What size tires fit 27x1-1/4" wheel?
Bikes: Peugeot UO8 (vintage 1970's)
What size tires fit 27 x 1-1/4" wheel?
I have a vintage 1970's bike with new wheels that are 27 x 1-1-1/4". And I see tire selection for these bikes is 27 x 1-1/8" , 27 x 1-1/4" + 27 x 1-3/8". Will either of these 3 tire sizes be ok on this size wheel or does wheel width need to match tire width exactly?
I am potato.
Quoted: 1789 Post(s)
Liked 1,630 Times
Yes.
The number you are looking for is ETRTO size 630x(some number) or (some number)x630, 630 being the diameter of the bead seat in millimeters & the other number being the nominal width on a typical rim.
27 inch is an imperial size tire. Current tire's tend to be sized in reference to metric standard. ETRTO is the industry organization that unified all the various globally found number systems to bead seat & width.
In short any of the 3 sizes you list will fit.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,220 Times
As long as they are all have an ETRTO size of 630mm, they will all fit. You are looking at only 1/8” between the sizes and 1/4” over all. Not much in the grand scheme of things.
Stuart Black
Stuart Black
Quoted: 1062 Post(s)
Liked 665 Times
Vittoria Zaffiro 27x1-1/4 appear to be in stock at Bike Tires Direct. All other things being equal, I'd go with the wider tire, for comfort.
Admittedly, I hoarded a pair of them when the pandemic started but the bike parts shortage hadn't yet materialized. Just to keep my old bike going for a few more years
Location: western Massachusetts (greater Springfield area)
Bikes: Velosolex St. Tropez, LeMond Zurich (spine bike), Rotator swb recumbent
Quoted: 67 Post(s)
Liked 67 Times
Somewhat off topic, if the ERTRO number is the diameter, why is a 630 bigger than a 700 which is bigger than a 650?
Liked 665 Times
I don't know the history of the size designations, but have learned the lesson that the ETRTO is the only thing that's sensibly related to a physical dimension of the wheel.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
https://www.sheldonbrown.com/tire-sizing.html
Quoted: 967 Post(s)
Liked 1,631 Times
So... Considering the size now what type of terrain will ya be ridding. For me and my torn up asphalt roads its these two. The Continental Ride Tour is proven. It is absolutely my favorite tire. For gravel ridding I use the Kenda.
I also use Generic Butyl tubes but when the TPU tubes come down in price I am certainly going ta give um a try...
Quoted: 346 Post(s)
Liked 398 Times
Hello MIKE w MASS;
Be careful what you call a 650 TIRE designation BECAUSE:
.............................................................................Did You know that the 650 tire = the SCHWINN ONLY 597mm 26 x 1 3/8 tire and ancient EA1 spec. (597mm)
so remember that:
650 = SCHWINN ONLY 597mm, and ancient EA1 specification tire of 597mm
650a = THE COMMON "Everybody Else In the World Except Schwinn" the Everybody Else's 26 x 1 3/8 590mm (37-590)
650b = 584mm
650c = 571mm
.......................so be careful what you call a 650 TIRE even though the old three speed and 1960's and 1970's dept store 10 speed's (650 a 26 x 1 3/8 37-590) has not been typically seen on NEW bicycles sold in the USA since probably about 1984 - 1985.
The 650a 26 x 1 3/8 37-590 tire is still produced in large numbers by about a dozen tire manufacturers, as millions of tourist 3 speeds are still enjoyed in JAPAN as well as Europe and other continents, as well as folks here in the USA that have forty to sixty five year old classic Non-Schwinn 3 speeds,, classic Non-Schwinn 5 speeds, and classic Non-Schwinn 10 speed bicycles in that 590mm 26 x 1 3/8 37-590 "COMMON-everybody else" 590mm non-schwinn wheel size which also is known as 650a.
What you likely commonly refer to as being "the 650" is actually probably the 584mm size which is 650b.
27 INCH wheels = 630mm
700C = 622 mm
Traditionally back in the seventies BEFORE TIRE MAKERS BEGAN TO REALLY CHEAT THE BICYCLE TIRE BUYER in actual/nominal tire tread widths,
The typical 27 x 1 1/4 tire for a ten speed was typically a "TRUE" or "NEAR TRUE within + or - 1mm TREAD WIDTH of (32-630)
(32-630) 32mm being the TREAD WIDTH ON THE WHEEL
....................However today's tire manufacturers sometimes "CHEAT" , while a few are TRUE to size......just DEPENDS on the tire model from the particular tire mfr.
What I am describing as "CHEATING" is heck there are some tires today in which a 32-630 (27 x 1 1/4 tire) is actually only approximately really 28.4mm tread width instead of being TRUE 32mm. *****You did not have this wide of a discrepancy back in the 1970's.******* What can I say that hasn't already been said millions of times over the past 35 years..............................you've just gotta investigate the brands and their tire offerings in the 27" (630mm) size on an individual case by case basis.
