N20(Nitrous) instead of CO2 cartridges?
Attention science folks! Anybody attempted to use Nitrous Oxide (N2O) cartridges instead of Carbon Dioxide (CO2) in their pumps? It's a lot cheaper to buy a box of 'em at the local Smart and Final (or head shop for some of you!) and at the end of your ride you can suck the gas out of your tubes for a nice cool down! Would it be safe? Would it last in the tube?
Thanks--gaijin
Thanks--gaijin
Still kicking.
Not a good Idea at all.
Appreciate the old bikes more than the new.
At least the original question is not a joke. Every time I go to Smart and Final and I see the box of "Easy Whip" cartridges it makes me think.
It tastes like burning!
N2O is laughing gas.... lots of kids abuse it.... you know, buy cans of whipping cream just to snort the gas.
CO2 has a molecular weight of 44
N2O has a molecular weight of 44
hello
George
Bikes: 84 Trek 660 Suntour Superbe; 87 Giant Rincon Shimano XT; 07 Mercian Vincitore Campy Veloce
Great idea! Why heck if you were racing and was in second place with only 20 yards to the finish line and the first place guy was only a maybe a wheel length ahead, you could puncture your rear tire and light a match then BOOM, the resulting explosion would blow you into first place! OK, I'll stop inhaling the N2O now-darn!
Crank Crushing Redneck
Bikes: Bikes are environmentally damaging
How about helium in your tires, then you can just float over the top of the competition.
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
Thanks--gaijin
Thanks--gaijin
I don't know if the NO2 cartridges have the same amount of pressure as the CO2 cartridges. If they have less then you might have a problem getting your tubes inflated to the right pressure. Also, I haven't seen any NO2 cartridges which are threaded so those of us using threaded inflators wouldn't be able to use them. And I'm not sure where you're getting your pricing from but IME even a bulkload of cases of NO2 cartridges (read: 600 cartridges) works out to around US$2.50/cartridge. That's definately not cheaper than CO2 cartridges.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
Quoted: 15 Post(s)
Liked 9 Times
Marty
Sono più lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
Nitrous Oxide isn't explosive? How? It is used in drag racing in both Top Fuel and Funny Car and in some street classes as a "boot". Ever heard of NOS (Nitrous Oxide System)?
Nitrogen is used in race car tires and to power the pnumatic impact wrenches used to change tires in pit stops. I don't believe N is used in bike racing as you don't deal with near the extreme high tempatures. I'll just stick to CO2 for now.
Location: Ohio's Cycling Capital, America's North Coast.
Likes For Ebbtide:
Originally Posted by ehenz
Sorry, it is not explosive or flammable. The nitrous gas is cold and condenses the oxygen that burns the fuel.
DieselDan, I think that racecar tires use helium in them to make them lighter and also the fact that helium resists the heat buildup better. I think that they would use helium in bike racing, except it leaks really fast (smaller molecule?) and there is not a whole lot of air in a bike tire anyway.
they use regular air in impact wrenches. it is just compressed with a compressor.
Bikes: '03 Fuji Roubaix Pro; '03 KleinGi Attitude; '06 Soma Rush; '04 Surly Cross-Check; '06 Soma Rush; '07 Scott CR1 / Chorus
Originally Posted by Phatman
I thought it was because the Nitrous has more oxygen per volume then regular air, thus getting more air into the engine.
When nitrous is heated (above 570F, I think) it splits into oxygen and nitrogen, thus making more oxygen available for combustion in the engine. And when it vaporizes, it provides a cooling effect on the intake air, which increases the air's density thus making even more oxygen available for combustion.
Not flammable at all.
Bikes: Litespeed Firenze / GT Avalanche
PS. N2O is not used in top fuel, they burn nitromethane.
Likes For Avalanche325:
Direct Hit Not Required
Bikes: Leopard DC1, Ridley X-Fire, GT Zaskar 9r
All you want to know about Nitrous Oxide... https://www.cganet.com/N2O/factsht.asp
Guest
Posts: n/a
Quoted: Post(s)
I drag race cars....Nitrous is gas form contains high amounts of O2 (oxygen) so injecting N20 increases the volume of O2. More O2 + fuel = more HP. Also N20 cools the intake charge or AIT (air intake temps) very important on high HP drag cars, cools cyclinder temps and is also used to spool turbo cars. Top Fuel cars use nitromethane different than n20. N20 is NOT flammable.
