Is a SRAM AXS mullet worth +$1k over GRX 1x mech?
Quoted: 60 Post(s)
Liked 33 Times
Through some small miracle, I was able to secure the components for either setup on my Salsa Cutthroat. I absolutely cannot bring myself to open the packaging for either!
Option 1 is GRX 1x with an ethirteen 9-46 cassette, vs option 2 Force AXS shifters/GX derailleur/10-50 cassette. On the GRX set up. I might run a tighter cassette for less extreme rides (likely GX 10-42).
Both have a similar range and I understand the gaps are bigger on the 11 speed set up. Barring that, and any general Shimano/SRAM general preferences, it comes down to roughly $1k more for the AXS set up. Value is of course a relative concept I guess! I can afford the AXS setup, but obviously saving money is nice especially if it means nicer wheels or other upgrades.
Pros of the GRX....Im used to working on Shimano, i have back up brake pads, changing cables is no big deal.
Pros of the AXS.... set and forget (no cables), smaller steps between gears, maybe more future proof?
Any thoughts are appreciated!!
Bikes: Niner RLT RDO, Trek Remedy 9.8
Quoted: 108 Post(s)
Liked 117 Times
If it was me: I also am used to Shimano and I don't like remembering to charge stuff before a ride. And like you said, more money towards a nice wheelset.
(having said that, I have never ridden SRAM extensively and have never tried their wireless stuff)
Likes For tdilf:
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Based on what you said, Shimano. You already have spares, and you already know their systems, and their brakes (I assume you are also familiar with) are a bit easier to work on. As for future proof, 11-speed will be around a long time, you'll be ready for a new bike or a new group before you can't source Shimano 11-speed parts.
Likes For Badger6:
Bikes: 1984 homemade 531SL road bike; 1988 Ritchey TimberComp; 1997 Nashbar tandem; 1998 Kona Explosif; Specialized Epic, Scott CR1 Pro; Salsa Beargrease; Curtlo custom Tandem, Curtlo custom S3 steel gravel bike.
Quoted: 67 Post(s)
Liked 49 Times
Have you counted the cost of eTube wires at $27 each ($150), junction A ($115) and B ($30), battery ($125), Bluetooth module ($90) and charger ($125)? That is almost $700.
Quoted: 60 Post(s)
Liked 33 Times
I have Di2 on my road bike and the biggest draw for me initially was not having to worry about the front derailleur in full synchro mode! If I go GRX, it'll be 1x mechanical.
Quoted: 1221 Post(s)
Liked 629 Times
SRAM will be 12s, GRX 11s? SRAM seems to be the pioneer for 1x stuff, and the wireless would be super nice. 1x for gravel/road I'd want as many gears as I could afford.
Personally I'd go with 12s Shimano if I could get it (just Ultegra and dura ace for now?) or Campy Eckar.
I ride 11s 105 so probably should ignore me
That $1,000 saved would go a long long way towards nice shoes/tires/bags!
Likes For GrainBrain:
Expired Member
Quoted: 3674 Post(s)
Liked 5,432 Times
Likes For shelbyfv:
Quoted: 60 Post(s)
Liked 33 Times
This is where I'm leaning I think. Thanks all for the advice!
I have no doubt that AXS is nice but I'm definitely having sticker shock With GRX, I know I'll still have a super reliable setup, I can have communal backup parts with my Ultegra Di2 bike (calipers, rotors etc) and it'll play nice with the 11 speed on my trainer.
I do have this impending sense of FOMO though if I don't go AXS, but maybe that'll go away if I buy some super nice wheels!!!!
Quoted: 60 Post(s)
Liked 33 Times
If they come out with a semi-wireless GRX 12s Di2, then I wouldn't have this analysis paralysis!! They'd already have my money!
Thread Killer
Quoted: 3143 Post(s)
Liked 1,707 Times
Quoted: 60 Post(s)
Liked 33 Times
SRAM have a beta program going for AXS, so I’m guessing it’s going to be a format which sticks around for awhile. In any case, GRX 11spd is already out-of-date with semi-wireless 12spd Shimano here, so I’m having a hard time following the logic in eschewing fully wireless 12spd for 11spd mechanical if future-proofness is an issue. We also already know that 13spd is possible within current design paramaters (i.e. frame spacing, hub body length), so it’s simply a matter of software updates on AXS hardware to make them 13spd compatible when SRAM moves to 13spd, which they almost certainly will given the history of drivetrain evolution.
12s Shimano GRX hasnt been announced to my knowledge, and I want to go wide range 1x so Ultegra 8100 isn't really an option even when setting aside concerns of cost or availability.
Sunshine
Quoted: 10964 Post(s)
Liked 7,490 Times
In a short 12-15 years from now, Claris will be 11sp, but it wont matter because we will finally have the hoverboards from Back to the Future and thats all anyone will want to ride.
Quoted: 60 Post(s)
Liked 33 Times
You and I have very different definitions of what 'out of date' means. I view that as meaning old fashioned or expired. 11sp is still being made and Shimano has said they plan to continue to make it.
Thread Killer
Liked 1,707 Times
I'd argue that mech GRX can be considered somewhat future proof because it's still easy enough to find 10s speed Shimano stuff when we've been rolling on 11s for a while now. Future proof doesn't necessarily mean it's top of the line. I'm not trying to to be argumentative, just running through some of the thoughts I've been stewing on for a bit.
And in regards to Shimano 12, I was referring to the fact that it’s here in Dura Ace and Ultegra, which is exactly why 11spd GRX is already out-of-date. The new semi-wireless Di2– let’s call it Di2E, the E for evolved, to use Shimano’s lingo— has made the wired Di2 obselete, and I’d wager that within 2 years we’ll have 12spd Di2E GRX, and fully wireless Dura Ace 13spd, like AXS, within 4 years.
Quoted: 60 Post(s)
Liked 33 Times
I’m not sure I follow the logic of calling replacement parts “future-proof”. I rather consider future-proof to mean, particularly in the context of bicycle drivetrains, that a given component will work with new systems in the future. For example, if I wanted to move from an 11spd system to a 13spd system, is my hub future-proofed and will accept the necessary freehub? Will my derailleur and shifter be adaptible to the 2 extra gears, or will I need to replace those if I want to upgrade? I mean, you can still get Shimano 7spd freehub bodies, but they’re not gonna run even 22 year old 8spd cassettes, let alone the 12spd Shimano is on now.
Thread Killer
Liked 1,707 Times
Thread Killer
Liked 1,707 Times
Thread Killer
Liked 1,707 Times
II get that, but my point is that’s not saying much. 7, 8, 9, and 10 speed Shimano stuff continue to be available, up to many decades after they were introduced. It’s not the number of speeds which “future-proof” should refer to, because that practically has no meaning, IMO.
Quoted: 60 Post(s)
Liked 33 Times
Thread Killer
Liked 1,707 Times
As I said, I understood what you meant, and was pointing out that it was not much of a relevant basis for decision-making, IMO.
Thread Killer
Liked 1,707 Times
Likes For chaadster:
