Powder coated frame advice
Old 06-08-22, 04:15 PM
williamskg6
Quoted: 29 Post(s)
Liked 65 Times in 17 Posts
Hello, everyone. I had a 1987 Specialized Sirrus powdercoated and when they did the job, they powdercoated the dropouts. This looks nice but has a fun problem - the rear wheel will slip forward while riding even if I crank the quick release down very tightly.
I was wondering if anyone else has had this issue and found a solution that doesn't require keeping Arnold Schwarzenegger around to tighten the rear quick release prior to each ride.
Thanks!
williamskg6 is offline
Old 06-08-22, 04:45 PM
masi61
masi61's Avatar
Quoted: 1163 Post(s)
Liked 442 Times in 315 Posts
What is your theory as to why the powder coating is making the quick release skewers lose their grip? Are you using internal cam or external cam skewers? If the external type are slipping get some shimano Ultegra ones (or comparable) and they should hold much better. I can't see why you would need to somehow remove the powder coating on the dropout face.
masi61 is offline
Likes For masi61:
Old 06-08-22, 05:21 PM
delbiker1
Mother Nature's Son
delbiker1's Avatar
Quoted: 853 Post(s)
Liked 1,436 Times in 818 Posts
I am thinking your bike has horizontal drop outs. I have the same issue with a late 80's Ochsner, but the drop outs were not powder coated with the rest of the frame. It is an issue with the horizontal drop outs, the wheel has a tendency to be pulled forward on the drive side due to the torque from the chain. As stated above, good internal cam skewers are needed, and you still might have to tighten them down more than you would with vertical drop outs. When I spread the rear to 130mm, I put on a set of Open Pro/Ultegra wheels with Ultegra QR's, internal cam, and the wheel does not slip as long as it is tightened enough, which is far less than the old ones. I could hardly open those after tightening them so much. I have an older set of Bontrager wheels and QR,s, not internal cam, they will slip on the Ochsner, but not on a bike with vertical drop outs.
delbiker1 is offline
Old 06-08-22, 10:40 PM
williamskg6
Quoted: 29 Post(s)
Yes, the dropouts are horizontal, as all good 80's bikes are. I not only have problems with them slipping on the drive side, but the non-drive side too. I have to crank my quick releases down so tight they're almost impossible to remove. Sounds like I should try to get some internal cam skewers and try that.
Likes For williamskg6:
Old 06-08-22, 10:43 PM
williamskg6
Quoted: 29 Post(s)
Easy. The powder coat paint is very slippery. It's also very hard and smooth, hence the slippery. I may have to try those internal cam skewers though - the ones I have are just the ones that came with the wheels and they're almost certainly not internal cam.
Old 06-08-22, 11:53 PM
3alarmer
Friendship is Magic
3alarmer's Avatar
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times in 7,208 Posts
....those quick releases that look like this are not suitable for horizontal dropouts, regardless of paint, chrome, or powdercoat on them.
I don't think I ever saw a set of those until frames with vertical dropouts became more common...which was well after the 1980's.
3alarmer is offline
Likes For 3alarmer:
Old 06-09-22, 04:02 AM
delbiker1
Mother Nature's Son
delbiker1's Avatar
Quoted: 853 Post(s)
The slippage usually happens on the drive side, that, of course, cause the non-drive side to slip also. I am guessing when the wheel slips, the front of the wheel/tire are off kilter towards the non-drive side.
Old 06-09-22, 08:05 AM
williamskg6
Quoted: 29 Post(s)
I have ordered a Shimano Ultegra 6800 internal cam quick release. I'll post back when I've given it a try. Thanks for the advice everyone!
Old 06-09-22, 09:06 AM
himespau
himespau's Avatar
Quoted: 4234 Post(s)
Liked 2,949 Times in 1,808 Posts
I just wish campagnolo quick release skewers weren't so expensive, because they work so well on horizontal dropouts. Fortunately, you only have to buy them once.
himespau is offline
Likes For himespau:
Old 06-09-22, 10:00 AM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
https://surlybikes.com/parts/hurdy_gurdy
Rolla is offline
Old 06-09-22, 10:38 AM
zandoval
zandoval's Avatar
Quoted: 966 Post(s)
Liked 1,629 Times in 1,045 Posts
See post #65: https://www.bikeforums.net/classic-v...l#post12257823
This has been a cheap solution and solves the problems from using Cheap Light Weight Quick Releases...
zandoval is offline
Old 06-09-22, 02:35 PM
Eric S.
Eric S.'s Avatar
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times in 36 Posts
Skewers don't seem to "bite" like they used to. I've experienced slippage and found a suggestion to lubricate the cam of the skewer. So far, it has fixed the problem on the road bike I use for commuting, a steel LeMond Tourmalet with short, semi-vertical dropouts.
Eric S. is offline
Old 06-09-22, 10:46 PM
Bike Gremlin
Mostly harmless ™
Bike Gremlin's Avatar
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times in 130 Posts
For what it's worth: this (internal-cam QR skewer) has worked for me with a powder-coated horizontal-dropout frame.
Bike Gremlin is offline
Likes For Bike Gremlin:
Old 06-10-22, 07:16 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3588 Post(s)
Liked 3,400 Times in 1,934 Posts
Yes. Exposed cam quick releases are only reliable with vertical dropouts.
JohnDThompson is offline
Old 06-10-22, 09:26 AM
ign1te
Quoted: 92 Post(s)
Liked 48 Times in 34 Posts
Convert the rear hub to a solid axle.
ign1te is offline
