Gp5000 S TR actual size with wide rims
Advocatus Diaboli
Quoted: 4756 Post(s)
Liked 1,537 Times
Of course, making tires that are really wider than their nominal size, makes it easier to win the rollingresistance online reviews that compare results by nominal, and not actual sizes.
Regarding the width of the wheels. I'm planing to buy Elitewheels carbon wheels. Now I have endurance road bike, Giant Contend, where maximum tyre width is 34mm. In future, maybe in two years, I'm planning to buy gravel bike.
Elitewheels gravel carbon wheelset has 24mm internal width and 31 external. So, if I buy 30mm conti 5000 STR, it should be just about 34mm real width? So I will be able to use this wheelset now and on future gravel bike with even wider tyres.
Quoted: 4481 Post(s)
Liked 4,952 Times
Most of them are now true to their nominal size on 19 mm internal rims. There was a time not that long ago where some brands were quoting width on narrower rims, which made them much wider on modern rims, but I think all the big brands have updated now. They still usually measure up a little wider than nominal on 20+ mm rims.
Bikes: SL8 Pro, TCR beater
Quoted: 1003 Post(s)
Liked 588 Times
My 28mm measure 29mm when inflated on 21mm internal width hooked rims.
Would say they would be true to size on ''standard'' internal width rims (19mm?) and would be another 1mm wider if they would be on 24mm internal width.
Hello.
First post. Can't find answe using search propably just not using it right
Just bought GP5000 S TR 28mm (front) and 30mm (rear).
Installed them for my new Nextie aero wheels, hooked and inner width 24mm.
Tubeless installation and pressure approx 4.5 bar.
After first 100km tire actual width measured in front little under 31mm and rear 33mm.
I bought this model because many review says that this S TR is more true to size than older models but seems that it's not true.
Could there be difference between batches or is this common with extreme wide wheels?
Thanks
I'm still not sure, should I rather take 21mm Internal width. It says, that I can still mount 42mm tyres for gravel on this 21mm wheels, but it's the maximum width. Allthough, I think 42 is enough for gravel. Just hope it won't look weird in narrow 21mm rims.
Liked 588 Times
If I had the choice, I would take 25mm internal width for gravel usage for sure.
