Help!! Keep getting flats!
Quoted: 9 Post(s)
New to the forum and fairly novice bike rider.
Last Friday I had my rear tube replaced at the local bike shop. That night I had the front go out so I took it back and they replaced the front tube. I put it on he bike rack and when I got home they were both flat. Took it back to the bike shop and they changed the rim tape and replace the tubes again. The following day I went out for a ride and had a slow leak in the rear. Had the rear changed on Monday and this morning the front is flat again!!! The puncture is in different places (sometimes on the inside sometimes on the side). I checked the rim and the tire and can't find anything. I weigh about 210 pounds and I am running 700x28 tires at about 80-85 psi (85 is the max) does anyone know why this is happening. IM going crazy! The only thing I could think of is getting a tire that has a higher max psi to support my weight.
Bikes: I'm a Flatbar Guy
Quoted: 356 Post(s)
210 pounds on 80 psi tires shouldn't be an issue, and I'm assuming the tube punctures aren't from getting pinched on the rim. How old are your tires ? Maybe they're getting a little dry rot on the inside and causing the tube puncture ?
Likes For Scooty Puff Jr:
Bikes: Cannondale Synapse, Focus Izalco, Focus Mares CX, BMC GF02, Giant VT3 MTB (upgraded), Felt Brougham SS
Quoted: 56 Post(s)
I had a similar problem a few years ago and I fixed it by replacing my rim tape...have you checked the tape?
Likes For Larry77:
Quoted: 30 Post(s)
Few months back same issue..every ride a flat. Marked the tire and tube with a red marker so once I found the puncture I could match them up and investigate the tire. I ran my finger on the inside, nothing, used a magnifying glass, nothing, used a cotton ball on the inside of the tire hoping something would snag it, nothing. I had an extra roll of rim tape so replaced it, nothing. Three rides, three flats, bought a new tire, problem solved. I admitted defeat and moved on.
Quoted: 1617 Post(s)
Liked 2,620 Times
I'd say you got into some thorns and didn't get all the debris out of the tire. Could be a spoke poking through. Might be installer error. Could be you're going crazy, but I'd use that as a last resort...
Quoted: 9 Post(s)
The tires are about 2 years old. They are kenda kwest tires that come stock on the purefix cycles. They look fine inside. The old tube I took off is a bontrager 700x35-44 could that be the issue. That seems a little big
Quoted: 9 Post(s)
Quoted: 9 Post(s)
Quoted: 1438 Post(s)
Liked 1,092 Times
stoplight's cotton ball technique is a good one, but I would suggest turning the tire inside-out first to put the inner surface of the tire under tension. This will tend to open up any tiny holes where a sharp item like a shard of glass or the tiny steel wire from a tire belt may be hiding.
Likes For dsbrantjr:
Quoted: 1364 Post(s)
Liked 1,683 Times
I have Kenda Kwests 700x32 and I notice the tread pattern tends to hold small stones. I run tire liners. No flats.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
If the punctures are in different places on the tubes, and happen on both front and rear, that seems to rule out something on the rim or in the tire. Maybe you're just in an area with lots of thorns or tire wires or something. If that's the case you'd want strong puncture resistant tires.
In any case if you keep getting flats try to remember where every puncture is on the tube for further detective work.
Quoted: 9 Post(s)
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
I can't guess the causes of your first two flats, but I'll speculate that the subsequent flats were caused by deficient work by the bike shop and/or defective tubes sold by them. Maybe find a different shop.
Quoted: 4560 Post(s)
Liked 2,803 Times
Flats seem to run in phases for me. I'll go months without any then have several in a row. I had one on a new front tire on my mountain bike in September, due to a big chunk of glass hidden under leaves. Then another flat on the same tire in December, this time a tiny shard of glass. Then five in one week on the same tire, each due to grass burrs. But I've been riding off road, and some really rough rural roads and chip seal, so it's not unusual to encounter lots of sharp pokey stuff.
I finally swapped to a new tube filled with Slime. Hopefully it'll help with the slow leaks caused by the tiny nicks from grass burrs. If it gets me home without needing to stop to patch the tube, I'll be satisfied. I don't want to use liners on the lighter mountain bike tires. I like the handling now.
I'll keep the oft-patched tube for the errand bike, which wears heavy duty puncture resistant tires and has never had a puncture flat.
A PureFix? Real narrow, aero rims? If so, I'm willing to bet money that you're getting flats from the tube being forced to expand down into the (very narrow) rim cavity.
You probably won't like the best solution.
Quoted: 1572 Post(s)
Liked 643 Times
It sounds to me like you have covered all of the typical things that I'd suspect. If I had an old set of tires laying around, I'd give them a try. If the flats stop, and I couldn't find anything in your flat cursed tires, I'd bite the bullet and replace them.
Quoted: 9 Post(s)
I once had a customer have me install new tires for me and immediately took a ride in the park across the street from the shop. He came back about 1/2 hour later with 8 thorns in one tire. I shope that I got them all.
Quoted: 136 Post(s)
Liked 57 Times
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
If it's a rubber strip and you've got a double-wall rim, the strip may be allowing the tube to expand into your spoke holes. Rubber strips are intended for use on single-wall rims.
If you've got cloth rim tape like Velox or Newbaum's, or a plastic strip meant for high-pressure tires, is it wide enough and applied on-center? If it's too narrow or it's not centered, your tube may be expanding into spoke holes and rupturing.
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 458 Times
What kind of tires did you get?
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Liked 2,803 Times
This. Went through it with one of my bikes about six months after installing a new double wall rim. The tube extruded through the thin rim strip in several places. I replaced it with cloth tape (Velox or Nashbar, I had both).
What kind of rim tape or strip did they use?
Don from Austin Texas
Bikes: Schwinn S25 "department store crap" FS MTB, home-made CF 26" hybrid, CF road bike with straight bar, various wierd frankenbikes
Quoted: 11 Post(s)
Don in Austin
