Thudbuster ST vs LT
Thudbuster ST vs LT
Old 09-23-14, 10:37 AM
Doggus
half man - half sheep
Doggus's Avatar
Location: Big Mineral arm - Lake Texoma (Pottsboro, Tx)
Quoted: 9 Post(s)
Thudbuster ST vs LT
It's a long story but we're getting back into tandem'ing. We used to use a Thudbuster ST. We've since lost that seat post so I need to pick up another. Is it worth it go with the long travel version for a heavier stoker (220-230lbs)? It's quite possible that with continued cycling that 220-230 could become 160-170 like it used to be but I'm not counting my chickens, and that won't be for a LONG time.
Doggus is offline
Old 09-23-14, 01:44 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Had a Long one on my Bike friday Buy .. since the spring elastomer is in 2 sections you could fine tune the spring rate-elatomer density as the situation changes
Purple is the most dense , black, Blue and grey less so and you can mix them + there is the long preload bolt running through them to adjust.
the ST also has a number of different densities you have to look at the number molded in . its like a clock dial .. 3,5,7,9
long travel does require the post extension be sufficiently Long enough.. cane creek site gives the Numbers.
fietsbob is offline
Old 09-24-14, 07:02 AM
Paul J
Paul J's Avatar
Bikes: 1980's Spectrum 10 sp Campagnolo Centaur, 1990 Eddy Merckx 10 sp Campagnolo Centaur, Bushnell Tandem, Co-Motion Speedster Tandem
Quoted: 185 Post(s)
Liked 102 Times in 65 Posts
I you are riding on the road you will be fine with the ST. We have an ST on our tandem and it accommodates a good variety of stokers and that weight worked fine using the stiffest insert.
Paul J is offline
Old 09-24-14, 10:06 PM
mwandaw
Half Fast
mwandaw's Avatar
Bikes: A road bike and a tandem road bike
Quoted: 9 Post(s)
Liked 7 Times in 2 Posts
My wife (and stoker) used an LT for a while. The suspension was very comfortable, but she found herself bouncing so much that she gave it up. Our cadence is typically 80-90, so that might have had something to do with the bouncing. She weighs much less than your stoker, but as fietsbob pointed out, there are a variety of elastomers available.
mwandaw is offline
MountainCruiser
Tandem Cycling
13
05-08-18 07:32 PM
alias5000
Tandem Cycling
28
09-05-17 08:49 PM
Sprout97
Tandem Cycling
18
01-14-17 05:04 PM
Venturous
Tandem Cycling
15
08-29-10 05:50 PM
tdbmd
Tandem Cycling
9
03-25-10 10:19 PM
