Tire Pressure increases 5 lbs in one ride
Curmudgeon
Bikes: Specialized Diverge Comp
Quoted: 157 Post(s)
Liked 32 Times
I’ve not previously taken tire pressure after a ride. But I just put new Perrelli P-Zeros 700x28. Since it was the first ride I measured tire pressure and found they had both increased 5 LBS.
That is a surprisingly high increase.
how common is that?
zipp 303 wheels
new perrelli p zeros running tubeless
170 lbs rider
85degree air temp
70 mile ride @ 19 mph.
how common is that?
zipp 303 wheels
170 lbs rider
85degree air temp
Quoted: 837 Post(s)
Liked 1,061 Times
I'm not a pneumatic engineer so don't know the exact formula but assuming you're using the same pressure gauge the 85 deg temps might account for the higher pressure if say you took the original pressure reading in temps well below that. Also plenty of room for errors trying to find correct tire pressure in multiple attempts with high pressure tires. Hopefully a more educated poster will chime in.
Likes For Crankycrank:
Quoted: 6193 Post(s)
Liked 4,809 Times
Like Crankycrank said.
If you topped it off in the cool of your airconditioned home and then took it out in the 95°F (35°C) and in the hot sun where it could be more inside, then maybe that's where it came from. But I'm not a pneumatic engineer either. <grin>
I don't check my tires pressure after a ride so I'd have no idea how common that might be.
Perhaps the needle on your gauge is loose and never gives the same reading twice.
Likes For Iride01:
Really Old Senior Member
What's the temperature of the pavement? Probably much higher.
Likes For Bill Kapaun:
In addition to the day warming up after you set the pressure there's also the fact that tires get warm when ridden. 5PSI worth? Probably not on a bicycle. More than that on cars or motorcycles.
Probably mostly the day's temperature warming up from the start to end of the ride. Got up to 85 by the end of the ride? What was it when you pumped and checked? If it was down around 70 and warmed to 85? That could be the 5PSI.
The other option is if you used the same gauge for both measurements. Different gauges often give different readings. I'm thinking same gauge though since we're creatures of habit.
Likes For BCRider:
Quoted: 2333 Post(s)
Liked 2,097 Times
how common is that?
zipp 303 wheels
170 lbs rider
85degree air temp
how common is that?
zipp 303 wheels
170 lbs rider
85degree air temp
Expect about 2% increase in tire pressure for each 10F. Garages and houses are cool, pavement is hot. Tubeless and hookless? NB
Likes For GhostRider62:
Quoted: 1609 Post(s)
Liked 2,590 Times
You using a tire pump gauge or a dedicated gauge? At work we had a preset test valve to calibrate our gauges. Seems the act of checking pressure would drop it by a pound or two. Anyway, at least it's not losing air.
Curmudgeon
Quoted: 157 Post(s)
Liked 32 Times
What is most interesting to me is, I don’t recall anyone posting or advising about tire pressure increases. Back in my motor sports days, sports car and stock car racing, we obsessed about it by constantly checking tire diameter to manage to the best growth.
with all the constant chatter about “correct” tire pressure for tubeless bike tire setups, it’s curious there is no conversation or research into increasing pressures.
Quoted: 837 Post(s)
Liked 1,061 Times
Quoted: 569 Post(s)
Liked 582 Times
5 PSI in a passenger car and absolutely in high pressure tires for heavy vehicles is not unusual for large swings in temperature, added radiant heat from the Sun, and from driving on them, etc. That's why all passenger vehicle's recommended tire pressure is its cold tire inflation pressure.
Likes For easyupbug:
Quoted: 506 Post(s)
Liked 639 Times
how common is that?
zipp 303 wheels
170 lbs rider
85degree air temp
how common is that?
zipp 303 wheels
170 lbs rider
85degree air temp
Likes For KerryIrons:
Celsius
Apparently you were afraid to try Fahrenheit?
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
That said, the influence of temperature isn’t all that great on pressure. If the tire were filled at 70°F, the temperature would have to be raised to 95°F to get a 5 psi increase. Possible but unlikely. I’d suspect error in measurement more than temperature increase. To check, I’d measure again when the tires are at the same temperature as when it was pumped up. The problem is that there’s a bit of the Heisenberg Uncertainly Principle and Schrödinger’s cat with the pressure measurement. Measuring the pressure changes the pressure so you can’t know the pressure until you measure it but it’s no longer the pressure.
Stuart Black
Stuart Black
Liked 2,971 Times
Put a tire pressure sensor that reads out live data (via BT usually) onto the stem & see what the findings are.
-Oh Hey!
-Oh Hey!
Liked 2,097 Times
You can get there with the Ideal Gas Law but it’s the long way round. Guy-Lussac’s Law is a better way to do the calculation: P/T= k. In the Ideal Gas Law will give the same thing if you consider that the volume, n and R are all constant.
I am not sure why you consider a 2% per 10F increase unlikely. It is common form the differential from inside to outside temp to exceed 20F and the temps on the pavement are much higher still.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
But we do not even HAVE a measurement of temperature, either before or after the ride.
This comes up a lot in the "heat from braking blows tire off rim" threads.
So - temperature MIGHT explain it, but if you want to be sure, you have to run a real experiment multiple times and measure everything... not just rely on intuition and a couple data points.
Likes For DiabloScott:
Quoted: 1109 Post(s)
Liked 1,200 Times
What you're probably seeing is the difference between cold pressure and warm pressure. As you probably know, any tire pressure spec (cars, bikes, etc) is based on cold pressure. This is to make that pressure reading fairly uniform. Because, as as soon as you start driving or riding, the tire temperature - and therefore the pressure - will go up. Friction from the road, heat from the road, braking, air temp, etc. I'd be surprised if the pressure of your tire didn't go up with use. I've never checked a bike, but I do know that the pressure of my travel trailer tires goes up substantially as soon as I start towing (the pressure monitoring system also measures temperature)
An interesting question to me would be - after you ride, and the tire has cooled to the temperature at which you took the original pressure, what is it?
Likes For Camilo:
Liked 2,097 Times
Take ten or twenty pressure measurements. You will not get a normally distributed curve. I lost 1.3 psi on average with ten pressure checks done consecutively. If after a ride, one measures 5 psi increase, the actual is more like 6 psi
Quoted: 980 Post(s)
Liked 582 Times
Are you sure you didn't accidentally install one of these?
Likes For sweeks:
Liked 4,809 Times
Maybe this should be a poll. How many cyclist check their tire pressure immediately after a ride?
I'm thinking the OP is the only one! But I might be wrong.
Liked 2,097 Times
How many take an infrared gun out to test the carbon rim temps after a long hard descent? I know one.
Liked 4,809 Times
Maybe he listened to Silca's Josh Poertner who said tires blew of the hookless rim at a mere 80 psi. Think of how many use 75 psi. And how accurate is that 75 psi? (not very)
So do you stop every other switch back on the way down to check the rim temps? I admire your dedication to being safe! Though actually I hope carrying the IR thermometer is just in the interest of gathering data to help with the dogma.
Likes For Iride01:
