Tandem Flatbar/SRAM Conversion Question
Bikes: Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 79 Post(s)
Liked 37 Times
I am glad the o.p. finally decided to ask about the ergonomics of replacing the front shifter independently. I for one simply would not be able to abide even the mild difference in dimensions/throw/etc. that might result from simply sourcing any 3x front trigger that might be available other than the one expressly designed to work with the rear shifter of my choice. But we are all losing sight of the prize because all this talk of trigger shifters implies a change of fork and much more and I am just not sure that this is the way to go. The o.p. talked about a custom (steel) fork which is still going to have to match the 1.25" construction of the present carbon fork. I can only imagine that that fork is going to cost more than the entire 2024 value of the present tandem. The exaggeration (if) is only slight. Someone on planet Earth is capable of fabricating a carbon stem raiser in a 1.25" inch format so the o.p. can use their existing controls. The cost should not exceed the contemplated mods. Finding that fabricator would be my priority. Or finding a good Physical Therapist as an alternative. There is also the option of sourcing a tandem already built with an elevated cockpit for the Captain. I've seen these at Tandem Rallies. They must wind up on the classifieds market with some frequency.
The present value of the older tandem doesn't really work. The proper analysis is what it will cost to obtain/modify a tandem that fits both of us. I explored a new tandem (off the shelf and custom) and decided against it, primarily because as we age, changes will need to be made, so a new tandem isn't a long term solution.
The idea of using a Physical Therapist after every ride is somewhat amusing, but not practical.
Likes For PromptCritical:
