Do I want a front basket for my particular needs?
I tend to carry only a few items when I ride, including a u-lock and laptop in a backpack (It's not a grocery-getter or anything.) Even so, I'd like to get this stuff off of me and onto my bike. I'm thinking a front basket would be adequate for an average-sized backpack load, and it would allow paranoid me to keep an eye on my stuff as I ride. It might also keep the backpack higher up from ground level, which may or may not reduce bumps and shocks to it.) Also, my hip isn't so great at swinging a leg over a rear basket or crate when mounting my bike, which makes a front-load option seem more attractive to me.
Questions:
1. How much will front-loading the bike affect response/steering?
2. Would an ultra-lightweight basket (wicker, etc) mitigate this problem?
I imagine different bike geometries handle front loads with varying success; this is the bike I'll be equipping:
Questions:
A Wire basket with support struts to the fork tip under it, or front Porteur rack that is solidly Mounted, will make the steering response Predictable .
but if your load carried is to be only about 2Kg then something light may be fine . but the items you list will exceed that .
I like Pauls Flat bed for its near universal mounting and its USA made Quality . Flatbed from Paul Component Engineering
Though Wald baskets are OK too Front Baskets - Waldsports
Quoted: 19 Post(s)
Liked 7 Times
I fixed a basket using the Rixen and Kaul bolt-on kit. Very solid, secure, light, fits any basket.
Wicker is nicer than metal. Basil make lots.
Bikes: Raleigh Port Townsend, Raleigh Tourist
Quoted: 36 Post(s)
Liked 11 Times
I have the Wald Delivery Basket on one of my bikes and have had over twenty pounds in it a few times.
Questions:
Questions:
I have always liked the look of wicker as a front basket. It reminds me of the golden days of biking.
But due to the value of my load (puppy) I went with Wald 157 Front Giant Delivery Bicycle Basket (link below). Best price I could find and free shipping. YMMV
https://www.amazon.com/gp/product/B00...XK7BKKTT564UJB
I have had 30-40lb backpacks in it with no effect on the ride. A pillow and a small blanket and my puppy likes it just fine.
My biking buddy. Sorry no pics of her on the bike.
Hmm, it looks like my particular bike might not take a bolt-mounted front basket after all; the only set of eyelets it has down there are for the front fender. So I guess it makes sense to get a front rack that attaches to the brake bosses instead. This would allow me the same versatility as a rear rack as far as strapping a variety of baskets, panniers, pizza boxes, etc. onto it.... Anybody going that route?
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
Drilling your own holes is not something you should do without experience.
Wicker baskets are for LOOKS. They are practically useless otherwise and you don't want them...trust me.
Looking at your picture I can see the Wald 139 should be fine and it the arms are too short they can be had in many lengths, see the LBS, they are replaceable and can be ordered. You can also get longer mounts to put the basket out ahead further as well. If the bottom is in the way of brake hardware or fenders then either longer arms/mounts are needed or you need to chose a different size or style of basket.
Don't leave out the option of dual rear mounted 'paperboy' baskets OR bags as they carry their load over the drive wheel and don't unduly influence the steering. You have a lower stepover height that makes it easier to get on and I just tilt the bike inward and down lower, plant my foot out slightly and get it over. If that is still a problem I would recommend using the curb and place the bike lower in the gutter or using the parking space barrier in the parking space. Having a low stepover isn't really the advantage it seems to be if you need a taller seating position for a nominal stroke while pedaling but I sometimes nearly lay it down while stepping over anyway. My bikes are pack mules as well so I adapt.
My LBS says the Wald 1392 (same thing as the 139?) will work for what I need, but recommends that they either find some way to fasten it to my (unused) front fender eyelets or attach it with P-clips. Which method would be smarter and more secure? How much weight can I safely carry this way? 15 pounds, maybe?
Quoted: 7348 Post(s)
Liked 2,470 Times
Maybe up to 25 pounds. It depends. You'll figure it out eventually.
