Velocity Deep V or DT Swiss RR 585?
of Clan Nrubso
Bikes: Cannondale F400, Surly LHT,Motobecane Le Champion Ti, Novara Veloce
I am looking to have a set of wheels built for my new ride. Does anyone have experience with/opinions of either the Velocity Deep V or DT Swiss RR 585 rims? They are going on a Cannondale Synapse Carbon, I weigh 255 lbs, I'm don't participate in any sort of competitive riding. I'm just looking to build a wheel that will support my ponderous girth a bit better than the stock wheels. TIA
fishologist
Bikes: Diamondback MTB; Leader 736R
I am partial to the Deep V....I weigh 310 and have the 36 spoke Deep V...no problems what so ever.
We cannot solve problems with the same level of consciousness that created them. A.E.
1990 Diamond Back MTB
2007 Leader 736R
www.cohocyclist.blogspot.com
https://www.loopd.com/members/cohocyclist/Default.aspx
2007 Leader 736R
of Clan Nrubso
Thanks for the reply, that was quick. Have you ridden any other rims, and do you feel it to be "harsh riding" in comparison?
of Clan Nrubso
Although I like the look of the DTS more, I am leaning towards the Deep Vs just because they come in "Halo" paint.
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
Quoted: 5 Post(s)
Liked 7 Times
The RR415 is plenty sufficient for you. I rode the RR1.1 (predecessor to the RR415; different stickers) at your weight for years. They're strong and will save you 170g of rotating weight per wheel (3/4 pound for the set).
"I feel like my world was classier before I found cyclocross."
- Mandi M.
- Mandi M.
of Clan Nrubso
Ooh, thank you! Other options are always worth looking at. I've got that one open in another tab now. I should also mention that I live in a hilly area with some real crap-hole roads.
of Clan Nrubso
I probably should have added ", or other" to the title as I am open to other options. I was planning on using Prowheelbuilder.com (not to shill out to them) and was going off of their strength/compatibility rating system.
Quoted: 5 Post(s)
Liked 7 Times
I wrapped my RR1.1 rims in 28mm Conti Gatorskins for a little bit more plush of a ride over the nasty stuff.
I prefer the DT rims over the Velocity for the simple facts that they have a wear indicator, and they're eyeletted.
- Mandi M.
- Mandi M.
of Clan Nrubso
"eyeletted."?
Help me out here...
Help me out here...
they built my deep v for me a year ago. over 2k and still true. went with the 36 hole with dbl butted spokes and 105 hub.
LET'S ROLL
First off, check your current wheel for correct tension and that it's true.
You may not need a replacement right away if your spokes are adjusted properly.
Having said that, I had to replace my stock Alex rim(rear only) with a
Velocity Deep v after breaking spokes and going out of true many times.
The quality of the wheel build will make more of a difference than any
particular brand/model. I ride on the crappy streets of New York City,
I weight 200lbs. Wheel has 32 spokes with the original Alex hub:
REAREND by 1nterceptor, on Flickr
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Bikes: Leader 780-R; Rockhopper FSR;Trek 660; Kona Blast Hardtail
I used to torque my old rims on the hills, and since I was doing a complete bike build from parts, I had a set of DT Swiss RR1.1s built by Mike Garcia at odd and endos. Love em. I'm now 198# was 219#. 32 h rear shown.
I never owned Deep Vs so can't say, but they were a top choice too.
Sure you can't go wrong with either.
https://www.flickr.com/photos/mcphilpix/5480217829/
DT Swiss 1.1 Rear Wheel by PhilMcPhilly, on Flickr
D Swiss 1.1 Campy Centaur by PhilMcPhilly, on Flickr
Bikes: Litespeed Liege, Motorola Team Issue Eddy Mercxk, Santana Noventa Tandem, Fisher Supercaliber Mtn. Bike
Quoted: 14 Post(s)
Liked 11 Times
I own both and while they are very similar in specs, the Dt swiss rim is just a little nicer.. This is a welded rim vs pin sleeved (Deep V).. Either rim will suit you just fine for years to come.
