Reynolds 708 frame
Reynolds 708 frame
Hi
I am trying to find information on a Reynolds 708 frame - I think this tubing as not manufactured for very long. Where is the Reynolds hierachy does it sit? I am being offered a new old stock frame quite cheaply and thought it would make a good basis for a tourer.
Any thoughts???
Any thoughts???
Originally Posted by dukerider
Hi
Any thoughts???
Any thoughts???
Likes For sydney:
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
Hi
Any thoughts???
Any thoughts???
My guess is that a 708 frameset would make a fine light duty touring rig but may be a little flexy for loaded touring with a heavy rider.
Hope this helps.
Ed
Retrogrouch in Training
My understanding is that 708 offered superior rigidity over 531 for touring loads and that it was specifically designed for such use.
Liked 425 Times
Reynolds 708 CLASSIC
"A receint development from Reynolds, the name describes the purpose.
The main tubes of this set have a new and ingenious inernal profile.
The profile is designed to maximise lateral stiffness and strength in the direction of the known loadings, which result from the punishing road surfaces and the extreme rider applied deflection loadings experienced on the brutial classic racing courses."
No doubt 708 is stiffer than regular 531, however 531 SUPER TOURIST is quite a bit thicker yet which makes it a better choice for loaded touring.
Thanks
I have purchased but not collected the frame. Looking forward to checking it. Can you tell from th ecatalogue when this tubing was available? I am keen to know the age of the frame. It is new old stock and all I know is that is has been sitting in a shop somewhere.
many thanks
many thanks
Thanks. What you say is true but I was merely intersted in what I might be getting for admittedly a small amount of money.
I bought it.
I bought it.
Hi,
i used to ride a 531 .
This is all from memory but i believe the 708 frames were not successful because they lost their rigidity very early in their life.
on this basis i'd be very wary of a 2nd hand 708.
hope this helps.
hope this helps.
Bikes: R J Quinn road bike with Reynolds 531cs tubing, Lombardo Hiker 6061 aluminium tubing, Dawes road bike 531c, Dawes road bike 531st, Peugeot road bike reynolds 753
how did that 708 turn out? how does it compare on the reynolds scale of other tubesets? im thinking of buying one for myself to try out.. but there is a parcity of information on it. thanks
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
I doubt that very much. That steel loses rigidity over time is a persistent myth, but a myth nonetheless. Far more likely is that frame fashion preferences moved on from steel tubes in classic diameters to non-ferrous tubes and oversize diameters.
Likes For JohnDThompson:
Quoted: 7348 Post(s)
Liked 2,467 Times
I know I'm responding to a nine year old post, but steel does not lose rigidity with time, despite urban legends in the bike world.
Quoted: 2026 Post(s)
Liked 1,096 Times
Quoted: 19 Post(s)
Liked 7 Times
the finest British production tourer was 708 Raleigh Randonneur
Bikes: 2007 Nagasawa with C-Record, 1992 Duell with Croce D'aune/Chorus, three Gazelles, M5 recumbent
Quoted: 47 Post(s)
Liked 25 Times
I have a NOS Reynolds 708 tube set that one day I plan to build into a frame.
The ribs do look interesting.
Replying to old post here: my Raleigh Randonneur (708 tubing), which must be coming up for 30 yrs old, still gives a fantastic ride. It's very sprightly up hills and when I loaded it so heavily that I couldn't lift it off the ground it still went up 1/7-1/5 gradients and rode as nicely as ever - despite the fact that starting off was rather like launching a boat. It's still the bike I find most comfortable and reassuring over distance and steep hills and I rate it as a very lucky find second hand about 16 years ago - albeit this is all partly down to being a perfect fit it's generous gearing.
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 670 Post(s)
Liked 972 Times
I am responding to a very old thread. But I have one 1993 peugeot prestige road bike made of reynolds 708 classic tubing, it is equiped with a mix of dura ace 7400/7700 and ultegra 6500. Not the most light weight bike (9.7kilos) but very durable and comfortable. I willupgrade the drivtrain to dura ace 7800 and to dura ace 7700 or 7800 brakes. Old pictures I have taken almost a decade ago
Steel is real
Quoted: 670 Post(s)
Liked 972 Times
And more on the subject with an interesting link about what happened to reynolds 708 tubing plus some explanation about some older reynolds tubesets
Likes For georges1:
illenvillain
Classic & Vintage
12
03-18-14 08:32 PM
wroomwroomoops
Bicycle Mechanics
20
01-31-11 06:30 PM
