Titanium cold setting
Quoted: 569 Post(s)
Liked 583 Times
Grandson loves to ride my Litespeed Firenze when he visits and he got a too good price on one he could not pass up. Rear wheel tracking was just off the NDS stay, 4mm off center measured at the stay bridge. Read some pro and con posts here and as I have done steel cold setting and I could secure both stays I gave it a go using my home made hanger straightening tool as a gauge and bending tool. Two photos and today's ride confirmed it is good. Don't think it much more difficult that steel, would not hesitate to do a hanger however can imagine opening up an older frame to 130 would be an adventure without a frame table.
Quoted: 4208 Post(s)
Liked 3,874 Times
This might be better posted to the frame builders forum...
All I see are drop outs that might not be parallel with each other. Their faces might be well centered WRT the main triangle, but we don't now that form these photos. Have you done the "string" test? Do you have wheels that are properly dished and true to use as gages? Do you have "H" type tools for drop out alignment? $mm of off centered rear end would be easy to see with a Park *** tool. Andy
*** is Frame Alignment Gage
AndrewRStewart
AndrewRStewart
Quoted: 140 Post(s)
Liked 163 Times
ti can seem haunted when you try to alter it, even something as simple as a bent hanger. That sort of thing is probably for the frame manufacturer, or at least a frame builder experienced with ti. I say "haunted" because I have "straightened" a hanger on a ti frame, only to come back to the shop the next day and find it right back to it's pre-straightened (aka bent) state..... Which begs the question, "why didn't it just go back to it's aligned state after being being damaged, if it's going to pull that "memory" stuff, lol.
Not to make light of the situation, but ti is quite different than other frame materials in terms of working it during the building of the frame and also post-manufacture, regarding repair.
Quoted: 569 Post(s)
Liked 583 Times
Quoted: 569 Post(s)
Liked 583 Times
Liked 3,874 Times
Correct, not disclosed in sale, dropouts were not square. String within 1/2 mm although I have little faith or understanding of it as Andy Gilmour in Tucson straightened a tweeked Reynolds 753 (Reynolds engineers said can not be cold set) frame and fork that is a beautiful ride with string way off. Used my nicest wheels, 1/2mm lateral and almost twice that radial. I would love to borrow a Park dropout alignment tool to see if the bolts I use work as well as I think they do. Thanks for the good point after an unknown crash or storage mishap not just focus on the obvious issue, I sould have everything checked. Andy has a Marchetti so he can check the frame alignment for us.
But your story of the 753 frame just shows that a straight riding bike is not a result of only one alignment aspect. As well as that many riders don't even notice some "offness" in their bike's tracking. I would love to get Andy's take on that 753 job to better understand what went on and what resulted.
As to cold setting 753 and Ti. it's not that it can't be done, or is never done, but the efforts are very high and the risk of something going wrong way expensive. It's far less risky and more cost effective to make the frame straight than bend it so. Andy
AndrewRStewart
AndrewRStewart
