Help Setting Realistic goals for TT improvement
I currently do a local TT of 8 miles - relatively flat course and did it last night averaging about 22.5 MPH. I was pretty tired/sore legs from a race sunday so think I could have done a bit better with fresh legs. Will test it again in 2 weeks.
How realistic is it to get to 25MPH average in next 5-6 months?
I am in decent shape now but will do the following to try to achieve the goal, and if it takes me until next year that is fine.
1) Weight loss of 10 =15 lbs - I weigh 190 now- usually at 180 when training more - so will loose 10-15 lbs the next 1-2 mts from training and getting back on healthier eating plan.
2) Interval training to raise thresholds - will do this and never did much of it last year so did not improve that much. Also purchases Carmichael's TCC book as have limited time to train.
3) Joined a group training where I have access to a coach and challenging group rides.
I think from a graph I had someone help with last year it says I would be going from 250 watts to 325 watts to make the bump in speed. This sounds impossible, but 2.5 MPH avg should not be that much higher power required.
I figure you guys are the smartest in these forums so posting here to see what is realistic and the best way to get power up quickly for TT.
Cat-5-O-Meter: Training
Bikes: Cannondale Caad 8
With TT's your main focus should be Force, Muscular Endurance, and Endurance. This requires a high LT-power output and a large aerobic capacity.
**** that
Quoted: 1099 Post(s)
Liked 104 Times
For some reason I thought people were doing 25 mph 40k TTs on 240-250w..
gmt
Quoted: 45 Post(s)
I assume you are doing these TTs on a regular road bike. Aerobars?
If you are talking about buying speed, I think you could get to 25mph without a whole lot of LT improvement. If you intend to do it all with your legs... 5-6 months sounds like a very short time to gain that much.
gmt
Quoted: 45 Post(s)
size 51 slice hi-mod with aerobars slammed. I think it's 14cm drop at the moment. I tuck my head down as far as possible. Disc rear and front HED3. Skinsuit (long sleeve), shoe covers, Uvex helmet, no gloves.
部門ニ/自転車オタク
Bikes: 2008 Blue T16, 2009 Blue RC8, 2012 Blue Norcross CX, 2016 Blue Axino SL, 2016 Scott Scale, Fixie, Fetish Cycles Road Bike (on the trainer)
At 6'2", 177 lbs, I did 4½ hrs at 24.6mph (39.6 kph) @ 267 watts (273 normalized). If the course is truly "relatively flat" you won't need 325+ watts for 25mph.
w/kg is almost irrelevant on a "relatively flat" course, and it's more about watts vs frontal area. 8 miles can handle an extremely aggressive aero position and you could get there at 270 watts.
Now, if by relatively flat you mean "rolling," that's a different story.
Envision, Energize, Enable
I am on a TT bike (Fuji Aloha) and working on getting better at position. I did recently move to more aggressive drop - took out spacers to get about 2.5. Also up graded from the stock Xero wheels to Zipp 404s and just got in the wheel builder disc kit to try that. I do intend to get a skin suit, aero helmet and booty covers but wanted to get speed up a bit before putting on the full outfit as such.
The wheels definitely help at the higher speeds and I will benchmark things in 2 weeks.
I have no idea on what power I produce - that was some example I pulled that someone had sent.
The course has some rollers not totally flat. I do very well in totally flat and downhills due to body weight
One problem is the large frontal area - I am very broad shouldered - 44 inch chest - only 5 9 and weight 190 now. A lot of weight top heavy from natural build and weight lifting. I can diet to 180 but that is pretty lean for me, get me to 32 inch waist and zero stomach. Just have a heavy build/bone structure and upper body mass/arms that is of no benefit to cycling.
Slow'n'Aero
Heck, I've broken 25mph (actually 25.5 mph) on just 225W before over 40K...
pan y agua
Quoted: 1467 Post(s)
Liked 745 Times
Unless you have the aerodynamics of a brick. My FTP is 331 and I struggle to break an hour.
You could get lost and die.
You could hit a tree and die.
The question is, did you pass the guy behind you, or is he about to pass you?
I will see what speed I get in 2 weeks when I try it with fresh legs. I expect to be average around 23MPH - can then try more Aero - more drop - and also wheelbuilder disc in back. After that I will look at a TT helmet and skinsuit and booties.
Must Go Faster
Bikes: Trek Madone 5.9, BMC Road Racer SL01, Orbea Aletta TT
I would suggest doing lots of short (2-5 min), very hard intervals to raise you speed along with longer intervals at TT pace (FTP) - say 15-20 minutes. Also, try to get in two or three rides a week of 3+ hours in length around zone 2. Do this for a while and you will see increase in speed if you give yourself adequate recovery.
Depending on your optimum TT cadence, I would suggest doing some big gear riding once or twice a month to help build power in your legs. (Although kind of useless if you TT at 100+ cadence).
Cat WTF
pan y agua
Liked 745 Times
It's not. In fact it's going to slow the OP down. Longer endurance rides have their place. But 3 long rides a week are definitely going to hurt the OP's speed.
