Can I use toe clips without straps? Here's why....
I like having my feet attached to the pedals because they keep my feet in place on descents when I hit bumps at high speed so I won't get bounced off the bike, but lately I am getting tired of walking in clipless pedal shoes when off the bike and I need to amble around for a while. Even with the MTB shoes and MTB clipless pedals I still have to walk funny.
So I was wondering will using just toe clips (no straps) keep my feet in place on descents when I hit bumps at high speed so I won't get bounced off the pedals? I don't want straps, because that would be another encumbrance to fumble with. I just wanna get in and get out easy - stick my toes in and pedal away.
Does it work for you all? Can anyone recommend any types that might work better for my purposes than others? Bigger cage? Longer cage? Does it have to be a clip specifically designed for no strap use?
I don't care about efficiency of pedalling, pedalling in circles, or powering thru 360 degrees of the pedal stroke - just staying attached so I don't bounce off the bike. I mainly commute and fun rec rides.
Thanks for any help.
Quoted: 1217 Post(s)
Liked 187 Times
You can, several members here use clips without straps. There are even mini-clips available for sale that are designed to be used without straps.
See the second picture: https://www.parktool.com/blog/repair-...tem-and-cleats
Time for a change.
Liked 5 Times
There is a clip that is made of hard Plastic? and is called a half clip over here. The clip is pretty rigid and does not use straps and I find them preferable to clips and straps.
Spike Milligan
Spike Milligan
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
I use half clips on my city bike, no straps involved. I don't know how well they would work in a rough trail situation. I have used toe clips and straps on my mountain bike for years, I just kept the straps loose on the technical stuff for easy pull out.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Quoted: 19 Post(s)
Liked 7 Times
You can use loose straps, they need no cinching or fumbling, you just put your feet in and take your feet out.
Stiff leather straps are better than nylon and if you put a twist inside the pedal cage, the strap stays in place.
Bikes: Trek 1420 triple, Mercier Corvus, Globe 1 700, Surly Disc Trucker, GT Avalanche, GT Grade, GT Helion, Mercier Corvus, Motobacane Boris X7 Fat Bikes,
I use these https://www.jensonusa.com/!4enE3kQao6...medium=organic on the hybrid and the touring
By pushing the counter weight out and putting just enough weight in for neutral balance.
I also have an adapter plate with a clip type that fits on the Look clipless
something like this that fits on my old Look clipless pedals https://bicyclepedalclipsshop.blogspo...ess-pedal.html
They can even be a little snug, and be easy to pull out of. Nylon snaps stretch, and most of them come with cheap buckles that will allow the strap to loosen over the course of a ride anyway.
Quoted: 67 Post(s)
Liked 83 Times
I once ran about 6 miles in spd shoes, while pushing a bike so as not to DNF a mountain bike race. There is no reason to be walking funny in mountain bike shoes...
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Don't use toe clips without straps; use mini-clips as previously suggested.
Maybe you would be better off using power grips?
This works for me, too. You might also look at Power Grips, but I like toe clips with loose-ish straps.
They are Speedplay frogs (cleat is like an spd cleat). I can't use SPD. Only speedplays have enough toe-out rotation so they don't hurt.
I tried Power Grips. I didn't like them. Never felt I could get my foot in far enough.
Quoted: 70 Post(s)
Liked 15 Times
Also be aware of the fact that toe clips come in a variety of sizes. I use a variety of toe clips and that is my preference.
Aaron
Aaron
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
I have half clips, strapless clips, and a pair of toe clips with straps, by far my favorites are the strapless clips easy in and out, they hold my foot well and give me a lot more power transfer than without, yesterday I undid the straps on my one set of toe clips and rode my bike like that, definitely prefer ones made to be strapless.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Why not? The regular deep clips look like they will hold the foot over the top better than mini-clips. I would get the deep clips, whether mini or regular, so as to accomodate walking shoes. I am sure I will wind up getting and trying both regular and minis.
the fixie crowd has made a market for a double strap without the toe clip.
I don't do the adrenaline powered routes,
so my feet bouncing off the pedals at high speed just does not happen.
toe clips do position your foot consistently over the pedal axis.
but so does the contoured shape of Ergon pedals .. That is on my daily commuter.
Bikes: All Treks - fitness and road
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
I use these: https://www.nashbar.com/bikes/Product...60_-1___202530 - Shimano PDM324 Multi-Purpose Mountain Bike Pedals, and I really like them. I've got them on all my bicycles now.
I also use Lake Mountain Bike Shoes which allow me to walk normally. I've walked some distance in them quite comfortably.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Ergon pedals? Do they require special shoes?
How'd they hold the shoe?
there is friction tape like off skateboard decks,
in the center and the shape is concave.
https://www.ergon-bike.com/us/en/product/pc2
Got some MKS GR-9's and MKS deep clips...feet are snug as a bug in a rug, but I think I need the medium or small size clips....arrrrgggghhhh, and I used the sizing chart and the clips are still too long. Spindle too far behind ball of foot. Otherwise, I love the clips n straps.
OK, got the medium clips and seems really good now.
Thanks everyone for the info! I am so glad I can just get off the bike and walk now, but also stay safe by having feet held onto the pedals while riding by the clips. The clips keep the feet snugged down real well.
What's this lever do?
Bikes: 1987 Centurion Sport DLX | 1996 GT Vertigo
I'm using Christophe Specials without straps
I have the straps, but certain shoes I might be wearing get caught on the pedals which have lead to some sketchy dismounts...
My flat bottom Adidas shoes are fine, but my running shoes get caught when trying to remove my foot by pulling back. I have to twist them out to the side.
