12spd chainring with 11spd groupset ?
Old 06-27-23, 08:42 PM
louis711
Hi,
Im considering getting FC 7100 12spd crankset since it is much cheaper and also better design. Will it work with my 105 R7000 groupset 11 spd: FD, RD, chain and Cogs,....
Thanks !!!
louis711 is offline
Old 06-28-23, 06:55 AM
Zaskar
Quoted: 479 Post(s)
Liked 277 Times in 156 Posts
You should be fine.
- The outside width of the chain gets narrower as the cog count goes up, i.e., an 11-speed chain is wider than a 12-speed chain - but only the outside dimensions.
- The inside width - the gap the cog/chainring teeth fill - of the chain is the same - from 9-speed up. So, the inside dimensions of an 11-speed and 12-speed chain are the same.
But (there's always a but)... the ramping of the chains won't be identical - each optimized for the cassettes and chain rings. That means when shifting from the small to big ring, you may (may) feel it. I really don't know what "it" is though. These are fractions of millimeters... at very slight angles. So, it's likely you'd feel no difference in the two chains/chainrings.
And since this is the internet, give it a couple min. and someone will pop in with actual, real-world experience and either blow up or confirm my "should" and "may" hypotheticals.
Zaskar is offline
Old 06-28-23, 07:06 AM
eduskator
eduskator's Avatar
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times in 440 Posts
Only thing I can see is the 12sp chainring tooth may be narrower than the 11sp, so the part of the chain that's on the chainring may have a little play (left / right or inward / outward).
eduskator is offline
Old 06-28-23, 07:15 AM
GhostRider62
Quoted: 2333 Post(s)
Liked 2,097 Times in 1,314 Posts
Wrong. No diff
GhostRider62 is offline
Old 06-28-23, 11:56 PM
louis711
Originally Posted by Zaskar
You should be fine.
Thank for answering !
There is little information on the internet, i believe it works however require adjusting FD screw which is a nightmare for me
These are 2 videos i found on youtube, sorry i cannot post the link at the moment
Shimano Ultegra R8100 12 Speed Crankset to 11 Speed Mechanical Drivetrain Compatibility Test
Shimano Ultegra R8100 12 Speed Chainset Is It Compatible With 11 Speed R8000?
louis711 is offline
Old 06-29-23, 07:25 AM
Zaskar
Quoted: 479 Post(s)
The 12-speed chainrings are spaced bit wider than 11-speed
If you're not changing size/tooth count, the derailleur location - vertical on the mount and rotational - doesn't change.
You may need to adjust the H/L settings. Don't be intimidated. This is the easy part of installing, setting up, adjusting a front derailleur. The "H" (High) and "L" (Low) screws simply limit how far the derailleur moves. Your adjustments would be tightening that range... a very little bit. It really is as simple as turning a Philips head screw a tiny amount and watching derailleur move IN about .5mm
Zaskar is offline
Old 06-29-23, 08:07 AM
eduskator
eduskator's Avatar
Quoted: 989 Post(s)
Originally Posted by GhostRider62
Wrong. No diff
No difference at all between a 12sp chainring and a 11sp chainring? Allow me to doubt this
Do your homework before misinforming people.
Likes For eduskator:
Old 06-29-23, 08:22 AM
Zaskar
Quoted: 479 Post(s)
11 and 12 chainrings are not identical. The teeth are cut to work with the ramps on the 12-speed chain... which is designed (plates) to work with a 12-speed cassette. On the crank, the spacing of the small and big rings is also different - 12-speed systems have a wider chainline.
But... compatibility is subjective. These differences are often fractions of millimeters. Sometimes they manifest is just a tiny bit of extra driveline noise - as the chain "lands" on the chainring differently. Sometimes shifting is affected... if you really pay attention. And sometimes it just doesn't work 'cause you did the reverse-compatible thing the wrong way and things just don't fit ;-)
In the OP's case, it will work.
Zaskar is offline
Old 06-29-23, 08:50 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4737 Post(s)
Liked 1,533 Times in 1,004 Posts
I think he only maintained that there's no difference in width. not 'at all'. No idea myself though if this is true.
Sy Reene is offline
