Marine Grease
Bikes: Own: Fito Modena II 3sp, Schwinn Drifter (wifey's), Schwinn Top Speed (6yr old son's) Owned: Garbage find Yellow Banana with shifter, Huffy BMX, Winnebago BMX, Refurbed a garbage find Raleigh FS frame, Dyno Dtour, DB Avalanche, Specialized Hard Rock
Marine Grease
I just purchased some BIG BOX store Schwinns, and want to do maintenance sweep thru. Is it ok to use marine grease in the crank and head set bearings?
Thanks
Thanks
Quoted: 4806 Post(s)
Liked 3,928 Times
Yes. It works just fine. The cranks won't spin as freely but you won't notice pedaling. Big advantage - if you use enough, water and dirt will not get in even if the seals are poor. (Big box Schwinn; they probably are.) Also marinbe grease is cheap so using a lot doesn't affect wallet size. Drawback - plan ahead and work cleanly. The stuff is almost as detergent/solvent resistant as it is waterproof.
If you do a good job, it holds up for years.
Ben
Ben
Thanks, was asking cause i have a tub of it. Definitely messy, I'll be using latex gloves.
I also use marine grease because cheap and durable (I hope). I got one of
mini grease guns and it is really clean to use.
I didn't consider it may be hard to get out since it is more resistant to water and solvent. Also didn't consider it having more friction. mmmhhhh.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Marine grease is a perfect lube for bike bearings. I have a suspicion that the tubes of designer cycle greases were filled from a drum of marine grease.
Quoted: 4560 Post(s)
Liked 2,802 Times
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
I'd argue that complex lithium soap based grease has better properties (and a bit higher price, but not outrageously - 800 g can for about 5 euros), but marine grease is perfectly fine.
Mostly harmless ™
Liked 216 Times
Modern ones (last decade at least), with all the additives, have similar water washout resistance, lower cold working temp (important to those riding in freezing winter), don't dry out as quickly... though for bike bearings, as long as they're cleaned and re-lubed annually, most any grease will be fine. Having said that, not all the "marine" greases are the same either.
Forgot how bad it smells, was raining this weekend so had to do it in the house... Open the windows... But got it done.
