Can I fit disc brakes to a 1989 steel frame road bike?
Quoted: 71 Post(s)
Liked 18 Times
Update: I've decided I'll just try to get top tier rim brakes instead of disc brakes.
The title says it all, my bike has a vintage steel frame from 1989, I'm wondering if I can install disc brakes?
I'm not super confident in my brake pads' ability to stop me in a pinch, and I'd rather the disc solution as it requires less pressure on the brake levers to affect stoppage, as far as I understand it.. I recently took the regular, how would you call it, horizontal lever brakes off my bike to free up handlebar real estate, so I'm only using the brakes in my gear levers and I'm still getting used to it.
.. my wheels are campagnolo Zonda wheels - would they need specific brakes?
Note: I put this here because I'm not sure it is a road bike specific question? I dunno, hope nobody minds.
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times
Bikes were not dangerous before disc brakes. They don’t all need “upgraded”.
There’s lots you can do to improve your braking.
New cables and housing, lube all the pivot points. Clean the rims with 600-1000 grit sandpaper and alcohol. New pads, Cool Stop Salmon are loud and work great. Probably and afternoon of fiddling and $40. Less than $100 for a shop.
This would be your only real option and good news, it’s a good option.
To convert to discs, you’d need to stretch your frame to 130mm and find the mythical 130mm QR disc hub. Then get a mount welded or brazed to the frame.
Up front is a little easier, but a threaded 1” fork with disc mounts is not going to be easy to find. The 100mm QR disc hub does exist though.
TRP makes some great road lever/calipers. That’s another $300.
I think the conversion would be close to a grand and might not work very well.
Likes For rosefarts:
Quoted: 3952 Post(s)
Liked 7,297 Times
Likes For tomato coupe:
Quoted: 14 Post(s)
Liked 37 Times
I have both rim and disc brakes on my bikes. I would not spend the money to upgrade from rim to disc. In fact, I think I prefer rim brakes better all the way around.
Likes For Bosco13:
Quoted: 71 Post(s)
Liked 18 Times
For starters I would say that these brakes I've been using have been tuned up and such, etc etc, twice in the last week, er because I switched handlebars twice and they all got re-worked or whatever. They're not brand new brakes, but they've been serviced recently yeah.
The sensation I'm getting is this: I usually have my hands up top, I don't often find cause to get down into the.. dropped part of the handlebars? I am overwhelmingly doing urban riding over middle distances and getting down there just feels like it gets in the way of my awareness and reactions, maneuverability.. anyway so that means I'm using my brake levers with suboptimal leverage - maybe I'm depressing them halfway down rather than at the tips.. if you know what I mean.
So I give them a good squeeze, and the bike slows etc, but I feel like I need to really go wild with finger strength to get a really rapid halt. I'm worried that if I ever see a car or some such suddenly appear in front of me I'll not be able to stop in time. It doesn't feel ideal, but I don't want to put those regular hand brakes on the handlebars because I've got a light and cycling computer taking up space. So yeah.
You've given me food for thought about disc brakes though.. definitely.
Quoted: 1944 Post(s)
Liked 2,164 Times
I doubt you could ever mod a lightweight road fork to accept disc brakes. The cross section is probably not going to withstand the force. The solution is to replace the fork with a disc brake compatible fork. I'm not up to speed on who is producing 1" diameter disc brake road forks, but I'm sure they are out there.
As for the rear dropouts, I think you can get enough reinforcement brazed in between the chain stay and the seat stay to be able to use a disc brake. But a frame builder would be the one to let you know.
The last piece is the dropout width. You will probably need 135mm dropouts which can be done by cold setting the frame. Of course there will always be the argument of QR vs. Thru Axle and that throws everything out the window. Maybe not as much of an issue on the rear and lots of disc bikes ran QR's, so it may just be a debatable topic.
John
John
Likes For 70sSanO:
Quoted: 71 Post(s)
Liked 18 Times
John
John
Quoted: 1397 Post(s)
Liked 1,877 Times
Consider Kool Stop brake pads
Significant upgrade over old / hard brake pads
https://www.koolstop.com/english/rim_pads.html
Liked 2,164 Times
I don't see any more of an issue going over the bars on an older 25lb steel bike than a new 15lb carbon bike with disc brakes.
John
Liked 1,877 Times
this is my primary motivation for installing lightweight components
With a mighty wind
Liked 862 Times
It sounds like you aren’t getting much leverage from the hoods. I have that issue on a bike I ride that’s a similar age.
My newer bikes, even the ones with rim brakes have a totally different lever design that allows a lot better braking from the hoods. It’s still best from the drops but is acceptable on the hoods.
Does your bike have integrated shifters and brake levers? Or do you have downtube or barend shifter?
If they’re not integrated, you can replace with a more modern style lever that’s a lot more comfortable on the hoods. I did this on a bike once, used relatively cheap Tektro levers and was pretty happy.
A higher quality cable and housing set can also help. Jag wire or Shimano are pretty good.
There are so many things I’d do, including selling and replacing with newer, before trying to convert this to discs.
Quoted: 427 Post(s)
Liked 699 Times
Will your bike accept mini-linear pull brakes (also called v-brakes)?. if unsure that they will work on your bike with the existing levers, check with your LBS. If they will work, then those with Kool Stop Salmon pads should offer plenty of stopping power.
Likes For freeranger:
Quoted: 3511 Post(s)
Liked 2,926 Times
Get some compressionless cable housing and some dual pivot calipers (if you don’t already have them).
Likes For smd4:
ignominious poltroon
Quoted: 2239 Post(s)
Liked 3,434 Times
Within the confines of sanity, I would say you could buy a new disc compatible fork, and have a front disc brake.
However, the stopping power with my dual-pivot $40 Campy Veloce rim brake caliper upgrade is probably at least 80% as good as the Ultegra disc brakes on my modern bike.
Quoted: 1562 Post(s)
Liked 1,734 Times
I vote for new pads. If you have old, hardened pads, they won't stop you well. Get some Kool Stop salmon pads, they will stop you much better. If you really want discs, it's more economical to get a used bike with discs than to convert your current bike.
Likes For BlazingPedals:
Quoted: 71 Post(s)
Liked 18 Times
I just remember on the hand brakes I could really crunch down on them and bring my bike to a stop, but with these brakes it feels like I'm kind of doing the brake equivalent of dragging the soles of my shoes on the ground up slow down
Ehh maybe I'm just still getting used to the different feeling, it's only been a month or so since i took off the hand brakes.
SE Wis
Quoted: 2747 Post(s)
Liked 3,395 Times
1989 frame is not going to accept, nor was it built for the forces of disc brakes. A pair of dual pivot caliper brakes with the correct reach and mount (nutted or recessed) with kool stop pads, new cables, as well as cleaning the rim braking surface will be the best, most reasonably priced, brake upgrade to a frame of that vintage.
Likes For dedhed:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
The simple, practical, sane answer is no. Your wheels aren't disc compatible. Your frame/fork aren't disc compatible. It would cost so much to make it work that it's just not worth thinking about.
Likes For cxwrench:
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,899 Times
Okay, "Hoods" are the rubber covers that go on the LEVERS. So, you say you got new 105 "Hoods", do you mean new levers? What kind of brake calipers? How old? If they're from 1989, they're probably single pivot, which aren't the greatest, and if the pads are the originals, they're probably hard, and could be replaced with new ones.
There's a possibility that if you've got NEW levers and OLD calipers, it's possible the levers don't pull as much cable as the calipers need. Mixing eras doesn't always work well. If you have modern levers, you might try getting modern calipers.
But, yeah, what cxwrench said is correct - fitting disc brakes safely requires a ton of work, and I bet you could solve the problem with new pads, cable and housing, or new calipers. Good pads on clean alloy rims should be able to skid both wheels without Hulk-like strength.
Likes For genejockey:
Quoted: 71 Post(s)
Liked 18 Times
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
Cheapest and most practical way to upgrade your braking is get good quality brake shoes and pads ideally from one of the stop like KoolStop or SwissStop. You want good stiff shoes any flex in the system will lose you out on braking power and good replaceable pads with a good rubber compound in your case probably something S-group compatible. Then you want to replace your cables and housing, you want a good compressionless housing, I do really love Jagwire on this front ideally Pro or Elite, their Link housing is really nice and also quite light and flexible. For the cables you want a good stainless steel polished uncoated cable luckily Jagwire makes kits that have everything you need in one package.
Also make sure your rims are nice and clean with isopropyl alcohol and everything is nice and smooth.
If you are still having issues you could look at the brakes and get really spendy with the Cane Creek eeBrakes and some nicer levers (SRAM S500s or S900s are really nice) but that is an expensive proposition.
If you are really desperate and those aren't cutting it get a bike with disc brakes already. Vintage bikes like yours aren't designed for disc brakes. If you want disc brakes get a bike with disc brakes but make sure you also have a decent groupset on it. Claris is one notch up from their bottom of the range Tourney it isn't worth much and doesn't work all that well but certainly hits a price point and that is about it.
Likes For veganbikes:
Quoted: 6963 Post(s)
Liked 10,963 Times
No.
Likes For Koyote:
Hell of an answer there...
I would be a hell of a lot cheaper to get an auxillary bar to attach your light and computer and put the extenders back on. You are talking about protecting yourself on an instantaneous stop. In such situations you will be limited by the friction of your tire with the road. Discs and hydraulic discs in particular come into their own for sustained braking such as on a long single track downhill on a mountain bike. They will not be that much better in stopping you in an instantaneous situation because you are going to lock the wheel with respect to the ground.
Likes For kommisar:
Quoted: 71 Post(s)
Liked 18 Times
My bike is a bit of a frankenbike but everything is Shimano 105 or better.
I just reverted to this bike from a 2021 aluminium one, so I'm going to stick with it I think.. the wheels are a week old too so I don't think the rims have had much chance to muck up
I think my next objective will be Kool stop pads and some high tier hardware throughout.
The bike is a "Tange Prestige" so it's pretty special, I'll not push for disc brakes it it messes with the frame, so yeah that's that
