What Do I Do With Replacement Crank Set Grease Balls?
Finally, please clear something up for me:
Are you suggesting that, even if you had a suitable torque wrench and a suitable socket wrench ready to hand, you would never try the two-wrench technique, for fear of ending up with one or both of the crank bolts at an inappropriate torque setting?
Well, the need for two expensive torque wrenches.
I torque cranks by leaning over the top tube and grabbing the opposite arm and the wrench and using a push/pull motion from directly above the centerline between them. It really doesn't take much strength at all since all you're doing is keeping the crank arm from moving, which is pretty easy considering that arm is locked at the elbow. I think a lot of this kind of discussion comes from a lack of good technique - (for instance) I have never found a crank I couldn't extract, no matter how difficult, by arranging myself so I have a foot on one crank.
You're right, as usual, about the conventional technique working perfectly well. I just happened to think up the two-wrench technique back in the mid-'80's, out of boredom, assembling bikes in the middle of the winter.
Back then, I don't know if any bike shops had torque wrenches. Ours certainly didn't. So I was using two socket wrenches, or maybe a Campy "peanut butter" wrench and a socket wrench, to snug up the bolts. But it did speed up the torquing process, if only by half a minute or so. Fun, too. (The "fun" threshold is pretty low in bike shops in the dead of winter.)
Liked 3,200 Times
The bike community is gradually getting up to speed to "torque" because modern carbon fiber parts are much, much, easier to damage via over-tightening than old school steel and aluminum parts.
Correct torque is a good practice anyway and has been used in other shops for decades.
A bolt has clamping power because it stretches as you tighten it - sort of like a rubber band. Torque in a shop is really meaningless. It doesn't matter how hard you torque a bolt. What actually matters is how much you have stretched that bolt. Fortunately, torque and bolt tension correlate pretty closely, so we can use a torque wrench to get a workable idea of bolt tension without measuring it directly (which is hard).
Too little stretch, and the bolt doesn't give its maximum holding power. Too much stretch, and the bolt can become permanently "stretched out." The optimum stretch for maximum bolt clamping power is just below that point where it permanently stretched out and ruined. However, many bolts can handle more tension than the stuff they are bolted into. Putting 100 ft-lbs. on a bolt just because the bolt can take it might flex, bend, crack, deform, or break whatever that bolt is holding. Bolt size is a decent general indicator of how much clamping pressure to apply, but not always reliable - better to look up the actual torque value or range.
Likes For ScottCommutes:
Oh dear. Picking up two wrenches instead of one.
Seriously:
Of course there's nothing inaccurate about using one crank arm or the other. I didn't suggest otherwise.
And: sure. Few bike enthusiasts have a shop-quality torque wrench capable of being used to set crank bolt torque lying around. But if you do, try using the two-wrench technique sometime.
In any event, as I said, it's faster and eliminates the need to grasp the (annoyingly short) off-side crank arm and is thus easier (especially now that I'm an elderly weakling). People who work in bike shops generally like discovering ways to make a task both faster and easier, with no downside.
I admit to feeling a bit proprietary about this discovery. It's a shame that so few people seem aware of it. And now it's the twilight of the two-bolt crankset era, so it's effectively obsolete anyway.
Seriously:
Likes For choddo:
Likes For Kontact:
All of us grew up with metal parts that flex politely when they are stressed, and then bend back into perfect shape when the stress is relieved.
Carbon is a whole different animal. Look at the wreck of the Titan submersible diving the Titanic wreck side. Cumulative stress on the carbon fiber hull from multiple prior dives snapped individual fibers a few at a time until the entire hull imploded catastrophically at depth.
The damage was microscopic. I don't know any way to check how much strength is left in a carbon fiber part. One thing you can do to keep carbon fiber parts in good shape is to properly torque your bolts.
Another is to not subject them to 1800bar
You're on your own there. I've skipped directly from square-taper bottom brackets to Hollowtech II. (With a couple of stopovers I'd rather forget, including Campy Ultra-Torque - or maybe it's Power Torque - either way, it has a click I haven't put much effort into getting rid of - and some FSA proprietary design - works fine, but I much prefer Hollowtech II.)
Also, turning tools are a particular length for a reason - the manufacturer is trying to help the less skilled achieve good torque.
IKEA furniture uses a certain size key so you don't rip right through the material.
Cars come with a tire iron that should get the job done without breaking anything (usually I wish these were longer!)
A 1/2 ratchet wrench is typically longer than a 3/8" or 1/4" ratchet wrench because it is used for higher torque.
If you look at your 11-piece metric wrench set or your hex wrenches, each one gets progressively longer to help guide your hand toward an appropriate torque.
Long pattern wrenches are fine for getting stuff apart, but not the best choice for getting stuff back together.
Even a quick release lever on a bike is designed to feel intuitive to a person of average strength.
