cassette swap: will i need a new chain?
No, your OTHER left!!
Bikes: 2 motos and a schwinn (road bikes more or less)
going from a 12-26 to an 11-28. the chain only has about 350 miles on it. Will it need to be longer? or am i all set? Oh, both are 9 speed if that makes any difference.
THANKS!!
andy
THANKS!!
andy
Quoted: 1572 Post(s)
Liked 644 Times
Probably you'll be OK. If it was my bike I'd gently shift into the big/big combination to be sure the derailleur has a bit more take up slack.
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
How old/worn is the cassette? It's generally a good idea to replace chain with cassette or else the worn/stretched chain will prematurely wear the new cassette.
chain and old cassette only have like 350 miles... no wear as far as i can see. sound ok?
andy
andy
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4344 Post(s)
Liked 3,004 Times
Yeah your chain is probably fine but the length might not be. But put it on and check big-big for enough chain, and small-small for enough wrap to make sure the chain is sized OK... if it's borderline tight now, it might be too tight with the new cassette, and if it's borderline loose now... too loose.
don't be attached to chains, they should be replaced frequently
to keep from prematurely wearing down the rest of the, more costly, drivetrain ..
Constant tinkerer
As long as the chain hasn't been through rough, dirty use it should be fine with the new cassette. 350 miles isn't that much if it was kept lubed.
Just check the chain length in the big-big and small-small combonations as noted.
Im really good about keeping the chain clean and lubed... I guess i was mainly concerned about it being too short with the bigger cassette... sounds like most likely it will work ok
andy
andy
Quoted: 5866 Post(s)
Liked 2,712 Times
Why don't you just measure the chain instead of guessing. I suspect that it'll be OK, but you could measure and know for sure in less time that it'll take to get a bunch of meaningless opinions here.
If over 12" it's stretched less than 1/64" or so (eyeball 1/4 or the way to the 1/16" mark) go ahead and use it. if it's worn beyond that, switch it out for new, but save it and rotate it back into service when the new chain catches up, or passes it slightly. Thereafter adopt the two chain system leapfrogging them back and forth until both are stretched.
BTW- if you have noticeable stretch after only 350 miles, you need to rethink how you lube and maintain your chains, because your system isn't serving you well.
Note, 2 extra teeth will need 1/2" more chain, so if your chain was measured super close for the 26, then it may be too short for the 28. Then again this is also something you could measure rather than guess.
FB
Chain-L site
FB
Chain-L site
I guess what i was trying to get at in the first place before all these posts about chain wear, was whether or not the 2 extra teeth on the cassette would require me to buy a LONGER chain... I guess i wasnt to clear on that.
thats mainly what i wanted to know...
Thanks to everyone for your assistance
Cheers
andy
Liked 2,712 Times
Cheers
andy
Cheers
andy
If it looks OK, switch cassettes, but confirm that the chain is long enough by going to big/big and double checking that the RD isn't pulled to it's limit.
FB
Chain-L site
FB
Chain-L site
The latter part of my post covered that. 2 extra teeth on a cassette call for 1/2" more chain, It's easy enough to check on the existing cassette. shift to the bib/big combination, put a ruler against the lower loop and see if you can pull 1/2" of chain forward (make sure the crank can't turn) out of the RD cage.
Thanks so much!!!
andy
Thanks to everyone that helped out with my Q. The new cassette arrived today, and i am happy to report that i swapped it out without a single hitch. shifts perfect, didnt even have to adjust the RD... and also, the chain is still long enough and has slack on the largest rings.
Loving the new setup and Thanks again!!
Cheers!!
andy
Cheers!!
andy
