1x question
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
1x question
So short of sort of purpose made chain keeper would a non functioning front mech do the same thing?
Building my 11 year old sons first road bike and using 1x system. I have a 2x crank set on the bike just using the smaller chainring. So the large chain ring acting as a guide on the outside but nothing on the inside concerns me.
I know what your all thinking, make it a proper 2x system and don't worry about it. The problem is my son doesn't want a 2x and the small to large front chain ring jump would be big for the front mech anyways. AND the parts I have on hand without buying more stuff is always a bonus. I am not even sure what gearing he will have yet so a narrow wide chainring is in the future as soon as we can figure out the proper front chain ring size but for now I am looking for some cheaper temp options.
Go ahead and beat me up too, I can take it
Seriously any thoughts would be appreciated.
FYI the road bike is running a sora set up.
Quoted: 18378 Post(s)
Liked 4,512 Times
It might not hurt to trim all the teeth off of the outer ring to use it as a bash-guard. That will also help prevent things like pants from getting caught on the ring.
The front derailleur may help some. Or, it is quite possible that he won't drop the chain on the inside when not shifting. So, leave it off and see if it actually is a problem.
If the inner ring does become a problem, then look for a 1x chainring.
Likes For CliffordK:
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
You can put the FD back on and adjust it so it won't rub. Maybe.
Kid bikes commonly come with inexpensive 3-piece cranksets with a permanently mounted 36 tooth ring. You could find one of those - maybe ask in a forum like the one on MTBR because the "serious" dads are throwing out oem components all the time. They sometimes have some kind of simpler chain retention like a bash guard.
The Specialized version has a top chain guide and a bottom idler. It's stout. I took it off my kid's 20 inch bike because he's a pretty timid rider and it all weighs about a pound. He hasn't dropped the chain riding but it's come off a few times slinging the bike around.
https://www.specialized.com/us/en/hotrock-24/p/184500
The problem I see with a "full" 1x setup is that you've started as far from that as possible. All the road/gravel 1x controls are for hydraulic discs and the newer longer cable pull. There's no gravel equivalent of Sora yet, for example, and if there ever is it might not have a 1x or clutch option.
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
I am going to not try the FD, seems like not so great after I think about it and the couple comments on it.
I will probably go with nothing and see if it even is an issue as you suggest.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
to be clear, the end goal is to get a narrow ride when he decides what size he likes best. this is all temporary issues that hopefully won't be issues in the end.
thanks
Liked 4,512 Times
What crank length are you using?
165mm?
165mm?
Quoted: 967 Post(s)
Liked 1,629 Times
He's eleven years old... He can take it, learn it, and out grow it...
Don't do anything special. It won't be long before he is on his bike and you on yours and he is squashing Ya like a Bug!I
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
He is up to 152mm
He tried 160 but there a bit of a stretch yet so 152 is where his most comfortable at right now. Will use this until we get to 160's range. The only reasonable set of 152 was on a triple set up. Its good but not perfect yet short of of a narrow wide ring.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
I will leave it be I think and see how it goes now.
I built this the way I did so when he out grows the frame size and cranks I can strip this frame of most everything and upscale it to the next size frame. There is a good use to have a box full of old parts and crap sometimes. Was pretty handy for this project.
progress so far...... well as of last night, wheels got put on today so we are at least using the mech
Paintjob inspired by star wars, cyan and pink what he wanted.
Quidam Bike Super Hero
Bikes: 1995 Trek 800 Sport, aka, "CamelTrek"
Quoted: 331 Post(s)
Liked 415 Times
In the interim of switching my old Trek mtb from 3x to 1x, I rode the bike with the FD limit screws dialed to the middle and left the FD on as a chain keeper. No issues, though noting that I RARELY leave the roads and MUPS.
Likes For Digger Goreman:
