Shock-absorbing Stoker Seatpost?
Can I get a recommendation for a very good shock-absorbing seatpost for my long-suffering Stoker/wife on our Trek T900? We ride on the Ozaukee Interurban Trail in Wisconsin and it has some completely heinous cracks and rough spots -- despite my trying to avoid them, she takes some real abuse back there from the shocks. Today she was getting some serious back strain from it.
We're approaching 7800 miles on the bike now, and I want it to be fun for her going forward. Thanks in advance!
Likes For Bellman:
My stoker got a long travel version of the Thudbuster years ago, and she will not consider anything else now because of the long travel, inherent damping of the elastomers, and constant seat to pedal distance.
Quoted: 2495 Post(s)
Liked 738 Times
Quoted: 637 Post(s)
Liked 1,285 Times
We also have a Raleigh Comapanion I put together for the local rails to trails and a local canal tow path that are mostly gravel, patches of dirt and sand and occasionally chip and oil. I put 26 X 2.3 Kenda Small Block 8 tires on it and while they do have a bit more rolling resistance over the Schwalbes on pavement (although not bad considering the aggressive tread) they have an even smoother ride due to the large volume. They fit the Raleigh frame but clearance at the back of FD cage is tight. By visual comparison I believe they will fit the T900 as well. Kenda makes their Kwest line in a 26 X 1.9 that is nearly as wide as most 2.125's but I don't know how well they would hold up on a tandem. I have them on a vintage MTB turned townie and they handle and ride great.
Liked 738 Times
Our T900 came with 26 X 1.75 Bontragers, other years may have spec'd different tires. I just replaced them today with 26 X 2.0 Schwalbe Marathons and there is a noticeable difference in both ride and perceived pedaling effort. The bike rides smoother and feels like it rolls much easier.
Likes For Leisesturm:
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 207 Times
The Thudbuster seatpost has been THE CHOICE of suspension seatposts for tandem enthusiasts for decades. It comes with variable density elastomers to meet most stoker needs. I can't imagine your stoker wouldn't do well with this. If that fails, then perhaps the only solution for you would be a full suspension tandem. This would achieve the best impact attenuation she could achieve. Less unsuspended mass means the rear wheel can bounce in and out of potholes, up and over bumps and rocks with the most ease, allowing the rest of the bike and rider to be "insulated" from the impacts of the rough road surface. And this explains why the vast majority of mountain bikers today ride full suspension. It's so well designed and implemented that it's now the standard. Yes, it's overkill for "casual" tandem use, but if it's as bad for your stoker as your post indicates, then you may want to consider it.
