-links that don't require tools.
I feel safer using Shimano, which requires a tool to get them apart (and in my experience) to get them back together.
Liked 3,443 Times
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,294 Times
Liked 2,568 Times
Does SRAM say that it's OK to re-use Powerlinks? The internet seems to vary on this answer. I no longer have the original packaging for the ones I bought (a few years ago), but I was going to order some new ones. If there is a brand that says they are OK to re-use, I'd prefer those. Replacing each time I clean my chain seems crazy and annoying and/or will result in me not removing my chain to clean it.
I agree that if I couldn't reuse that link, I'd have to do things differently. And I wouldn't be happy about it!
Quoted: 839 Post(s)
Liked 1,064 Times
I like to test these things out and have found with the "one time" links I have used, KMC, Connex, SRAM, that the pins and side plates will start to wear grooves before anything breaks so they get changed when the wear is visible. Never had one fail even after using on 3 chains and 12K plus miles with 20+ remove and replaces for the same link. Most failures I've heard of are from installation error where the sideplates weren't engaged properly with the pins.
Likes For Crankycrank:
Quoted: 303 Post(s)
Liked 136 Times
My experience is similar to those that R&R the chain periodically: though the makers of several quick links do
specify "1 use" in practice this means use on one chain until the chain wears out then discard chain and link
and don't worry about periodic chain removal
for cleaning or what. I have only had one quik link fail in the past 15 yrs and that was on a tandem.
Quoted: 569 Post(s)
Liked 588 Times
Single use or multi use they all use an interference fit to stay connected so I use the closing force to determine whether it goes in the trash. I get the link up and hold the wheel an if I can easily close it with my hand on the crack it is trashed, some as early a five uses.
Quoted: 2604 Post(s)
Liked 1,933 Times
Likes For pdlamb:
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
I use the Wippermann, prefer it to SRAM and KMC. Well designed, isn’t going to open in use.
Quoted: 1088 Post(s)
Liked 1,026 Times
I've always just assumed that this referred to the life of the chain, single use to the chain and don't use after the chain wears. I've yet to run into a link that hasn't worked just fine for the rest the chain life, and can't recall seeing a chain that snapped at the link, usually always somewhere else so I suspect it isn't that important an issue.
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
More speeds = thinner plates on the quick links.
I've never seen a single-use 8-speed quick link, while I've seen many single-use 10 and more speeds links. I have successfully re-used 10 speed quick links that were sold as single-use, but for regular re-use (like weekly chain cleaning and similar), I'm comfortable with up to 8-speed quick links, the rest I consider emergency re-use only, even if manufacturers say otherwise. Colour me conservative.
Having said that, I've seen quick links fail on other people's bikes, but it could have been from improper installation, a defect, or some other problem, but never had problems personally.