27 x 1 3/8 tire (37-630)
27 x 1 1/4 tire (32-630)
The inexpensive Kenda K-40 gumwall wire bead tire of 27 x 1 3/8 (37-630) is available everywhere on amazon and out on the worldwide web.
https://www.amazon.com/Kenda-Street-.../dp/B07BVJPVQ6
You might need that 37-630 wire bead K-40 Kenda just to get tires on your ancient Seventies era bike-boom 10 speed to have current rubber which is near to what the original tread width was of that 1973 era, 50 year old 27 x 1 1/4 tire back when you were listening to 8 track tapes, and wearing bell-bottoms and smoking who knows what....
see Sheldon Brown for further detailed explanation on......
https://www.sheldonbrown.com/650b.html
https://www.sheldonbrown.com/26.html
so remember that:
650b = 584mm
650c = 571mm
700C = 622 mm
Likes For Vintage Schwinn:
Quoted: 2485 Post(s)
Liked 2,956 Times
One important consideration for most bikes with 27 x 1 1/4" rims: hook-bead versus straight-sided (or "hookless") rims.
If your rims have inner ridges (labeled "Hook" in the illustration), although they might give a more comfortable ride at lower pressures, you can safely run the tires at or close to the maximum pressure indicated on the tire.
If you rims are hookless, the safe maximum pressure is probably no more than 75 psi. A pressure range of 60 to 75 psi is usually best for both reasonable comfort and efficiency, anyway.
Likes For Trakhak:
I'm not an expert but 1 1/8" will fit a 1 1/4" wheel with no problems or issues. We did it all the time back in the 1970's and early 80's. They were consider inter-changeable depending on if you wanted a fatter or skinnier tire. Matter of fact, it was considered "cool" to have the skinniest tires. Would I put any other tire on my rim that are not designated for 27 x 1/14 or 27 x 1/18? No, not unless I could be convinced that a new tire is specifically designed for that rim.
Can you fit other tires to a 27 x 1 1/4" rim? Sure, but it doesn't mean that you should. I have an older Raleigh Wyoming that has 27 x 1 1/4" rims and I searched to find a decent pair of 27 x 1 1/8" tires to fit it. I was not going to take any chances.
Likes For drlogik:
I've tried a few 27" tires in the recent past. I am most happy with these....https://www.swifttire.com/product/sa...8-folding-tan/
The nominal size is 27 x 1 3/8, but they are really closer to 27 x 1 1/4.
Quoted: 790 Post(s)
Liked 348 Times
I would like to know what the fastest available 27" tire is so I can get a pair on my Huffy to run in the TT this summer. I am hoping that with a set of good tires and one other trick I have up my sleeve, maybe I can run as fast as I did last year. When you are in your 60s running as fast as you did the year before is actually running faster. I heard the Continental gatorskins have low rolling resistance.
I am potato.
Liked 1,630 Times
So just in case:
Panaracer Pasela is quite possibly one of the last really "good" 27 inch tires readily available on the market.
If anyone reader knows of a lighter, better, more supple 630 tire than Pasela that is available for purchase, I am genuinely interested.
Car dependency is a tax.
Bikes: 1974 Masi GC, 1982 Trek 728 (aka 720), 1992 Trek Multitrack 750
Quoted: 122 Post(s)
Liked 222 Times
https://en.wikipedia.org/wiki/ISO_5775
Liked 4,220 Times
’Tis a silly, cumbersome, and throughly confusing system. There are like 6 different “sizes” for the 26” designation and none of them are interchangable,
Edit: My mistake. A 27” tire would need to be 1.1” tall and a 700c tire would need to be 39 mm
Palmer
Quoted: 1670 Post(s)
Liked 1,825 Times
The Schwalbe Marathon Greenguard has comparable rolling resistance, much thicker thread and higher puncture resistance.
The Continental Ultra Sport III has much lower rolling resistance than either.
See:
https://www.bicyclerollingresistance.com/
YMMV
I am potato.
Liked 1,630 Times
tcs
Thanks!
Thanks!
Quoted: 913 Post(s)
Liked 515 Times
As one who still uses 27" tires, I like to draw attention to this thread in the C&V forum:
https://www.bikeforums.net/classic-v...ce-thread.html
where all 27" tires and who has them is discussed. I thought it used to be a sticky but not now.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
While pretty much any 630mm tire will fit on a 630mm (aka 27 inch) rim, the limiting factor may be frame/fork clearance. Measure how much clearance you have with your current tires to see how much wider you may go.
Likes For JohnDThompson:
Quoted: 790 Post(s)
Liked 348 Times
I understand you are probably kidding, unless you really do have one of them fancy funny TT bikes 7-11 & Raúl Alacalá made famous...
So just in case:
So just in case:
Likes For beng1:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
This seems like one of those threads that AI chatbots could replace
Genesis 49:16-17
Genesis 49:16-17
