New freewheel loud knocking noise?
So I brought my vintage 80s de visini with camps trimomphe group set to the LBS to replace the chain ans the old regina 5bx 5 speed 14-22T freewheel a new Sunrace 6 speed 14-28T freewheel.
Once I picked up and rode the bike it made a very loud knocking type of sound, once every revelation on every gear when the crank was at around 2 o clock. LBS confirmed this and tried replacing to another brand new Sunrace 6 speed 14-28T. This one made the bike have the same sound so LBS mounted the original freewheel and the sound was gone...
According to LBS both the sunrace freewheela have manufacturing defects (seems a bit unlikely both do?).
So what to do? The bike has 127mm measured dropouts and the Trimomphe derailleur should be able to handle 14-28T 6 speed back and 52/42T front chainrings. I'm tempted to bring them a new shimano MF-TZ500 6 speed 14-28T freewheel but I dont know...
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,485 Times
New Sunrace freewheels do not make "loud knocking" noises. Sounds like a fairly simple issue that deserves greater attention than this particular bike shop can handle. Why not try to understand the issue yourself? The bicycle is a very simple machine, but it takes time and patience, things that maybe this bike shop doesn't have readily available.
Quoted: 360 Post(s)
Liked 328 Times
I have a 14-28 freewheel that I bought new in the last two or three years. I think it was a Sun Race but I am not sure. It had a loud knock in it as well. I took it off and it now serves as a paperweight in my home office. I replaced it with a vintage Sun Tour something or other (New Winner?) and the knock went away. My conclusion was the same as your bike shop's-Bad freewheel.
Andy
Andy
Quoted: 4722 Post(s)
Liked 3,036 Times
That ounds like a crankset issue, given that it makes it at the same point of every crank revolution.
Likes For T-Mar:
It's been a few years since I've used one, but in my experience, they do. Or at least the 6-speed 14-28 ones that I use do. It's a consequence of a sloppy bearing assembly. Wear can lead to squeals developing alongside the knocking within a few hundred miles.
This has been an issue with every single Sunrace freewheel I've used.
This is why I generally stick to Shimano freewheels, despite their ugly big cogs.
Quoted: 1829 Post(s)
Liked 3,376 Times
I've had SunTour freewheels where the bearing cone loosened. This resulted in the outer body pivoting on the pawls, depending on which cog the chain was on. This resulted in a "thunk" twice per wheel revolution, and this "thunk" was a warning that the cone was about to completely unthread and let all of those 1/8" bearings escape to the street and never be seen again. Once the bearings were gone, the freewheel would no longer function and you would be a pedestrian once again.
Not a good thing.
In the OP's case, as noted, a noise that happens once per crank revolution is unlikely to be a freewheel problem. It could be a bearing problem, or the front derailleur smacking into the crank arm, or a multitude of other causes.
Steve in Peoria
Not a good thing.
Steve in Peoria
Likes For steelbikeguy:
To clarify and answer all the above:
- Knocking sound not present when switching back to the old Regina BX freewheel - should rule out crank issue
- Bearing problem should be present when using the old Regina BX freewheel but it is not
- With the two Sunrace freewheels it makes the same sound when holding the rear wheel firm and pushing the crank with your hands a few mm forward when crank is in around 2 o clock position, this does not happen with the Regina BX freewheel
- We ruled out the front derailleur smashing into the crank when I was at the store, also the sound seems to happen when crank is not in a position to touch the front derailleur
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 984 Post(s)
Liked 635 Times
Another data point -- I have an IRD freewheel making such a noise, but probably not as loud. Hmm, when I coast or at least let up for a tiny fraction of a second, which implies the pawls then engaging a different part of the freewheel... it goes away, until the next time I coast (or maybe not, it's like Russian Roulette). I've developed the technique of a slight "stutter" in my pedaling when I encounter it. Too cheap to discard freewheel, and good luck trying to convince the manufacturer it's defective.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
señor miembro
Liked 6,485 Times
Likes For SurferRosa:
señor miembro
Liked 6,485 Times
Quoted: 1088 Post(s)
Liked 1,205 Times
Well I dont have neither time, tools or patiance, Im glad if I can get a few hours of spare time to actually ride the bike during weekends.
Likes For noobinsf:
Well, it looks like you participated in the diagnostic phase, so if you're satisfied and you trust the shop, there's no harm in putting the Shimano on if you need the larger rear cogs. Like SurferRosa, my only experience with Sunrace freewheels is with a pair of 7-speed units, and these have been fine for me. Shimano may be ugly, but they're reliable in my experience.
señor miembro
Liked 6,485 Times
https://www.ebay.com/itm/294988240793?hash=item44aeab5799:gvwAAOSwpQpigyck
The 6-speed units like that are more difficult to find. You have to look up the model number on the Sunrace site, and then search the web for that.
Quoted: 767 Post(s)
Liked 1,898 Times
Guys, defects do get through in mass production. I had a knocking Sunrace freewheel here a while back. Brand new.
