bottom bracket clicking sound
Quoted: 43 Post(s)
This is on a bicycle with a spindle and cup, caged bearing bottom bracket that I have overhauled a few times within the last year because of some vague and minor issues that have developed. Since the last overhaul, the drive-side cup and lock ring have remained tight except the bike has developed a -cinching- click type of sound with cranking up the steepest of slopes.
I have had this problem arise before more than once with a sealed cartridge bottom bracket for which the BB can simply be replaced. I wonder if anyone else has run into this audible cinch from the bottom bracket and if there is a recognizable cause?
Quoted: 5931 Post(s)
Liked 2,825 Times
FB
Chain-L site
FB
Chain-L site
Quoted: 4235 Post(s)
Liked 3,956 Times
Of course others have had this problem. We see it at work often. Many causes exist. The basic understanding is any two parts that touch could be slightly rubbing and this movement heard as a creak, squeak, tick, click. There are many part interfaces in the crank area. Pedal cages on pedal bodies, pedal bearings, pedal axles in crank arms, chain ring bolts in rings and arms, arms on BB axle, BB bearings, BB cups or cartridge in BB shell. And i probably have missed a few. Your job is to go through each and every one of these connection points and take apart, clean, lube, tighten or otherwise insure that each is not a problem. The scientific method is to do one spot at a time and see the results. Real life in a shop is to do a bunch of easy and quick things first that don't require taking things apart. Good luck. Andy.
Liked 2,825 Times
I read your post too fast, and somehow came away with the idea that the cup worked loose.
Re-reading I see that wasn't the case, so I'll modify my advice.
Before touching the BB, or even going near it, remove both pedals, clean the threads and mating faces on both the pedals and crank arms and replace. If you have a spare set of Pedals you know to be OK install them as a control and test ride.
Pedal threads are a common cause of clicking or creaking under load, and though they're not the most common cause, they're the easiest and cheapest to diagnose and rule in or out as a cause.
I don't know any mechanic who ever regretted checking pedal threads as a possible cause, but I know many who've regretted time wasted because they didn't check this.
FB
Chain-L site
FB
Chain-L site
