Chainring Size on Crank Arms?
Hello,
I am fairly new to road cycling and I recently got a 2013 Cannondale Super Six Tiagra and I am getting the drivetrain changed out for an Ultegra.
When purchasing the Ultegra parts, it lets me pick the Chainring sizing? How do I pick the size?
" Choose from (170mm, 172.5mm and 175mm crank arms with 34/50 chainrings, 170, 172.5 or 175 with 39/53 chain rings or 170, 172.5 or 175 with 36/52 chain rings)"
And I know my crank arm is 172.5mm based on my height and inseam, but now I need to choose between 34/50, 39/53, 36/52.
Thanks for your help
Quoted: 2501 Post(s)
Liked 745 Times
There is no formula. You pick 'gearing', you do not pick chainrings. 50/34 is nearly meaningless unless we also know the range of the cassette that you plan to use with it. In theory using smaller chainriings up front means using smaller cogs in the rear. The resulting gears are the same ones as if you used bigger rings up front and bigger cogs in the rear. The bigger cogs and chainrings apparently are somewhat more efficient and longer wearing, even if they are somewhat heavier. What are the gears on the bike you presently ride?
H
H
H
H
Thank you for your response. I am not really sure what I use. I think I use the larger cog. Is there a general chainring size? I have been fine with whatever size that has been on my Cannondale CAAD8 54cm.
Thanks,
Alan
Liked 745 Times
Frame:
CAAD8, Optimized 6061 Alloy, SAVE
Fork:
Cannondale Ultra, carbon blades, 1-1/8 inch
Gears:
Shimano 2300 front and rear mech and shifters and compact crank with 50x34 tooth chainrings, SunRace 12-25, 8-speed cassette, 16 gears
The gears are the interesting bit. Ideally you don't use a gear, you use the entire range available. You asked about a "standard" gearing. For decades, a 52/42 chainring double with a 14-28 5sp freewheel was the standard default gearing of every bicycle sold in America. Even in 2014 a big ring of 52 (sometimes 53) teeth is "standard". The 42 tooth has become a 39 as front dérailleurs have gotten better. The 5sp became 6,7,8...10,11,??. For all practical purposes, the 52(3)/39 x 12-25/7 9sp is about as close to a standard gearing as anything in the 21st Century. But your bike is adopting a 'newer' standard. The 50/34 "compact double" aims to save weight and provide 'crisper' shifting over "standard" gearing. How did that work for you? Lots of people cruise in the big ring close to the middle of the rear cluster and others (me) cruise in the smaller ring close to the middle of the cluster. I'm guessing you're young. Enjoy it.
H
These are some specs I pulled off a review of CAAD8, Cannondale's own site is not working for some reason. In 2013 at least, CAAD8's came like this:
Frame:
Fork:
Gears:
H
Frame:
Fork:
Gears:
H
Yea, I enjoyed it. I don't really have much to compare to, but I guess the 50x34 is good for getting me up some hills. I live in virginia and it can be quite hilly. Are you basically saying that 50/34 is becoming the newer standard? I was thinking of going 36/52, as a compromise.
Thanks,
Alan
Liked 745 Times
Hello Leisesturm,
Thanks,
Alan
Thanks,
Alan
H
I meant enjoy your youth. And you are still missing my point about the gearing: 50/34 doesn't get you up hills any easier than 52/39, its what's in back that counts. The teeth in the rear are far more important than the teeth up front. What cassette do you intend to use in back? 52/36 might not shift properly with a standard front derrailleur. If you have a 12-25 now and the hills bother you, you could go to a 12-27. If you bump the big ring up to a 52 you might need to raise the 12 to a 13 or you might find that the 52x12 doesn't get enough use to be worth the weight. Look at some bikes online and see what gears they come with. Copy one. You can always change later.
H
H
I appreciate your help!
The back counts too, but given the same rear cluster, a 34 is going to be a large step lower than a 39. And there are limits to how big you can go on the back without changing out to a MTB derailleur. If one is a sub 155 pound lightweight racer, 39 may well be small enough to get up practically anything. Bigger people in less good shape better go for the compact 34, unless they live somewhere totally flat IMO. Even pros are often using compacts these days in mountain stages.
count teeth the number of teeth is what you use in math to get how big the combined number makes your drive ratio
say front is 50t, and rear is 20t ,then 1 crank rotation, turns the rear wheel 2.5 times..
aquateen
11
03-13-14 01:53 PM
thenomad
13
06-07-10 09:49 PM
