Newbie has question: Why did my Rear Derailleur Bracket wear this way ?
Hello. I am new to Bicycling Repair. I have a Giant Mountain Bike with a Shimano RD M3000 Long Cage Rear Derailleur.
Can anyone explain why the Derailleur Bracket wore this way?
Thank you in Advance
The yellow arrow points to a notch worn by the chain
Quoted: 6193 Post(s)
Liked 4,809 Times
In that big/big combo, something is keeping your jockey wheel to far from the cassette. You chain if it's not continuously rubbing that tab is at least too close to it and slapping it too much. Or is it just on the wrong side of the tab entirely? I'm having trouble deciding since the DR has several wonky things going on.
Do you have the b screw too far in? The jockey wheel should be much closer to the gears. At least mine always are.
Likes For alcjphil:
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
That was my first thought. Bet the chain clattered a whole bunch.
Stuart Black
Stuart Black
Expired Member
Quoted: 3674 Post(s)
Liked 5,431 Times
Oooops....
Quoted: 1819 Post(s)
Liked 1,693 Times
You can solve the issue by routing the chain correctly on the original derailleur. The B screw isn't the problem
Liked 4,809 Times
https://si.shimano.com/api/publish/s...001-06-ENG.pdf
https://si.shimano.com/api/publish/s...001-24-ENG.pdf
Go here and put in the model of your shifters. The DM for them might be a little more detail for adjusting the shifting than the General DM linked above.
https://si.shimano.com/#/
At any rate, if the chain was regularly touching that tab, then that was your problem. You had it routed wrong. But your tab is on the backside of the DR and not the front side as mine is. So I'm really not certain from your pictures. But if you put the new DR on, and it touches any tab then you know it ain't right.
Really Old Senior Member
Go look at a bike you haven't messed with for correct chain routing.
Liked 1,693 Times
Nice to know that we were correct, can you explain how you figured that out? I only ask because I have been wrong in the past when I offered an opinion
Quoted: 1944 Post(s)
Liked 2,164 Times
I’ve often wondered what the function of that tab is.
Does the tab have any purpose for the guiding/keeping the chain in the cage? I’ve never seen any marks on RD cage plate tabs.
Or, is it just to add stiffness to the cage plate?
John
John
Very easy to do. I bought a new bike where the chain had been placed the wrong side of the tab. It took me ages to work out why I seemed to have this curious vibration, more noticeable in some gears than others. I was pretty unimpressed!
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
Looks like you now can just have it on the shelf for that someday you might actually need to replace the old one. Or replace it and keep the old one as a backup.
Quoted: 2482 Post(s)
Liked 2,955 Times
The one function of that tab is to prevent the chain's coming off the tensioner wheel during shifts or while riding on rough surfaces. The longer the derailleur cage, the more likely the chain is to bounce off the tensioner wheel.
Likes For Trakhak:
Liked 4,218 Times
It happens. Shimano has even swapped the tab around on some derailers so that if you route it the “right” way, it’s wrong. Damn Shimano!
Stuart Black
Stuart Black
Quoted: 2952 Post(s)
Liked 3,106 Times
Likes For caloso:
I wish I was 30 again & 5 hours of sleep a night was ok.
I would have more time to tinker with bikes.
All I can do is muddle through because house repairs &keeping the family cars running gets first priority.
Liked 4,218 Times
Good eye. It is a bit short. Shouldn’t have a kink in it like that.
Stuart Black
Stuart Black
Quoted: 966 Post(s)
Liked 1,629 Times
Whats embarrassing is I still can't see it... Rats!!!
Kinda like when the Grand Babies bring over those picture puzzles where you find a hidden item... Ha
Thanks I replaced the whole cable and I retuned the entire rear and...then I remembered how bad the front derailleur was shifting and I ordered the parts to fix that..only because of you guys on this Forum. Figured you guys were watching me down in the garage.
Likes For AJW2W11E:
Oh these days 30 years old nets you a couple young children and you have no time to play with bikes at all 😀.
