Tubs vs. Cinchers- ride/suppleness
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Discussion in another thread got me wondering… convenience, puncture resistance, weight/cost aside, anyone care to quantify-ish the differences in suppleness/ride? Aging joints & other issues (including terrible local road conditions- surface though, not necessarily broken glass/debris/thorns) demand a cushy ride for me. I’ve got a couple 650b conversions with 42c tires that are pretty great. But I’ve also got a racy frame with fairly tight clearances I’d like to build up and ride too. I’ve never ridden tubs before, but I’m curious. I’ve heard much about the ‘amazing ride quality’ of tubulars and I’m wondering if (all else being theoretically equal) what a width equivalent might be? Like, say, would a 28c tub at, say 80psi have the ‘plushiness’ of a 32c at 60psi (I’m kinda just arbitrarily pulling these #s..)? Basically wondering if going with tubs on a bike would let me get away with narrower tires, ride/comfort wise? (Plus give me yet another cycling thing to obsess, er, I mean experiment & learn about…)
Likes For ehcoplex:
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
This is entirely subjective, but my experience is that tubular tires provide a level of comfort similar to what a much wider clincher tire would give.
Likes For JohnDThompson:
Wrench Savant
I prefer riding tubulars.
I prefer maintaining clinchers.
I have tubulars on my racey and CX bikes. Everything else is clinchers.
Likes For balindamood:
Quoted: 4806 Post(s)
Liked 3,932 Times
The difference between clinchers and tubs is hard to quantify or put numbers on. And substantially bigger clinchers at lower pressure will feel "plushier". But for a restricted width, tubulars help a lot. And at lower pressures they are very forgiving. Pinch flatting, while it happens, doesn't always happen even when you hit the rim hard. (I put substantial dents in both rims in a 4 hour race that started 2 hours late when I pumped my tires to the minimum to not have a jarring ride over the 12 miles of poor road very late in that race. Latex tubed silk tires. Bike felt right-on perfect the whole race. Never thought once about the wheels. But I hit hard when I crossed the classic New England railroad tracks 1/3 mile before the finish! No flats and it didn't cost me a second in my race. The two additional hours before the race? Race official missed his flight and had to drive.)
And super low pressures can be ridden just fine if you don't care about the rims. I used to run CX tires in winter and just adjust pressure for traction needed. Ice? Almost nothing. True, rims were random polygons by spring but the tires didn't care. Low pressure tubs also never pull the tubeless stunt of burbing. You do however have to glue them better. (CX racers have to adhere to gluing standards we roadies don't have to sweat. But, do take gluing seriously. It hurts us a lot more when they peel off!)
For plush, tire quality mattters a lot, especially as you get to the narrower ones. I started back on tubulars last summer and had a hard time finding good tires below 25c that worked in my early '80s race bike. Put cheap Conti Giros, 21c on, mistakenly on very light, high quality rims. Enough pressure to feel good about the rims = too hard for comfort and lousy handling. I raced lighter rims and tires the same size back then. Same pressure. They were wonderful. Yes, real for road feedback but not abusive and handling was A1 sweet. My other bike has 28c Vittoria G+ tires that are that old sweet only they are plush! Maybe not quite 32c best clincher at lower pressure plush but a much nicer ride!
Splurge on the tubulars. But man up and buy really good ones. The comfort difference is real. And run strong rims so you can drop pressure if needed. The old shallow rims were also more comfortable. Lace 'em with light double butted spokes and more comfortable still. (Yeah, I know. There are experts here who will laugh me out of the bar.) I put 17,000 miles on Mavic GP4s laced with 15-17 spokes. Retired them only because the sidewalls were completely worn out. Like read newsprint through them gone. Rear collapsed bunny hopping a pothole. Bumped 8 miles home. Tire didn't care.
Edit: and as always, the real gift of tubulars - when you flat, at any speed, nothing happens. You just brake (you can use both wheels), stop, change or slime the tire and go on. Tire doesn't come off (with the usual caveat - did you glue it properly?). You are riding on rubber or at least fabric and rubber the whole time, not aluminum of carbon fiber. Nothing jams in forks or stays. Actually, even boring. I've done it at 45+. NBD. In fact, so NBS I do not remember where I did it, if I did it more than once or which wheel it was. Now, the one time I had a rear clincher come off at 25 mph, that was an incident I will NEVER forget!
Likes For 79pmooney:
There is a lot of confusion as to why tubulars are superior to clinchers (tubeless or otherwise). And make no mistake - that tubulars are superior for every application from road to 'cross to track to MTB. Yes, tubular MTB tires are used at the elite competition levels of the sport, or at least on those teams that have good sponsors.
Look at the cross section of a tubular rim vs. clincher. Observe the two 'hooks' at the bottom of the clincher rim - which are required to hold the clincher tire on. These are fragile, heavy (at the worst place for mass on a bike) and are sharp and cause pinch flats. Tubular rims eliminate the need for the 'hooks' so all things being equal, the tubular rim is lighter, stronger and doesn't cause pinch flats. The tire is glued onto the rim with a few grams of high-strength glue.
There should be no difference between the 'ride quality' between a tubular and clincher tire, provided the tire construction and materials are basically the same. A minor difference is that tubular tires tend to feel a little larger than equivalently-sized clinchers. See the dead-space between the rim tracks on clinchers? The purpose of an inflated tire is to cushion the rider and protect the rim. The clincher 'dead space', or roughly 10% of the inflated tire volume does nothing in this respect.
So the main benefit to tubulars is the rim - not the tire, or the 'feel' whatever that is. All things being equal (materials, construction and strength) a tubular rim should be at least 100g per pair lighter than a clincher rim.
Another key tubular advantage: safety. This has been beat to death here. Have a sudden high-speed flat on a tubular?:.... manageable and controllable as the flat tire stays tight on the rim. The same flat on a clincher? Life threatening scary. If for no other reason, this is why I would ride tubulars.
Likes For Dave Mayer:
Quoted: 1248 Post(s)
Liked 1,323 Times
Something does not add up here.
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times
I had never ridden tubulars until a few years ago and, like you, was curious. I read Totally Tubular thread from beginning to end and gave it a try. I've converted all my bikes (except a bike friday) to tubulars which, I guess means, I like them a lot. My personal feeling about comfort is a clincher has to be at least 5mm wider to even compare in plushiness and even then, it is not the same. I'm 170lbs and ride 28mm tubulars at 55-60 psi front and rear around 65-72 (I don't pump every day). I can ride 33mm tubulars at lower pressure (35-45ish) than 38mm RH Steilacooms AND get a better ride, or so I've convinced myself.
Quoted: 1143 Post(s)
Liked 1,753 Times
Clincher setups can feel heavy, I feel like a rocket on tubulars. However bad roads with plenty of glass just kills the good tires, and bangs up the rims.
I do like the mavic open Pro rims with Vitoria folding tires.
Likes For Mr. 66:
Quoted: 761 Post(s)
Liked 1,563 Times
I'm starting to see a set of tubular wheels in my future... The original reason for inquiring is I've got an old Holdsworth Professional I'm building up now. I can just squeeze 700x35c tires into it, but it's pretty close. In my recent experience, with all the wonderful 'gifts' of aging (& crappy roads) I feel like 35c is about the narrowest I can be comfortable on, at least with clinchers. The Holdsworth will be my 'go-fast(ish)-on-the-slightly-less-crappy-local-roads-on-nice-days' bike, so if I could get a really nice ride on tubulars (& even lose a little weight, too), why not give 'em a try?
Strong Walker
When I first rode (good) tubulars, I went of the bike after a couple of seconds because it felt like I had a flat - so supple was the ride. I grew up with Hutchinson 18mm and 20mm Conti GP mind you.
a very good clincher with a latex inner tube comes close, but for me and you may call me an old fart nothing comes close to the ride experience on Veloflex Competition. I tried Dugast Seta, couldn't find an improvement but the replacement was double the money...
Likes For martl:
Liked 1,323 Times
Subjective, of course, but this is what I was looking for!
Likes For Atlas Shrugged:
Quoted: 761 Post(s)
Liked 1,563 Times
Point taken, though there are many who would say that about C&V bikes on the whole!
This may end up just being a mental exercise anyway, as I'm already half way through building up a set of clincher wheels for the Holdsworth build. And I thought Rene Herse tires were $$$, but a quick search of good tubs indicates they're definitely no cheaper! Still, I'm curious, so I'll be keeping my eye out for a reasonable tubular wheelset nearby...
Quoted: 192 Post(s)
Liked 566 Times
Compared to a clincher of the same width, a QUALITY tubular will be more supple, handle better, be far more resistant to pinch flats, be far safer in the event of a flat at speed, and have lower rolling resistance ( no matter what the various tests show). I have no idea about tubeless. It always astounds me about the people who consider tubulars to be “ too much trouble” but gladly go through the satanic rituals required to set up and maintain a tubeless setup…..then there is the tubeless roadside repair kit, also known as a cell phone. Tubular tires exist despite the marketing might of an entire industry for one reason; there are performance advantages that they offer that are not equaled by any other setup. If you are tempted to try them, by all means do so and experience them first hand….just go all the way with quality tires and wheels as the cheap versions lose all of the advantages.
Likes For El Chaba:
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 462 Times
Yes on Veloflex
Veloflex uses latex tubes, which makes for an exceptional ride.
Made in Italy and reminds me of my old Clement Criteriums from the seventies.
Tubs cost, over the course of usage, likely twice as much as clinchers, but we are so worth it, aren't we?
Likes For roadcrankr:
Liked 1,323 Times
You have no idea about tubeless.
Glueing tubulars is not a time wasting PITA?
How do you repair your tubular on the side of the road, with a sewing kit?
Who is behind this big bike conspiracy against the superior tubular tire?
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 922 Times
The by-now knee-jerk, automatic rejection of tubulars is based on out-of-date information. No more glue (well, maybe if you race cyclo-cross). Tape is as fast as tubed clincher mounting. Not to mention that removable valve cores allow for sealant, which will take care of most punctures. Sealant is a lot less messy when there is an inner tube to contain it!
I'm surprised by some of the negativity shown tubulars in this C&V forum thread, actually. I think riding sew-ups is a bit like playing vinyl records. We may be less than 1% of music listeners, but we're sure having fun!
Likes For Fredo76:
Liked 3,932 Times
Just ignore all the tests that show they are slower because I say so.
Gluing isn't hard to do and doesn't take very long beyond waiting time when I simply do something else.
One of the reasons I commuted exclusively on tubulars for 25 years was that I could do 5 minute tire changes guarantee, not just on a good day. And I never re-flatted from the whatever I failed to remove. (I loved that I could do the change in the same time in the rain, snow and dark. Nothing that I had to get right. A completely lopsided mount would get me out of a shady neighborhood and home just fine. I could run over an open knife and that wouldn't affect the change time or its reliability. (Again, tubeless nooby - is that true with tubeless?)
No comment.
Quoted: 761 Post(s)
Liked 1,563 Times
Quoted: 2588 Post(s)
Liked 4,824 Times
If the true point of this thread is to discuss differences/sameness in ride/suppleness, my personal experience is that top range open tubulars/clinchers, blown to high pressures (like 130psi), feel and perform almost exactly like my hard-blown (140psi) tubular setup. The only real difference I can detect is that the tubulars seem to squish/rebound more noticeably when compared to the open tubular/clinchers. Most people would probably say that's a good thing, but not in my book; I like a planted rear end, and any pogo-like movement of the rear tire (not wheel, mind you) simply sucks away cornering confidence. It's just one reason I like high pressures; another benefit is less pinch flats.
Full disclosure: the clinchers I favor are 320tpi Vittoria Open Corsa Evo SC or CXs. Tubulars are currently Vittoria Corsa Control G 2.0s. The clinchers are generally 23s and the tubulars are 25s.
DD
DD
Likes For Drillium Dude:
I've never gotten a pinch flat with any of my clincher tires.
I got all sorts of flats with tubular tires.
As soon as good quality clincher tires became available, I dropped the tubulars like a hot rock.
Every time I think about trying tubulars, I remember how piss poor they were. They were relatively easy to swap tires if you got a flat, but what if you get two. Repairing tubulars is not difficult but it does take care and a lot of time. Especially so for the re-stitching of the casing to ensure it does not bulge in or out.
OP: tubulars, on bad road conditions? Uh,... no thanks.
Buy yourself a set of GREAT clinchers from Challenge or Rene Herse or whomever. You'll be a LOT happier overall.
Likes For Bad Lag:
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
The "all else being theoretically equal" part of this can be pretty elusive, but I've got a reasonably close estimate for you.
Here's my De Rosa with tubulars -- 700x28 Vittoria Corsa G's on Campagnolo Epsilon rims:
I don't have any pictures, so maybe this didn't happen, but I've got another set of wheels with 700x28 Vittoria Corsa G clinchers on H Plus Son TB14 rims that I've used with that same bike. Both wheelsets have Campy Record hubs. The only differences are the rims and the tubulars versus clinchers from the same manufacturers with the same tread compound and size. Honestly, I really don't think I could tell the difference between these two set ups. The clincher rims are considerably heavier, and maybe I could feel that. I'm not disputing how wonderful the tubulars are. I'm just saying that a really high quality clincher like the Corsa G is also wonderful.
I have a theory that part of the reputation tubulars has comes from the fact that historically most clinchers were kind of crap and most tubulars were pretty good. I could be wrong.
You can also run tubulars at lower pressure without fear of pinch flatting. That's a really big deal in cyclocross where low pressure gets you a lot of extra traction. On the road, it's much less of a win.
My Bikes
My Bikes
Likes For Andy_K:
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...I have probably ten sets of tubular rim wheels that are sitting over in a corner, under a tarp. Every now and then, if I need a set of really nice hubs to build wheels for a project, I cut the spokes out of one, and use the hubs. I have ridden tubular tires in the past, and there was certainly a time when it was difficult to get clincher rims and tires that came anywhere close in performance. But that was many years ago.
The advantages of both modern box section rims and advanced high pressure tire technology in the clincher design convinced me to switch over some years back. I would rather be beaten with a softball bat than deal with tubular tires again. But that's just me. I understand that with the advent of modern sealants, tubular tires are much more easily maintained. But I'm probably not going to try that, because I have reasonable ride quality with the clincher rims and tires I use now. I'm certainly not a racer, so that's not an issue for me. I'm just in it for the outdoor exercise and watching the miles go past.
Also. maybe I'm riding on better roads than you describe.
Likes For 3alarmer:
Bikes: Two Peter Mooney customs, a 1980 Trek 510 townie, a Marin Stelvio set up for TTs.
Quoted: 228 Post(s)
Liked 294 Times
The thing not adding up is your recollection. I have in my current possession a pair of Shamals, and they most definitely have deep sew-up rims.
Quoted: 346 Post(s)
Liked 175 Times
OP is curious. Obviously some like and some don't. Only way for OP to find out which camp he is in is to try. What's the harm?
Likes For L134:
