Raleigh International Copper Paint Code
Old 12-05-10, 09:35 PM
ronp6
Bikes: Seven Cycles ID8 & steel Axiom; Bridgestones: MB-1, RB-T, XO-1, '85 Orange Gran Velo; electrics: Bionx, Swytch, Eflow Nitro; Merlin early MB; Raleigh Twenty & a lot of comings and goings
I just acquired a second 1974 Raleigh International and it at the tipping point of needing a repaint. Since both are champaign colored I was thinking of copper for a repaint but I don't have a copper to match for paint color. Does anyone have a paint code for the International's copper color? I appreciate your help.
ronp6 is offline
Old 12-08-10, 11:05 AM
ronp6
bump
ronp6 is offline
Old 12-08-10, 12:25 PM
sciencemonster
There's a Duplicore paint that seems pretty close - although I've never found it in a store to try it. Burnt Copper:
https://www.amazon.com/Duplicolor-Spe.../dp/B00099BJWU
I've tried mixing testors, but it's impossible. It's a tough color to match. The metal speck is what does it, I think.
https://www.tdpri.com/forum/tele-home...nge-build.html
sciencemonster is offline
Old 12-08-10, 01:56 PM
wahoonc
Membership Not Required
wahoonc's Avatar
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times in 14 Posts
I am not aware of ANY existing paint codes or formulations for Raleigh paint. I have taken a bike part into my local auto paint supplier and had them mix up a batch for me, IIRC I had to buy a quart, that is enough to paint 3 bikes with some left over. I have seen NOS Raleigh touch up paint in little glass jars, but after 35+ years I doubt it would be much good. I have gotten lucky with cheap nail polish from the dollar store and been able to use it for touch up paint.
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"
_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"
_krazygluon
wahoonc is offline
Old 12-08-10, 04:52 PM
ronp6
Mark, Thanks. It looks close to what I remember on the last one I had. I'll paint a sample board and hunt down an original. Ron
ronp6 is offline
Old 12-08-10, 07:31 PM
sciencemonster
Let me know how it turns out - I've got a spare copper International frame that needs some help.
Old 12-08-10, 10:30 PM
ronp6
sure thing
ronp6 is offline
Old 02-27-24, 02:45 PM
systemBuilder
Quoted: 22 Post(s)
Liked 13 Times in 9 Posts
I worked with Brian Baylis to repaint a 1974 Raleigh International in Copper color. Brian liked to use House of Kolor candy paints. The solution we both decided was the closest was the Orange/Copper paint (not sure about the code you'll have to look it up) over a GOLD primer coat. The GOLD primer coat is important to get that rich color. The SILVER primer coat resulted in a far-too-bright far-too-light orange color. If you get an orange paint make sure to test-spray it over both gold and silver to decide which ones looks best with the orange color you settle upon.
My frames were so sun-damaged that parts of them ranged from bright orange to burnt orange so just about any orange is a correct match for a 1974-76 Raleigh International after spending a the right amount of time in the sun!
I suspect we used "Tangerine" over GOLD base (primer) coat (see House of Kolor paint chips below). Incidentally, Brian also painted a bike Emerald Green and I suspect he used the "Organic Green" below (it's a 1970 color, also used on some mid-late 1970s grand prix bikes) - not Chartreuse which was used in 1971, 1972, 1973 - the latter chartreuse (a 50/50 green/yellow) I recently matched by "Alien II Green" from Kia Soul cars in a repaint by Ed Litton and I can show the color match there against an original frame if you are interested.)
The picture below is quite old and its taken in a dimly-lit room, and looks more red than it really is - it is far more orange in bright sunlight! Be aware that whomever was painting the bicycle that day @ Carlton could produce a dark rich orange or a light fluffy orange depending upon how much paint they sprayed - I have seen it at least twice on the 2 forks I owned from copper raleigh internationals. I restore only rescues and was extremely happy with this color from Brian Baylis !! The cross hairs indicate what part of the picture was used to white-balance this photo.
systemBuilder is offline
Likes For systemBuilder:
werwer2012
Bicycle Mechanics
13
02-07-14 09:39 AM
JimDeen831
Classic & Vintage
4
07-06-13 01:04 PM
markk900
Classic & Vintage
8
07-10-11 11:46 PM
ukny
Classic & Vintage
1
11-26-10 01:08 PM
tsappenfield
Classic & Vintage
0
12-29-09 06:50 PM
