The Infamous Dork Disc
Cantilever believer
Quoted: 534 Post(s)
Liked 1,832 Times
We always called 'em "pie plates". Still use them on some bikes.
Likes For RCMoeur:
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,993 Times
If you do bend your rear mech I think it's less likely to snag on a smooth bit of plastic than an unprotected spoke. Rear mech in spokes can have you walking home. I actually bought a plastic dork disc not long ago to fit on my hack bike because I tend to treat it careless, but I didn't check the hub flange diameter so it will be going on another bike that I've not started yet.
I think yes if it were to hit smooth plastic it is less likely to snag but I don't think generally it will hit much smooth plastic unless a disc wheel or something large and even then if it was able to bend to that level I have a feeling it would have just cracked the dang thing. maybe not but those things seem to be easy to snap off.
Front View
Back View
The largest rear sprocket is effectively a 28T - the four support arms for the integral "dork disk" replace 4 teeth, so it only has 24 actual teeth.
Edited to add: this is the only example I've ever seen; dunno if Shimano ever made a 6- or 7-speed version.. It's now awaiting a future build (which will be 6-speed; it takes standard Uniglide sprockets and spacers), which likely won't occur for several years in the future. The source purportedly had 2 of these, but the second turned out to be an actual Schwinn Approved 6-speed UG cassette w/o built in spoke protector on the last sprocket. I didn't really mind, as my NOS UG hub set is 6-speed.
Clever design, but likely added too much weight (2mm steel plate is fairly heavy) to catch on industry-wide. Plus, I'm also guessing either Shimano or Schwinn patented the design.
Likes For Hondo6:
Quoted: 94 Post(s)
Liked 151 Times
That’s a bizarre looking cassette with the built in spoke protector. I have never seen such a thing. I’m not sure if the 4 missing teeth on the largest cog are a great idea, which results in a such a large gap between the two teeth.
Quoted: 966 Post(s)
Liked 1,629 Times
Of further note is the damage that comes from a slipped chain to the inner hub. If the rider keeps pedaling even a few turns the chain can do allot of damage to the spoke necks. In this picture I am trying to show that a jammed chain has caused small damage and abrasions to the most critical part of the spoke, the bend at the neck. I am now going to have to replace most of the spokes on this wheel.
However, I don't see why the missing teeth would be a major problem, other than maybe making the sprocket wear out a bit faster (fewer teeth engaging per rotation). I understand 1/2" pitch chain works acceptably on skip-tooth (e.g., 1" pitch) chainrings. All one missing tooth does is create a short a skip-tooth segment in 4 places on the sprocket.
Last edited by Hondo6; 01-09-23 at 06:40 PM. Reason: Minor rewording, add missing punctuation mark.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
That stamped integrated version is cool. Can't imagine it goes well with shift ramps though.
Only scraping outies is why there are eight in my photo earlier. The innies were fine
Genesis 49:16-17
Genesis 49:16-17
Quoted: 5224 Post(s)
Liked 3,581 Times
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
I assert that the entire internet is wrong.
While the spoke protector is probably marginally helpful in preventing catastrophe from an overshift, it's most useful function as far as I can tell is to shield the exposed bearings in the backside of the freewheel from debris intrusion.
The rest is cultural inertia, hopes, dreams & luck.
On bikes with freewheels, I recommend the dork disc be installed for maintenance reasons more so than any disaster mitigation concerns.
It might be an unpopular sentiment but, anyone who relies on a safety device for safety usually get what they deserve.
That being said: Shiny, metal dork disks get a pass.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
My mid 2015 MacBook is too old for anything beyond Monterey. I suspect I could poke around in some Safari setting and see what is askew, but I rarely follow video links anyway.
Palmer
Quoted: 1668 Post(s)
Liked 1,820 Times
Back in the day: straight cut cog teeth, late shifting derailleurs that required overshift.
Now: shaped and ramped cog teeth, early shifting indexed derailleurs.
Quoted: 99 Post(s)
Just to be wrong the guys test methodology is broken. He uses his treadmill to spin the wheels and then drops the chain with minimal torque on the cranks and, as a result, no realistic, short/long term tension in the chain. If he dropped it whilst pedaling with real world tension in the chain and his butt on the saddle he might, will, see different results.
Likes For chorlton:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,483 Times
Likes For SurferRosa:
Quoted: 499 Post(s)
Liked 433 Times
Judging by the chewed up spoke protectors I've seen they do a good job of protecting spokes on the cheap and neglected bikes that they were often fitted to. But many of those had cutouts rather than being full pie dish.
Likes For Bob Ross:
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
Likes For Polaris OBark:
Quoted: 1607 Post(s)
Liked 2,216 Times
I typically remove them but then most of the bike I have didn't come with any. The one that did blends in so I left it on.
P1000031 , on Flickr
Likes For SJX426:
Likes For Hondo6:
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 583 Post(s)
Liked 697 Times
Next thing will be bashing brake safety levers.
Likes For Gresp15C:
Quoted: 1324 Post(s)
Liked 927 Times
I think of spoke protectors (aka Dork Discs) as insurance. You don't really want if but if something does go wrong you're really glad you have it.
To me a spoke protector doesn't look any worse than a disc brake does.
Most of my bikes don't have a spoke protector.
Cheers
Cheers
Quoted: 3511 Post(s)
Liked 2,926 Times
