Reliable patch brand? I have vulcanizing glue already.
#51
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
I've used all kinds of patches over the last few years but I always seem to come back to Rema. They seem to last the longest. I used their brand of vulcanizing fluid also. I think it's a good idea to use the same brand fluid as patch. On the road though I carry both Park self-sticky patches and Rema. I have a small Rema patch kit that I throw two Park patches in as well as the Park self-sticky tire boot patch. The later came in handy a few years ago when I blew out a tire.
Stuart Black
Stuart Black
Likes For cyccommute:
#52
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,432 Times
What is Tyvek? I see that word plastered all over houses under construction, when they put up whatever underlayer the siding or whatever goes on. Didn't know they made envelopes out of it too!
#53
Liked 4,218 Times
Stuart Black
Stuart Black
#54
Quoted: 7348 Post(s)
Liked 2,470 Times
I patched two tubes yesterday. I learned that my memory is not reliable. Well, I knew that already. I thought my bulk patches were Rema and the bulk glue I got at the auto parts store was vulcanizing fluid. It turns out the patches are Sunlite (a no-name name), and the glue is marked as rubber cement. Well, I've been using this setup for a while, and it's working, but I still agree that Rema is the best stuff.
#55
Bikes: (2) 1994 Cannondale R900, red, Silver Trek hybrid
Quoted: 69 Post(s)
I used them a lot. Two problems with them today. 1, the patch is too big for a road bike tube, I would cut them down to fit. 2. They dont' make them any more. I can't find them now. They do/did work great
#56
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,432 Times
link?
#57
Location: Guadalajara de Buga, Valle del Cauca, Colombia
Bikes: Maria Casquitos: 15" MTB 26" frame+ 8spd Alivio 2007 groupset. 48TT CR. Celestina: 16" MTB tandem frame with Shimano Alivio 2014 groupset, 48TT CR. Greta: tailored steel road frame (Duarte) with Sora 9spd groupset, Mavic Kysrium SL SSC WS 50-34/28-11
Quoted: 19 Post(s)
Liked 8 Times
This is an interesting thread since about 3 years ago I realized that after 25 years commuting, glueless patches are quite handy. You use glue like 2 or 3 times a year, so the fourth time glue is dry. Glueless patches (or stickers if you like) last longer on your bag.
They're not common in my country, in fact I have to order them online, since if I can find some they're quite expensive. I started using them when I got a kit as a gift (park) and loved them. Run out of them and tried to find similar ones, and found Skabs, by slime.They work great too, but just ran out of them. Looking for their replacements I started to give it a little research and found this thread, a little late since I ended buying cheap ones on aliexpress. I thought: "what is the difference between brands, is just tyre rubber and glue". Reviews are 98% positive, but only a few for the product, most of the are just for receiving the item.
However, they look fine. What's your aversion against glueless? I only had one issue with them in the 3 years I've been using them, they adhere to the surface just like the glue ones.
I'll let you know how it goes with this sketchy "duuti" glueless patches, and I promise I'll go for you beloved Rema if they don't do the work.
#58
Bikes: 1975 Raleigh Sports, Cycles Toussaint Velo Routier, Yuba Mundo, Raleigh Sports (1970)
Quoted: 34 Post(s)
Liked 10 Times
Who knew that patches were so controversial! I have always used Rema kits and generally had no problems. One thing I've noticed is that the new Rema kits say that you don't have to wait any time between applying the fluid and putting down the patch. They don't offer an explanation for the change, and I'm set in my ways enough that I still wait a bit, or at least I take my time getting the patch ready after applying the fluid.
#59
Quoted: 966 Post(s)
Liked 1,629 Times
Oddly one of the hardest things to do when installing a patch is to let the glue dry before applying the patch. Really it is only about 5 min but they appear to be very long minuets when your waiting. I carry just a generic ChiCom patch kit with the little 5-7 gram tubes. But I also carry an unopened little tube of Generic Super Glue as a back up. Using a dab of super glue works well for a patch but it is not flexible and therefore not a reliable patch.
Some times my generic ChiCom patches get kinda dry. No biggy, I just put vulcanizing cement on them and they soften up.
Again... Remember to let that glue dry before application. Often its a hard task...
#60
Quoted: 514 Post(s)
Liked 448 Times
Years ago I bought a can of Rema cement and a box of 100 Rema patches. The glue dried up after a couple year, but the patches still work great. I use a rubber cement that I bought at the local True Value store. They work fine together.
#61
Cantilever believer
Quoted: 536 Post(s)
Liked 1,833 Times
My experience, after patching hundreds upon hundreds of tubes for local nonprofits (and my own re-use):
Surface prep is 95% of success. If I'm patching at home, I use a dremel with a sanding drum attachment to get a good clean nothing-but-tube-rubber patch area about 25% larger than the expected patch. Turns a tedious chore into seconds of easy work.
I use only Rema cement. I buy the 4-pack of 7 gram tubes every so often - if there's a long hiatus between patching sessions, I only potentially lose what's left in the currently open tube. NOTE: the newer Rema cement tubes say the formula is now a "no-wait" one and the patch can be applied immediately - I still wait 3 minutes or so out of habit.
I've used non-Rema patches with Rema cement with good success, but using Rema (or any) patch with non-Rema cement sees an unacceptably higher failure rate.
Oval Rema patches have an amazing ability to fix long cuts / blowouts / bigger holes, but aren't 100% foolproof . Don't ask me how I know this. The bigger frustration is now they're nearly 50¢ each on Amazon, so wasting an oval is an annoyance.
#62
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Four year old thread
Likes For Rolla:
#63
Quoted: 1819 Post(s)
Liked 1,693 Times
Sadly, I have had so few flats in the last 10 years that I have forgotten almost everything I ever learned about patching inner tubes in my earlier life. One thing I do remember is usually applying a second coat of the vulcanizing fluid after waiting for the first coat to dry and waiting again for the second coat to dry. I also remember those hot patches. I had a 1972 Peugeot that had tube type Michelin X radial tires. I remember repairing a couple of punctures using those hot vulcanizing patches. The nice thing about tube type car tires is that you can remove the tire without needing any special tools other than a set of old fashioned tire irons. My grandfather was a master mechanic and I inherited a set from him
Likes For alcjphil:
#64
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,432 Times
Likes For RubeRad:
#65
Quoted: 1562 Post(s)
Liked 1,734 Times
I used to use generic rubber cement with Rema patches. They seemed to work very well. The etches were all glued down very well. But then I started seeing the patches crack after hanging around in the garage for a few months. So I switched to Rema glue. The gold standard supposedly. But now the edges don't stay down. In fact the other day I peeled one patch right off. I put on a second patch, and I was able to peel half of that off. I ran out of time so I had to quit there.
So from where I sit, Rema sucks.
Likes For icemilkcoffee:
#66
I use generic Chinese branded patches with generic Chinese branded patching glue tubes. I've used countless different brands of patches and glue, both name brand and generic. They're all the same, at least the ones that I used. My record is 11 patches on a tube.
I do not use peel-and-stick patches as I find they come off eventually.
#67
Liked 4,218 Times
Stuart Black
Stuart Black
#68
Liked 1,734 Times
Your problem is probably in the preparation. The tube has to be well sanded to remove any mould release compound. The fluid has to be dry…the longer it sits, the better. Don’t touch the patch or the dried fluid…oils from your hands can interfere with the bonding process. It takes a little attention to detail but I find the results to be worth the effort.
Also- could it be the temperature? Is there an ideal temperature to do this exercise in?
#69
Liked 4,218 Times
I sanded the tube and also used acetone to wipe it. I waited between 5-10 min. With 5 minute wait, I could pull the patch right off. With 10 minute, I was able to pull half of it up. So I don't know, maybe next time I'll try 15 minute. Is there such a thing as waiting too long?
Make sure you put on enough fluid, as well. You need to make sure the fluid goes beyond the edges of the patch.
Stuart Black
Stuart Black
#71
As with most adhesive applications, surface prep is of highest consideration.
1) clean of the waxy parting compound from the tube with a solvent (acetone, isopropyl alcohol, etc) soaked rag, and roughen the surface with fine sandpaper
2) mark the location of the hole with crosshairs or equidistant x/y axis marks
3) apply a thin coating of the adhesive. To accelerate drying and to warm the rubber tube, ok to light it on fire, but blow it out before bubbling starts. (If you use fire, make sure your solvent rag is not close by the flame)
4) quickly apply your choice of patch (Rema, Tip Top, etc)
5) stitch the patch with a roller or coin shaped object with a hard object beneath the tube
6) stitch it again, in all the directions
7) partially inflate just enough to round out the tube, but not stretch the rubber and check for other leaks
8) put it back in the tire and enjoy your ride!
I’ve also found that the Skab patches work very well following steps 1 and 2.
#72
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,432 Times
Skab patches don't require step 5? That's amazing!
