Any carbon framebuilders around?
I'm an am amateur to framebuilding (but learning fast!), currently riding my first carbon frame, building my second, and designing my third.
I'm wondering if there are any other, more experienced carbon frame builders on this forum willing to share some information and experience. I'm especially curious about preferences when it comes to bottom brackets, dropouts, and bottle bosses, as well as monocoque vs bonded tube constructions.
Randomhead
Liked 3,698 Times
I don't think we have anyone that posts here regularly that works with carbon. I always wanted to build carbon frames. I even took a class on composite materials back in 1981. That was a mistake, the professor talked me out of building frames.
Quoted: 4205 Post(s)
Liked 3,864 Times
Over on Velocipede Salon there's a few that do. Or there's a few who in the past have posted. None that I remember ever talked about teaching though. Andy
AndrewRStewart
AndrewRStewart
Quoted: 321 Post(s)
Liked 263 Times
I've made a steel frame with a carbon TT and DT going into "lugs" that I welded up. I don't think there's much benefit to this over just using steel (actually I prefer steel) but it's what the friend I was making it for wanted. But this probably isn't relevant to what you're trying to do.
But if you want to post about it I will be interested to read it!
Quoted: 4408 Post(s)
Liked 1,561 Times
On Velocipede there was a tutorial posted by a guy who made tube to tube carbon frames commercially. He showed how he used sanded filler to blend the joints and then over-wrapped them with carbon. Lot's of good detail. I forget the brand.
For a more basic technique, there are lots of pics out there of Calfee's method using carbon tow for building customs like tandems or working with bamboo. The joint is a big knot of tow that is ground smooth after it has cured.
I've always wanted to try doing it with carbon socks, like how fork crowns used to be made.
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 670 Post(s)
Liked 974 Times
Serotta did it back then ,now I don't know who does carbon custom frames.
Randomhead
Liked 3,698 Times
It was Nick Crumpton
Quoted: 49 Post(s)
Liked 13 Times
It was Crumpton. The whole process actually is quite simple. There's a limited number of ways you can wrap carbon around a lug
Even with all the theory on how to do it you still need to actually be able to execute the idea yourself.
You'll see a lot of carbon work done by people who know what needs to be done but struggle to actually execute the process.
Likes For Canaboo:
Liked 1,561 Times
https://www.velocipedesalon.com/foru...ing-18058.html
Liked 3,864 Times
AndrewRStewart
AndrewRStewart
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
Found the thread, but the pics are, indeed, gone.
https://web.archive.org/web/20220627...ng-18058.html?
Bikes: many
Liked 1,392 Times
Also, Tim Massengill does (or did) custom carbon fiber frames. He's good friends with Doug Fattic who can probably put you in touch.
Quoted: 49 Post(s)
Liked 13 Times
Here's an article that shows a lot of the process used by Crumpton. https://pezcyclingnews.com/technspec...rbon-crumpton/
To me the joints could be made to look a lot neater.
ETA. This is an old article and I will say his bikes do look much neater on the lug joints now. I believe he no longer uses woven carbon on them The build along that disappeared showed unidirectional.
Thanks for the responses everyone
My first frame was monocoque using a 3d printed core instead of a foam one. My result was not the best aesthetically, but was rideable (its still my daily rider today). I would have liked to had done a tube+lug construction but at the time (pandemic + college student budget) it came out cheaper to buy all the carbon and do it monocoque.
Recently I've gotten back into carbon fiber as I'm working on a carbon cargo bike build and experimenting with some other carbon fiber component projects. And I've discovered a lot of interesting people doing interesting things with carbon fiber out here in eastern europe.
Likes For kooby:
Sorry for the long wait
Here is the top tube being printed.
Here are all the core parts glued together and mounted in my low-tech jig. The HT, BB, and seat cluster were printed from plastic mixed with carbon fiber for some added strength.
Here's the final result. It doesn't look great, but it rides pretty well and was a great learning experience
A lot of the lessons I learned building this bike have helped me with deigning and working on my current project I'm working on.
framebuilder
Likes For Doug Fattic:
Quoted: 2338 Post(s)
Liked 2,822 Times
maybe check out some facebook groups....I see people popping up on framebuilders that do carbon
