A question on spoke tension
Old 10-16-23, 11:59 AM
robow
robow's Avatar
Quoted: 598 Post(s)
Liked 283 Times in 194 Posts
A friend recently obtained this bike and rebuilt a taco-ed rear wheel but wants me to true it. What spoke tension should I be looking at, drive and non drive side according to my Park Tool spoke tensionometer. As always, thank you for your input.
robow is offline
Old 10-16-23, 01:18 PM
cb400bill
Forum Moderator
cb400bill's Avatar
Quoted: 3091 Post(s)
Liked 6,601 Times in 3,785 Posts
Thread moved from Appraisals to Mechanics.
cb400bill is offline
Old 10-16-23, 01:34 PM
Kontact
Kontact's Avatar
Quoted: 4412 Post(s)
Liked 1,566 Times in 1,028 Posts
Your tensiometer has a guide card. Use the lower end of the tension range for the spoke diameter you're using.
Or just make them reasonably tight and even in tone when plucked. This is not the kind of wheel where the tension is critical
Kontact is offline
Old 10-16-23, 01:59 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,932 Times in 2,557 Posts
Was the rim bent with the taco? If so, was it bent back? If you have to true a bent rim to be straight, throw the book on spoke tension out the window. You are now just trying to salvage a botched birthday cake that fell in the open. (And that truing job will not be permanent if the bike is actually ridden much.)
At the shop I worked in mid-70s, we had a mechanic who was a master at slamming wheels to remove bends. He'd study the wheel. loosen the spokes around the bend, the slam the wheel on a concrete step. Re-tighten. a little final truing and 4 hours later hand the wheel back to the customer. (Four hours so there was zero chance of the customer seeing the process!) Mechanic fully "got" that a bent wheel had to be bent back to have any chance of being a "happy" wheel later. And bending steel and aluminum isn't a pretty process. Wheels were never perfect after the second bend. The metal would work harden at the beginning and end of the damaged area and resist the bend back. So they would never be "gems" but many went miles and years after the "treatment".
Caution - this approach worked really well for steel and 1970s aluminum rims. In the '80s, aluminum changed to a much stronger but far less forgiving of bends alloy. I only do this on the old stuff.
79pmooney is offline
Likes For 79pmooney:
Old 10-16-23, 03:11 PM
FBinNY
Quoted: 5793 Post(s)
Liked 2,585 Times in 1,433 Posts
The RANGE of proper tension is a function of spoke gauge. Assuming these are 16g spokes, that would be anywhere from 60-110kgf.
I'd shoot for mid-range, or 80-90kgf both front and rear. If you want to be fancy, go 70 in front and 90 rear.
FB
Chain-L site
FBinNY is offline
Likes For FBinNY:
Old 10-16-23, 03:13 PM
Kontact
Kontact's Avatar
The rim was replaced.
Kontact is offline
Old 10-16-23, 04:41 PM
mpetry912
aged to perfection
mpetry912's Avatar
Quoted: 839 Post(s)
Liked 1,258 Times in 663 Posts
I'm with FBinNY 65-80 kGf or until a nice uniform "**ping**" is acheived.
/markp
mpetry912 is offline
Old 10-16-23, 05:23 PM
robow
robow's Avatar
Quoted: 598 Post(s)
The spokes are 14 gauge, 2mm. I asked the owner to bring me the front wheel for comparison and those spokes don't even register 0 on the Park Tensionoometer, Ha. Loose as a goose. I'm getting it trued up but the replacement old used beat up rim is a real treat to work on....not.
robow is offline
Old 10-16-23, 06:35 PM
Shimagnolo
Shimagnolo's Avatar
Quoted: 3376 Post(s)
Liked 5,523 Times in 2,863 Posts
/markp
Give me a ping, Vasili. One ping only, please.
Shimagnolo is offline
Likes For Shimagnolo:
Old 10-17-23, 11:13 AM
urbanknight
Over the hill
urbanknight's Avatar
Quoted: 998 Post(s)
Liked 1,206 Times in 692 Posts
Assuming the rim is the same type (single wall?), I'd aim for about 90 for the high range.
It's like riding a bicycle
urbanknight is offline
Old 10-17-23, 11:56 AM
wheelreason
Quoted: 504 Post(s)
Liked 634 Times in 374 Posts
Ya'll just made my day, I'm about to show everyone in the shop...
wheelreason is offline
