16 vs. 17 vs. 18 teeth freewheel??
Old 07-04-08, 02:50 AM
solecal123
i am converting to singlespeed and have no knowledge on the number of teeth on a freewheel and how it affects the ride...so can you help me out by giving me advice on what each number of teeth(16, 17 , 18) would be meant for and why one more or one less tooth would make much of a difference
solecal123 is offline
Old 07-04-08, 03:13 AM
zerosiah
six too eight
zerosiah's Avatar
google "gear inches"
zerosiah is offline
Old 07-04-08, 03:27 AM
kogkrusher
straight krushin'
Bikes: RiGi track bike, Mercier beater, Schwin monster
it is time to become familiar with Sheldon Brown.
kogkrusher is offline
Old 07-04-08, 04:38 AM
gbarchus
gbarchus's Avatar
Bikes: 3Rensho pista, Bianchi mini, Raleigh cruiser
I've read Sheldon but only have the experience of riding on a 16 tooth cog. I would like to know from those who have ridden on these what their experience is. How do they differ?
...also, one tooth up or down on the chain ring? I'm riding 45/16 now and have heard it better to run same (odd/even) number front and back. So, do I go 46/16 or 45/15. From the charts I can see the difference. But, one way is cheaper than the other. Why pay for a mistake when there's so much experience here.
What's your feeling?
Gale
gbarchus is offline
Old 07-04-08, 06:36 AM
thehammerdog
thehammerdog's Avatar
Quoted: 722 Post(s)
Liked 353 Times in 226 Posts
Yo Slick. It will depend ona few things 1. what type of riding you plan to do. Flat/hills/city???
2. what type of rider are you big strong powerful fella or a lightweight spinner "pantani" type. I ride a 42X18 due to my hilly region. I only ride it as a donut/coffee bike.
Good luck
thehammerdog is offline
Old 07-04-08, 06:38 AM
ZiP0082
ZiP0082's Avatar
Bikes: 2008 Mercier Kilo TT
Gale
If you like your current setup, I'd say you should keep it. Super inexpensive 16-tooth freewheels are much easier to get a hold of and to replace than the more specialty 15-tooth freewheel. In a situation where you're stuck with a smaller chainring (like a 40 tooth) is when, in my opinion, the 15t option starts to sound more appealing.
ZiP0082 is offline
Old 07-04-08, 08:57 AM
dobber
Perineal Pressurized
dobber's Avatar
Gale
Changing the freewheel size by one tooth has a bigger impact than changing the chainring.
On my Peugeot singlespeed I've run a range of gears but found a sweet spot at 42/16. But it depends on what your using the bike for, your conditioning, equipment and the conditions your riding in.
In general you can't go wrong between 65-70 gear inches
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
dobber is offline
Old 07-04-08, 09:13 AM
iansmash
Changing the rear gear size is a big deal definitely. I just went from 48/16 to 48/17 and I have alot more acceleration
iansmash is offline
Old 07-04-08, 10:33 AM
roadfix
hello
roadfix's Avatar
Quoted: 195 Post(s)
Liked 116 Times in 52 Posts
Your ideal gear ratio ultimately would depend on your fitness level and your local terrain. About 70 gear inches is a good starting point.
roadfix is offline
Old 07-04-08, 06:33 PM
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times in 19 Posts
16 is harder than 17 which is harder than 18.
No one can tell you what is better for _you_. Go try it. And to echo other posters, 1T jump in rear cog is much larger than a 1T jump in chainring. Do not try to go 2t +/- in one go unless you know exactly what you're doing.
operator is offline
Old 07-05-15, 07:37 PM
Leo001
Bikes: Lightspeed Classic. Specialized Sectur. Specialized Langster. Salsa Beargrease Bianchi Camolante Serotta Colorado Trek Lane
Quoted: 9 Post(s)
Liked 3 Times in 2 Posts
I ride a 42/17, and tried a 42/16 also, on the flat stretches I like the 16, but it makes the hills tough for me. If my area was all flat riding, I'd go with the 16 tooth cog. But as everyone already stated, there are so many variables (terrain, level of fitness, desired speed, etc...) free wheels are cheap, try both.
Leo001 is offline
Old 07-05-15, 08:26 PM
Noli Timere
Noli Timere's Avatar
Quoted: 8 Post(s)
(Not sure if you realize but you've responded to a seven-year-old thread.)
Noli Timere is offline
Old 07-06-15, 05:32 AM
Leo001
Quoted: 9 Post(s)
! Yea, didn't check the date. Thanks
Leo001 is offline
Old 07-06-15, 07:18 PM
xscottypx
Bikes: 2014 Focus Cayo 3.0 / 2000 specialized stumpjumper M4 / 2013 All City Big Block
i changed from 46/15 to 46/17 and it was immense. freewheel is an 18t but i have yet to use it. found the 17t fixed to be more fun
xscottypx is offline
Old 07-06-15, 07:30 PM
Philasteve
Philasteve's Avatar
Bikes: Surly CreamRoller. 98 Giant Rincon. SE UVT
Quoted: 5 Post(s)
Liked 12 Times in 9 Posts
Those are mostly the 3 cogs I run on my Surly, buy them all.
Philasteve is offline
Old 09-17-15, 02:02 PM
childproof
cogs ( rear)
Is there much difference a 16-17 rear cog for easier pedal
childproof is offline
Old 09-17-15, 02:03 PM
childproof
Is there a noticeable difference between a 16 tooth cog and a 17?
Old 09-17-15, 02:11 PM
prooftheory
pro in someone's theory
prooftheory's Avatar
Bikes: FTP
Quoted: 72 Post(s)
Yep.
prooftheory is offline
Old 09-17-15, 02:16 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3588 Post(s)
Liked 3,400 Times in 1,934 Posts
Noticeable? Yes.
Dramatically so? No.
Keep in mind that your wheel needs to be repositioned in the dropout slot when you change cog size. Typically, you can only accommodate a 2-3 tooth change before you run out of slot and need to change the length of your chain.
JohnDThompson is offline
Old 09-17-15, 02:19 PM
childproof
Thank you, you guys are awesome
Old 09-17-15, 04:48 PM
Regulatori
Regulatori's Avatar
Quoted: 16 Post(s)
Liked 42 Times in 12 Posts
I use this site a lot for gear ratio info.
Bicycle Bike Gear Ratio Speed and Cadence Calculator
Just type in your chainring number in the first section and then 16, 17 in the second section. It will show you the differences in cadence vs speed....so you know how fast you'll be spinning on the cranks at different speeds. Gives you a better idea of the differences.
Regulatori is offline
Old 09-18-15, 02:38 PM
magomaev
I started with 46/17 about 4 month ago. Not i am up to 48/17. I would advise on 17t freewheel. I bought mine at Excess Components Pro Series freewheel | Retrogression I also have shimano and white industries. Excess in my opinion better than shimano. For only $20 plus shipping you can not go wrong. White industries better than all of them, but you looking at $80.
magomaev is offline
Old 09-18-15, 02:43 PM
johnnytheboy
johnnytheboy's Avatar
Quoted: 443 Post(s)
Liked 12 Times in 7 Posts
i love the fact when someome asks a question that's been asked before people berate them for not using the search function.
then whenever anyone replies to an old thread, they get called out on that, too!
johnnytheboy is offline
Old 09-18-15, 02:55 PM
prooftheory
Bikes: FTP
Quoted: 72 Post(s)
There is a big difference between appending a new question to an old thread and answering someone seven years later.
Old 09-18-15, 02:57 PM
Noli Timere
Quoted: 8 Post(s)
I told them that so they would know in case no one else replied to the thread. And I did not even do it in a dick-ish way. Any other complaints?