DT does offer a new pin sleeved rim that costs a little less which is the R520.. You can also look for the previous model to the R585 which is the DT 1.2 rim..
Speedgoat has these rims on sale right now: https://www.speedgoat.com/Catalog.aspx/Browse?Cat=C156
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
I like and use Deep V's. 20,000+ miles on my last one. I built it so it got lots of TLC during the build. Only small true after 13,000 miles.
At my weight, 240+/- a few, I don't worry a bit about a little extra rotational weight. I do lots of climbing and the only thing that slows me down is me! If I have a sucky day , it aint the rims.
My wife rode Bontrager Lites for 3 years till it wore out. I put a Deep V on the rear and she said, "wow, this is one stiff wheel, it makes the other wheel feel wimpy". I myself think it's stiff but I like the responsiveness while climbing. Like she says, other wheels have felt wimpy and flexy under me. So a little extra weight is not a bad thing IMO if the wheel responds.
I've seen the equiv in the DT but $85 when I can get a Deep V for $55? I've never had a need to try a DT rim.
She's got a Deep V and she aint afraid to use it! On the flats or in the mountains!
of Clan Nrubso
Thanks for the responses everyone! I'm apparently on the right track from what you all are saying; but none closer to a decision.
Bikes: Cannondale CAAD9-4
Don't rule out the Velocity Dyad either. It's a little stronger than the Deep V and that's what I'm going with. I considered the Velocity Chukker as well, but that might be overkill and there is a pretty substantial weight penalty with the Chukker vs. Dyad. If I end up with a cyclocross bike down the road I will probably have a wheelset built with Chukkers for that. Prowheelbuilder.com rates the Deep V as a 3 for strength, the Dyad a 4 and the Chukker a 5. The wheel builder at my LBS prefers the Dyad for Clydes over the Deep V too, so that convinced me to go with Dyads.
If you want a wider rim for a road bike, I can recommend the Velocity Synergy especially the version with off-center drilling. They're a hair narrower than the Dyad, which means you can shoe-horn a 700x25 tire onto them. The off-center drilling means that spoke tension is significantly more even across the drive and non-drive (or disc and non-disc) side spokes. IMO, this will lead to increased longevity. I used the Synergy OC when I build wheels for my touring bike and have been very happy with them so far.
Bikes: Rans V-Rex
It's also considerably wider than the Deep V (24mm vs 19mm for a 700c rim), which will limit your tire choices... It's a great rim for a touring bike, but if you own a road bike with limited tire clearance the Dyad might be a problem. IIRC, 700x28 is the smallest tire you can squeeze onto a Dyad; ideally I think you'd want a 700x30 or 700x32. On many road bikes, 700x28 is the size where you start to have problems squeezing the tire past the brake pads.
fishologist
They are stiff but at my weight I didn't want a wet noodle underneath me. They are a tad on the heavy side but so am I. I wanted something I know would hold my weight and I am not disappointed.
2007 Leader 736R
2007 Leader 736R
Bikes: 2009 Trek Soho
Same here, I have 25mm conti gp 4 season ties mounted on my velocity dyad. I'm 270+ and it has been fabulous for me. Whoever said you need a wider tire is incorrect,
My Synergy rims are 23mm wide. Having seen what a 700x28 looks like on them, I'd be frightened at the thought of trying to run a 700x23 on them! Then again, I wouldn't run a 700x20 on my 19mm ride rims.
I question the judgment of your wheel builder. Why would you want to take a wide rim and install a narrow tire on it? That sounds like a recipe for pinch flats and a harsh ride, to me. You'd probably be better off using a Deep V: it's slightly more aerodynamic than the Dyad, only a bit heavier, probably stronger, and a much better match for 700x25 tires, IMHO. If you decide you need the harsh ride and pinch flats, you can always switch to 700x20 tires...
Psimet, though not a Clyde, definitely knows his wheels. I've been riding on a set of Psimets for over a year without a problem. Did he give an explanation for his choice of components? Are you planning to race? Did you specifically request a 40- or 48-spoke wheel? Or the ability to use the same wheel on your road bike and 29er MTB? As I said, I fail to see the logic behind stretching a relatively small tire across a relatively wide rim...