I contacted Sunrace, and the rep asked for a short video of the issue. I provided, and he sent me a new freewheel right away, no more questions asked.
What did I find when I opened the freewheel? Two different size pawls, one silver and the other black. The main body looked like it was made on equipment that was long past it's useful life, just very, very rough. Lots of slop all around.
I have other Sunrace freewheels that have been fine.
If the issue is your freewheel, Sunrace will likely replace it.
Likes For BFisher:
Quoted: 1639 Post(s)
Liked 829 Times
Had an NOS Regina FW that knocked on me too.
Turned out to be a defect with the FW body the outer body was hitting the inner one at a certain point of its revolution. It was easy. Basically, a high spot where the two halves were rubbing.
I just knocked down the area with a grinding stone bit on my Dremel Drescher knocking was eliminated.
It's a relatively easy fix, as long as you are able to break open the FW with the right tools.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Just brought the lbs a new MF-TZ500 6 speed 14-28T freewheel since they didnt stock these, lets see if this ine works better.
Just too bad its ugly as hell...
Quoted: 1608 Post(s)
Liked 2,216 Times
Not intending to be judgmental but if the freewheel is/was the problem, how can the sound be always at the 2:00 position of the crank? We are talking changing gear ratios! does the sound only occur on only one sprocket and one chain ring?
Does the freewheel "wobbulate" when the wheel spins (typical)? Conceivably, the chain could be displaced during one revolution of the freewheel causing the chain to rub on the FD when on the largest sprocket.
Are the pins on the chain properly inserted where the chain was "broken?" Recently I was hearing a ticking sound once every revolution of the chain. The master link was for an 8-speed chain but mounted on the 9-speed chain. The link was wider and would hit the FD in the right configuration.
Liked 3,036 Times
Personally, I don't think they are ugly. Regardless, you'll almost certainly forget the aesthetics, once you experience the quantum leap in shidting performance over the old Regina.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
As one who loves installing certain of the SunRace chromed freewheels (7-speed for me), I have seen a couple of problems turn up on a few of the perhaps ~30 of them that I have installed.
The "tick tok" knocking is the most-common problem in my experience, always fixable by tightening the bearing adjustment (removing the locking cone, sanding down it's back-side seating surface, cleaning the threads and re-installing with Loctite).
[[[[[[[[[The cog-retaining ring needs to be removed first, so one needs to fashion a removal tool using 1/4" flat steel stock for twisting it off and then back on again. I used the handle of one of my older chain whips for this purpose, a few minute's time tuning up the width dimension of the end of it using a bench grinder and file.]]]]]]]]]
Removing metal from the locking cone is irreversible, so if you go too far with the sanding, the freewheel becomes a paperweight since the needed shims are not usually available, other than by cannibalizing another (perhaps worn or rusted) SunRace freewheel.
The freewheels were fine after my readjustments.
I also had a couple of SunRace freewheels come in that were from a batch where the factory over-packed the body with grease. These freewheels would not turn freely enough to use, and removing the excess grease required soaking the freewheels and giving them a spin each day for a week, with lots of time wasted. Thankfully this was a little over ten years ago!
The 13-25t and 13-28t, 7s chromed models are the cat's meow for performance riding around here using indexed levers!
Likes For dddd:
Not sure if the freewheel was wobbulating. Didn't look like the chain was rubbing FD though.
Regarding the chain, I would very much belive it was properly inserted since the poor guys had to switch freewheel like 6 times haha.
Brought the bike back from the lbs today with the cheap and ugly shimano freewheel. Knocking sound is gone, the shimano freewheel is a lot quite (the sunrace one was IMO way to loud) and it shifts so smooth and quietly together with the new Izumi chain. Wax also flying by all the commuters who were struggling uphill on the big hill back home
Likes For curiousabe:
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,195 Times
I've also have had great experiences with Sunrace customer service. Glad that curiousabe had a great final outcome.
Bob
Bob
Slowfoot
dddd, this fix worked great for me! I have a new Sunrace 5 speed that clicked and had a bit of play. I left the freewheel on the wheel and removed the lockring (removal is CW). Mine had 2 indents for a pin spanner but very tight so I used a punch and hammer to loosen and then the green Park spanner tool. I sanded the backside of the lockring (which is also the bearing race) on 3M Wetordry 220 with oil for about 30 seconds and tightened it up. Play was gone and so was the click. I noticed a shim in there - it was just a bit too thick. I sanded in 10 second sessions with test fittings in between. Great post, thanks!
Likes For dmarkun:
Quoted: 4512 Post(s)
Liked 6,384 Times
@curiousabe, @T-Mar, and all,
Fully agree on the fugly Shimano Mega billboards.
You have to lean in a bit but well worth it.
5 minutes on the bench grinder mounted wire wheel and the ugliness is gone, burn the branding off and the metal blends right in with the rest, do the backside and your golden.
Still not a fan but they do work well and I have accumulated several that have come with acquisitions along the way so free is good.
You could probably use a sharpie too......