Then I looked up British Standard Whitworth on Wikipedia and got schooled in a hurry. Whitworth was there first.
Kind of the way Suntour used plastic stem caps on the first AheadSet generation to keep mechanics from over-tightening the stem bolt.
But customers and mechanics jumped to the conclusion that Suntour was just cheaping out on the part and demanded metal stem caps.
Suntour said, "Fine; Have it your way" and went to metal caps.
Back to the T47 cups, though: just looked, and Shimano specifies min. 35/ max. 45 Nm. I'll check mine. They're almost certainly not tight enough by that standard.
Liked 1,757 Times
Well thats a worthy question.
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/242x182/screenshot_2024_02_27_10_22_49_e4ae90c989445cd8b704359b98e0303232bb128c.png)
AmazonPic
Well I think they are just Balls Of Mystery Grease, just put there to remind you that you need to make sure your bottom bracket is greased and that a thin layer of grease is applied to the spindle and threads of the spindle cover. Also note that after the bolt is installed you can cover the head of the bolt with grease to prevent rust under the bolt cover, if you use it.
My suggestion is to remove the manufacturers grease and use Marine Grease, of any flavor, to grease your bottom bracket and spindle. If your crank is in fact worn out then you most likely need to service the bottom bracket. I dont know if you have the proper tools. Note that if you do not have the ability to remove your spindle and bottom bracket to get to the bearings you can still clean the bottom bracket. Here's a link to give you a few ideas. Youtube: Trick for Removing a Bottom Bracket on a Bicycle
AmazonPic
I read the BSW Wikipedia article. We really take it for granted that a wrench is the size it says it is. I did not appreciate that some wrenches back in the day were instead marked with the diameter of the nut/bolt they were designed to turn.
Also, Whitworth threads to this day are used on Leica camera and enlarger lenses as well as stage lighting equipment mounts (as well as some other stuff). Goes to show you how hard it is to standardize machine tools.
señor miembro
Bikes: '70s - '80s Campagnolo
Liked 6,764 Times
What do I do with crankset replacement grease balls? I can't find any instructions anywhere about what to do with the grease balls.
Obviously, you grease the installation of your bb shell, cups, and spindle. Always grease the pedal axle threads. Some grease the spindle taper, some don't. Some grease the crank bolts, some don't. (I use only a tiny bit on the bolts.)
I am potato.
Liked 1,817 Times
A deflection test is the most common method to test service life. They load the part in some way initially at time of construction and measure the deflection. Then at prescribed intervals they repeat the test and compare the result against the original. When the part is deemed too flexy due to micro cracks in the matrix the part is pulled from service.
The Titan Sub was a hack job by an idiot using expired carbon fiber in initial construction in compression the way that it is weakest with no initial or subsequent testing. Per his life wishes, he is now known for all the rules he's broken. Just the way he wanted. (It's a shame about the kid tho.)
Car dependency is a tax.
Disco Infiltrator
Liked 2,129 Times
What a winter thread this is. Two wrenches! Genius! Carbon fibers! One guy can't do 40 NM!
Genesis 49:16-17
Genesis 49:16-17
I am potato.
Liked 1,817 Times
They X-ray commercial aircraft at certain intervals, too.
I was thinking Formula 1, specifically.
I’m considering buying Praxis’ tool and sending the Park Tool on back. It seems designed for the tiny gripping space on these BB cups without scraping paint off the frame.
When I was using a puller to pull the old arms off, one came off fine, but with the other one, the puller pulled out and stripped the threads on the arm(but the puller is OK, it screws in to the other arm). Is there anything I can do besides get a new crankshaft? I'll have to pull out the crankshaft and see whats engraved on it to help me find a new one. What specs to I need to know? Is it possible to get just the shaft without any of the other hardware? The bike is a Schwinn Sidewinder.
Edit: I don't think it'll help because my bike is too new to be in a database, but here's the serial number: SNMNG11A9137. None of you are nerdy enough to be able decode the serial number are you? I think I found Schwinn's code book, but my serial number is too new to be in it.😥
Why does the post I made after this one need to be approved by a moderator?
I found this video on YouTube that shows how to get an arm off when the puller strips the threads on one side: watch?v=NjI5eDPjS6o In that video, it was the arm with the chain ring that he got off and he pretended the other side was stripped. In my case, Its the chain ring side that was stripped. Please tell me I can pull the crankshaft(or spindle is you cockney people call it) out the other way. Also I didn't realize I didn't know how to remove the crankshaft. I've done it a few times on a BMX bike but never a mountain bike. Is there a video I can watch? I have a Schwinn Sidewinder. Its 8-10 years old I think.
ttps://www.youtube.com
I need one more post before I can post videos. Surely you guys know that every YouTube video has the same URL except for what comes after v= so you should be able to figure out how to watch it. In case you can't, just load another YouTube video and replace that one's serial number or whatever its called with the one above.The important part is halfway through. Thanks
