20mph average commute
Hi all,
I know some of the answers will be "depends on the engine", "depends on traffic lights", BUT given some traffic lights and some nice clear sections where I can go for quite a while without being slowed by lights. Is 20mph average possible for a 5 a day commuter? I want to get my commute time down to 30mins (10 miles)!
The last time I measured my speed I was averaging around 14-16mph - that was about a year ago.
Thanks
Daven
Thanks
Daven
Bikes: 2011 Look 566 Rival, 2009 Fuji Roubaix pro
My morning commute avg is 18 mph over 10.5 miles, one way. Unfortunate part is that I hit anywhere between 10-13 red lights and have to "slow roll" through 5 or so stop signs. Getting the average speed up can be tough with some many stop/start moments.
I've been commuting for 20 years and never averaged close to 20mph. I can get my average up to 17 on a good day, but hills, wind, traffic, city streets, and generally riding safely take their toll on average speed. I have no problem cruising at 20mph, but averaging that is wholly different level.
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
Try it and report back.
Fred "The Real Fred"
Quoted: 5 Post(s)
Liked 6 Times
I used to be able to average around 20...sometimes faster on my 9-mile commute. However, that was pushing pretty hard on low-traffic 2-lane country roads with only a couple stop signs and a few rolling hills. I have a completely different commute now.
sɹɐʇsɟoןןnɟsʇıbɟɯo
Bikes: fixed gear recumbent trike
im sure you can do it.
just push as hard as you can for as long as you can.
on a really good day i can do about 17mph avg......
https://cyclinginfo.co.uk/blog/timetr...le-time-trial/
It's very possible, but you'll need to do a lot of physical work and may need to look into more aggressive positions. Plus, wind could make it impossible some days.
The traffic lights, and traffic, may also make it impossible.
I generally cut the speed down more, because it takes 15 minutes of my time to change and 5 minutes to take it easy.
Sounds like I could at least get it close. That'd be good enough for me just like to set myself a goal and having an impossible goal would be rubbish. I think I'll go for an average of about 16-18mph each day as my goal for the end of the year.
Thanks
Daven
About 40-45 minutes total on my fixed gear hybrid - best has been 36 minutes riding time (not including traffic lights) on my road bike. Going to try to get the road bike out next week if the weather improves.
Thanks
Daven
Bikes: 05 Trek 5200, 07 Trek 520, 99 GT Karakoram, 08 Surly 1X1
Quoted: 52 Post(s)
Liked 17 Times
You're the one really in the best position to answer that.
On the biking leg of a sprint triathlon (about 15 miles), I can average around 20 mph on a fairly flat course. That's after having swam but there are no stops. Weaving around other cyclists can slow you down some and there are corners you can't take at full speed. About the last 1/2 mile I don't push quite so hard and I also ease up to speed in beginning rather than trying to explode out of the transition.
With longer distances it's easier to get the average up assuming you're conditioned for it. Since you're only going 10 miles, every time you slow down hurts you more, as you have to make that up in a shorter overall distance.
I'm not the world's fastest cyclist but I usually finish in the top quarter of my age group. Sometimes in the top 10%.
I think even if you could do it it would be a tough thing to manage to accomplish every day.
commuter and barbarian
I couldn't. Don't know about you.
But I'd say if you aren't doing 15mph every day right now, then a goal of 18 - 20 mph once is the place to start. If you get there, you will likely be riding pretty hard. Trying to do that all-out effort day after day is a tall order and probably not a smart thing to even attempt.
Quoted: 509 Post(s)
Liked 9 Times
Unless you have altitude issues or a prevailing wind that would prevent it, I suspect you will do it first on the homeward leg. My fastest commute times have always been during the trip home; it may have something to do with the cold beer in the fridge. Of course, my only breakdowns have happened on my trips home too, so both my fastest and slowest legs were the trips home.
Bikes: Surly CC
Try to do it 2 times a week to start. Use it like racers do tempo rides. So push hard for the 10 miles on the ride home twice a week. Also you're going to have to continue working spin. Pretty much drop gears until you're hips start doing the Elvis shake, then click it up one. Once you adjust to a faster cadence, you'll be able to push a third tempo ride into the mix in a week. It's possible after maybe 8 weeks. Then again, you'd be adding racing tools to a commuter ride, so /shrug.
I've pushed a 25 MPH pace for 10 miles in the last two weeks, until my daughter was hospitalized with the flu. But that is, once again, preparing for a triathlon this weekend. So I've probably got 2500 miles already under my belt of dedicated 150-200 mile weeks (sans commuting). Probably another 50 a week in commuting....see what I mean?
Obsession, dedication and a little bit of insanity have to be taken in the right dosage to make things interesting
Good luck.
Good luck.
Bikes: Bianchi Via Nirone 7, Jamis Sputnik
My gps tracking app tells me i'm generally cruising around 20mph, but with all the traffic lights and occasional hills, it drops my average down to the 14-16 range. Of course, I don't know how accurate it is. My ride is 13 miles. It usually takes around 45min to an hour depending on the lights that I get stuck at, or traffic conditions.
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
Quoted: 5 Post(s)
Liked 7 Times
Not for me it isn't, but that's not to say you couldn't do it.
My commuter is a tank, my commute has a bunch of hills, and I'm not in good enough shape to bust out with a 16mi time-trial twice a day.
When I lived closer to work (7mi one-way) and rode a flat path most of the way to work (no lights, no crossings, no stops) and just 1 hill afterwards, I could hit 18mph average if I was really pushing it.
"I feel like my world was classier before I found cyclocross."
- Mandi M.
- Mandi M.
On a road bike, with favourable traffic lights, going all out the whole way, I've been able to do my 9.6 mile commute in about 35 minutes. That's mostly flat, but I have one good downhill section, and one good uphill section (start and end elevations are very close). Like others here, I can ride 20 mph easily enough, but 20 mph average in the city is pretty difficult, at least for me.
Bikes: 01 Specialized Rockhopper A1 and 07 Felt Z80 05 Canondale Prophet
I've hit that on the way to work a few times.. Typically around 19mph, or so, depending on the day.. It helps that I drop about 300 feet over the 10 miles.. I can usuall average about 17-18mph on the round trip.
If I rode everyday, I'm sure I'd be faster..
Bikes: 2002 Litespeed Vortex - 2007 Trek Madone 5.9 - 2004 Redline Conquest Pro - Specialized S-Works Festina Team Model - 93 Cannondale M 800 Beast of the East
If 14-16mph was the starting point, it's definitely going to take some work to pop that up to 20. As you stated, lights and intangibles are your enemy. You'd probably have to roll @ 22-23 mph routinely to make up for city conditions. It takes a pretty accomplished cyclist to maintain that kind of speed.
Quoted: 18883 Post(s)
Liked 10,646 Times
That's more reasonable. You'll have to work for it, but 18 shouldn't be too hard on the flats.