Center of the Universe
Bikes: Bianchi San Remo, Norvara Intrepid MTB , Softride Solo 700
NO2 is classified as a non flammable gas but in my Emergency Response Guide Book (for handling and clean up of hazardous materials) this is what they say about it
" Substance does not burn, but it will support combustion
Some may react explosively with fuels
May ignite combustibles (wood,paper,clothing,etc)
Vapors from liquefied gas are initially heavier than air and spread along the ground
Run off may create fire or explosion hazard......"
Where CO2 is non flammable although you do not want to inhale it and you must be cautious of freeze burns. I'll stick to the CO2 it seems a bit more stable.
Matthew 6
Matthew 6
Originally Posted by lotek
Nitrous Oxide isn't flammable, neither is Helium.
Marty
Marty
Bikes: 1998 Bianchi Veloce
Booyah and Saso are dead on about the use of N20 to increase output in internal combustion engines.
And no, it's not (as previously mentioned) in itself flammable. It's an accelerant, meaning that it aids rapid combustion.
And nitrogen is used to power air tools and air jacks in the hotpits (i.e. trackside) in motor racing for the fast pit stops. The reason they (we) use the big bottles of nitrogen is that they have extremely high pressure (our bottles are rated to 2000 psi of storage capacity, but you can get bigger) and can support high air flow volume for short periods of time. An air compressor just can't get a motorcycle (or car) elevated fast enough for a fast pitstop. It's cheap, too! If you've already paid for the bottle (the expensive part), a refill for a 2000 lb. bottle only costs about 27 bucks at Airgas or Praxair.
The reason that it's used in tires is not for any weight reason, but because it doesn't expand with the high tire temps seen in motor racing (we aim for 180 degrees F on supersport motorcycle tires). By having pressure rise under control, you can acheive better repeatability in the tire's traction behavior. (In addition to a daily calibrated tire gauge with a padded box guarded like the crown jewels!)
Before anyone points out that the atmosphere is indeed 78% nitrogen, part of that remaining 22% is moisture----the main thing that expands in tires when heated. Then add the moisture from the tire mounting process. The nitrogen that comes out of the bottles is "dry".
Here's the full routine for you other motor racers who are (obviously) lurking out there:
1) Mount tires. Set beads as per normal and set pressure.
2) Balance tires.
3) Break the bead on one side only of the balanced tire.
4) With the tire laying on its side, push the bead down away from the rim on the side opposite the valve stem.
5) While holding the bead down, start inflating with nitrogen. When you feel the cool nitrogen flowing past your hand, count to 2 or 3. This step purges most of the plain ol' wet air out of the tire.
6) Release your hand while still filling. This will set the bead.
You now have a tire that won't rise as much during the race. You will, however, need to re-adjust your starting pressure. Go a pound at a time, and keep an eye on those tire temps...
Now, back to the bicycles!
-Erik
2) Balance tires.
-Erik
Likes For gazedrop:
Quoted: 413 Post(s)
Liked 109 Times
Nitrous Oxide does both...it introduce more oxygen into the combustion chamber allowing for more fuel to be introduced and it cools the intake charge making for a more dense air mixture which allows for more fuel as well.
Nitrous Oxide is not flamable but I cant figure out how you get 'nitrous/intake explosions from it pooling up.
CO2 is 10X more disolvable in blood than regular. Suppose you have a cut on you hand and accidently blast it with your CO2 cartridge....you really dont need to worry about a CO2 bubble getting into your arteries....N20 on the other hand...isnt there something about nitrogen and scuba diving and nitrogen bubbling in your blood? Blast an open cut with one of those and who knows what might happen,
Sport Class Racer
Bikes: 2003 Leader Bike LD 515 <----race bike, 1991 Cannondale SR 400, Haro Escape 8.3(dead, will revive to ride urban on),2003 Ironhorse Hollowpoint Expert, Random Frames and BMX stuff
would helium work in a tire???
Guest
Posts: n/a
Quoted: Post(s)
Race grade N20 contains sulphur and cannot be abused unlike medical grade N20.
