Post your MiniVelo thread!!!
#51
55+ Club,...
Bikes: 9+,...
Quoted: 1115 Post(s)
Liked 849 Times
I'm actually on the fence about it. I MIGHT go against what I said and go 3 speed, but currently it's slated to be a SS.
#52
55+ Club,...
Bikes: 9+,...
Liked 849 Times
The seller couldn't ship for the agreed $60, or even the full S&H of $180. The order, with my blessing, was cancelled.
Oh well, no Origin8 Bully.
#53
55+ Club,...
Bikes: 9+,...
Liked 849 Times
Yup! And the seller promised shipping he couldn't get. I could have refused the cancellation and made him eat the cost, but I'm not that kind of person. I'll wait until I see another Origin8 Bully, or hopefully someone in the forums offers to sell me one. I really want one,... Sooner or later.
#55
Thread Killer
Quoted: 3147 Post(s)
Liked 1,712 Times
#56
Bikes: Fuji Comp 29r, Downtube, Tommi Sea fat bike, Nashbar SS 29r half-fat, Full suspension mini-velo/MTB, Loopwheel M-Velo
Mine. Loopwheels suspension wheels, SA 3spd IGH, hub brakes on both ends.
#58
#59
55+ Club,...
Bikes: 9+,...
Liked 849 Times
I'm 5'11. Are you over 6' tall? I thought it was supposed to fit the adult rider.
#60
No, I'm 5'11" as well. But thugpipe gave me some tips about his Bully, and from the sounds of it and the geometry, it's probably a "medium" sized bike at best. It would probably fit me if I tried, but given that there's no way to actually try out the bike in advance, I figured I'd pass on this one.
#62
Bikes: 2011 Origin 8 Bully, 2010 Dahon Silvertip, 2016 Respect Mini Velo
Quoted: 20 Post(s)
I just gave out the original J&B importers product page links to Ozonation. There is only one size frame for the bully.
https://www.jbimporters.com/web/links/69193%20Bully.pdf
https://www.jbimporters.com/web/check...t_number=69193
#63
55+ Club,...
Bikes: 9+,...
Liked 849 Times
I guess, after all my wishful thinking & attempted purchases of a Bully, I should be grateful I didn't get one. My Lombardo Power2000 shall suffice then,... Thanks for the legwork fellas!
#68
55+ Club,...
Bikes: 9+,...
Liked 849 Times
@smallwheeler - do you own it? Looks funky,...
#69
Quoted: 151 Post(s)
Liked 10 Times
from what i was able to gather, the maker was either gazelle, peugeot, or a sub of raleigh (phillips). not terribly important really. good chance it was made in 1966 based on the original wheelset that came equipped with an SA 3 speed dated 66. deciding who the maker was may be down to which head badge looks the coolest. (actually i'll probably design my own badge..)
the black bracket you see under the 3 speed shifter is stem clamp. it adds a significant amount of rigidity to the long nitto technomic stem.
i also have the original fenders and rear rack. i had the whole thing media blasted and powder coasted black with a diamond clear™© coat added. the wheelbase is 950mm. effective toptube is 520mm.
i toyed with the idea of having a top tube added. but, ultimately, couldn't make up my mind which was probably for the best anyway. the bike is very stable as is. adding the brompton front mounting block is still likely, though.
the wheelset is comprised of a 349mm recumbent front wheel from a p38 lightning and the rear is a brompton wide range hub with 15t and 12t cogs. i considered adding a derailleur, but found that i liked the current set-up. manually switching takes less than 5 minutes. ideally, i should remove a chain link to switch to the 12t. there is some slack in the chain as the dropout isn't quite deep enough the take up the slack. the bike is fast and very responsive without much flex (surprisingly). that may have something to do with the massive lugs. the overall weight without the fenders and extras is approx 7.5kg(16.5lbs).
having a wide range 3 speed takes some getting used to, but i learned pretty quickly to love it. you wouldn't use it to cycle through gears the way you would normally with a 3 speed. it's basically a steep hill gear, a cruising gear, and a speed gear. big steps between gears.
instead of modifying this bike any further, i'm working on building a new one. fanciful i know. but... we'll see.
#70
55+ Club,...
Bikes: 9+,...
Liked 849 Times
@smallwheeler - fantastic! # 4 made me drool though, since it reminds me of the Origin8 Bully a little.
#72
Bikes: Raleigh Folder
That's what I'm thinking. Looks like the RSW Shopper. Frigging beautiful, I'd love to find a non-folder like that.
#73
My raleigh shopper
Latest purchase from work, donated to the charity where I work at a bike recyclers, we have lots just sitting collecting dust and I saw this ones potential, paid £15 bought as seen and had it delivered to me same night, started to strip away parts and wire wool the chrome to remove pitting which comes of no problem revealing a very nice bike underneath, just years of grime and dust to clean off it and its almost good as new, will probably sell it to make a profit then once I have done a few I may have enough for another moulton but something nice and modern, just awaiting delivery of my old moulton as a starting project.
