New Pads, Same Type: Rotor Resurface Necessary?
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
Hi everyone,
⬆️ As stated, do I need to grind a disk clean every time I swap in fresh (as in brand new) pads of the same type (e.g. organic/resin) from a different brand? Or do I just drop the new pads in and pedal away?
Bikes: 2018 Jamis Renegade Exploit, 1996 Trek 930, mid-90's Dean El Diente, 2010 Scott Addict SL, 1998 Trek 730, Xtracycle EdgeRunner 30D, Xtracycle Swoop, 1992 Trek 790
Quoted: 87 Post(s)
Liked 107 Times
Drop the pads in and go. Wouldn't hurt to clean the rotors with some isopropyl alcohol but I wouldn't do more than that.
Likes For nathand:
Quoted: 83 Post(s)
Liked 64 Times
Pedal Away. Just be aware the pads won't have full surface contact until they wear in - you might have slightly less braking power. You can try to bed them in - some manufacturers recommend that and provide instructions. Usually involves doing a series of full braking stops from high speed without locking a wheel.
Likes For veloz:
Quoted: 800 Post(s)
Liked 512 Times
Agree with what nathand had to say. Give the rotors a clean with some rubbing alcohol. Drop in the new pads. You're golden.
Likes For NoWhammies:
