Inner tubes
Quoted: 7 Post(s)
Inner tubes
I just purchased new tyres 2.60" and could not find inner tubes bigger enough. Only could find for 2.40". Is it possible use these inner tubes?
Likes For Jeff Wills:
Quoted: 4205 Post(s)
Liked 3,863 Times
Agree with Jeff. The usual worst case is a slightly faster leak down over the days/weeks after inflating. It you ride with too low an air pressure the tire can creep/shift around the rim and the tubs valve being trapped by the rim hole will stay put and the tube will get stretched on one side and might bunch up on the valve's other side. But this happens due to too little pressure and not tube fit. So just keep the air pressure topped off before riding. Andy
BTW running a slightly undersized tube has been a BMX racing trick for many decades. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 2604 Post(s)
Liked 1,933 Times
Quoted: 837 Post(s)
Liked 1,061 Times
2.60" is roughly about the same as 65mm so if you look at the ISO sizing probably also listed on your tire you can do a search for that size as well. Great article on sizing here. Tire Sizing Systems (sheldonbrown.com) A little long but not necessary to read the entire article. And would agree a 2.40" tube will be fine as well.
Liked 3,863 Times
On a smaller tire I'd agree wholeheartedly. But what about the fatness of the tire? I've seen some stupid-low recommendations for tire pressure with wider tires. I don't know where the inflection point would be between "no problem" and "the pressure of a XX tire is too low to keep the tube in place." Do you have any information on how wide a tire or how low tire pressure can go before one runs into the problems you described?
AndrewRStewart
AndrewRStewart
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
Buy 2.4 tubes for spares. The 2.6 are huge and take up lots of volume.
Quoted: 6193 Post(s)
Liked 4,809 Times
Is there more writing on the box that might give us more information about them? ABC inc. inner tubes might be different than XYZ inc. inner tubes.
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
The tubes do exist couldn't point you towards them because we don't know what size you need. However you can always go to the shop you purchased the tires from and they will have the tubes or can get them if for some reason they don't carry tubes for the tires.
Yes sometimes running a smaller tube is fine but I would rather have the correct size. The only reason to run the wrong size tube is in an emergency situation or if you are running Tannus inserts.
