Di2 owners: Checking battery percentage and charge?
Don’t. Your questions were remarkably different (in substance and expectation) than asking about a 30+ pound bike with garbage components looking for affirmation from a bunch of folks who’ve been riding quality bikes for years. D-Fly is NOT a requirement to have Di2, it can enhance the experience, but it isn’t necessary. That’s my opinions.
As for what gear you’re in, I don’t look or care either. I can tell by feel when I am outside my normal cadence range, and I know how to shift the gears to get there based on the salutation (wind, hills up or down, etc.). It’s a “nice to have”, but definitely not necessary for even a moderately experienced rider.
I find knowing what gear I’m in to be incredibly helpful for going up hills. I have some around me that I know I can do in the big ring and some that need the small ring. Then there’s the times that I forget to pay attention and have to make a decision, do I shift up and get to where I need to be or is there too many jumps and I dump the front to the little ring and keep going. The last case is when I’m going down hill and start to think I’m superman and spinning out the hardest gear only to realize I have a couple more downshifts to go and I’m not going to win the Tour De France thanks to my absolutely awesome power output.
in short, no it’s not needed but there are cases where it may be useful to know some of that information.
On a somewhat related topic, my bike is currently in the shop being upgraded to Ultegra Di2 and I have been doing online reading and watching YouTube videos about Di2 and how to use it.
Yesterday, I read an article that mentioned the eTube app and its capabilities. The app sounded like a great tool that I would use, but many reviews for eTube in the Google Play Store were negative and discussed issues such as the app being unable to connect with Di2, the app crashing and other major issues.
Are those negative comments legit, or is it a situation where a small percentage of people who have experienced issues are writing negative reviews while the vast majority of eTube users are happy with the app?
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Quoted: 6971 Post(s)
Liked 10,967 Times
On iOS, no. The one time I had an issue, it was due to the wireless in my house deciding to conk out as I was upgrading firmware, and it "bricked" the battery module. Fortunately, because I have more than a couple bikes with Di2, I also chose to own a SM-PCE1 PC linkage device, and in about 20 minutes after running over to a buddy's house to get a PC, I had the system fully functional. If I had not had that option, I would have had to go to a bike shop to get it reset. But, that was one time over the last 3 years using the EW-WU111 in conjunction with the eTube app to program my bikes. The app is far more stable (on iOS) today than it was several years ago...I see no reason why it isn't the same for Androids.
Likes For Koyote:
Quoted: 532 Post(s)
Liked 621 Times
Koyote I don’t even own a PC...but I bricked a bike last winter, and with COVID restrictions here in Belgium, I couldn’t get into a bike shop for 3 or 4 weeks, so I bought the PC link device and borrowed a work colleague’s PC. Worked like a charm. I agree, I won’t bother with another attempt to do BT updates, now. But, I can dang sure do all sorts fo cool things....namely recover bricked Di2 now!
Likes For Badger6:
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
I once did a whole ride trying to conserve shifting. I think the display was blinking red at the start of the 50 miles? In any case, I didn't think it was enough to finish on that old battery. (But blinking red was probably okay for one ride.)
That was an "interesting" ride, where I was grinding in a low gear, or spinning to avoid another shift, even to the point of spinning up on the flats, coasting, and repeating. Not optimal.
Someone posted a list of Di2 "tips and tricks", some were quite good.
But one was for a dead battery: unplug your rear derailler, get your buddy with Di2 to unplug their rear cable, and temporarily plug into yours, then shift to a middle cog to have something reasonable for the rest of the ride. Heh. Yeah it could work.
Quoted: 532 Post(s)
Liked 621 Times
Quoted: 532 Post(s)
Liked 621 Times
Exactly. And when it fails, the system is D-E-D, dead. And, the normal charger won't bring it back, you need the fancy PC Link Device, which most shops should have. The recovery takes about 3 minutes, and of course your time to take bike to the shop and whether they will fit you right in or it gets to spend a few nights there...
Quoted: 974 Post(s)
Liked 512 Times
The Campagnolo electronic derailleur can be "unlatched" when dead, and moved to a different gear. By pulling on the derailleur body, I think? A nice design. I've never seen one around here.
Quoted: 942 Post(s)
Liked 527 Times
I've never had an issue with the IOS e-Tube app and have updated the Di2 Firmware several times. I have also used the maintenance function to dial in the indexing with no issues.
Re: Di2 battery not being reliable over BT. Yes I have heard that too, but your computer most likely connects to your bike via ANT not BT so the battery indication should be good.
To the OP....ask yourself this: If there was a small digital battery indicator that told you the % charge that was easy to install in-line anywhere you wanted...would you do it? If so installing the EW-WU111 is no different, you just get a whole lot more capability over battery level.
Likes For jadocs:
Bikes: two blacks, a blue and a white.
Quoted: 445 Post(s)
Liked 847 Times
As a gadget lover, I have to admit that I once thought I would get some kicks out of this "peripheral Di2 gear." Glad I saved my money. Over 6 years of riding, I don't think I've ever had reason to use any of it. I charge my battery when the FD stops shifting, never had a problem getting home without it. I get about 450 miles out of a charge so I don't need to check the battery much at all. The rig has never lost its indexing or given me a single problem (yeah, don't tempt the gods...). My highest complement: I don't have to think about it; it just works.
Quoted: 532 Post(s)
Liked 621 Times
450 miles? It sounds like your battery is nearing the end of its usable life. 6 years is good use, though!
I guess my thing from the beginning was hoping that I could find something that could give me that reading for free. I thought that maybe it was a part of the E-TUBE program or perhaps there was a free app or something out there that could give me that reading. It's just one those things where it would be cool to have, but not having it is totally fine as well. If the shifters or program didn't include the option, that would be a totally different story, obviously. As is, not really a huge deal either way for me.
Quoted: 445 Post(s)
Liked 847 Times
I'm a shift-o-phile. Always managing back into that 85-90 cadence. I'm wondering if, at some point soon, this "retro" battery will be hard to replace...should probably start looking into that.
Quoted: 590 Post(s)
Liked 445 Times
I have about 17k miles on my Ultegra Di2, and never once wondered what the exact charge level was. I typically charge it after ~1,000 miles, or if the flashing green light occurs when holding in a shifter button. Though I have been negligent and let the battery run flat twice in the past year, turning the bike into a single speed, which really sucks in a hilly area.
Quoted: 741 Post(s)
Liked 412 Times
Likes For colnago62:
Quoted: 532 Post(s)
Liked 621 Times
Interesting...and greta to know!
Now that I think about it, the two times I had a dead system it was the battery update failing, and thus, as GP said, it required a hard wired fix.
It seems that if we have an electronic shifter on our bikes we have already crossed the frontier. Three days ago my Bolt told me my Di2 battery was low. Yesterday it reminded me again so I charged it. Can’t get much easier than that.
Your Chevy Bolt reminded you to charge your bike?? very cool
Happy to help.
May I suggest that a wireless unit is useful for a whole lot more than just giving you a battery percentage in a data field on your cycling computer (on Garmins it displays in 10% increments until 20%, then it goes to 5%). With the BT module added, you can use the eTube app on your phone to adjust (program) the shifting, and it will also allow you to control certain cycle computers (Wahoo and Garmin for sure) if you have the Di2 integration buttons on your shifters (DA R9100, Ultegra R8000, GRX 800).
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,437 Times
That's still remarkably short. I've had mine since 2014 and live in a very hilly area. I get at least 1000 miles out of it, and re-charge when it starts to green-flash.
