Decent budget tire
Decent budget tire
Hi there. My allowance just arrived and I got impatient and decided to swap out the tires on my road bike. They've got 25 mm Ultra Sport IIIs at the moment (from the 28 mm stock Giant tires which felt dead and heavy) but I want to go back to 28 mm because the roads where I live in can sometimes be brutal. Think of this (photo not mine).
My frame can fit 32 mm but I think I'd be sacrificing a noticeable amount of speed at that point so I decided that 28 mm is the sweet spot (also most 32 mm tires I can find here are touring tires like the Schwalbe Marathon). I also considered getting a race tire like the GP5000 (GP4000 are super rare here nowadays) but, as a cash-strapped college student who doesn't race and only rides on the weekends, coupled with the kind of roads I ride on, I think it's too much for me.
I do ride at decent speeds (30-40 km/h on flats) so I want something that at least rolls well. Second consideration would probably be puncture protection, although it should be noted that I haven't had a puncture riding the Ultra Sport III that I have for 2000 km. All that being said, I've narrowed down my tire choices to either get another pair of Ultra Sport IIIs in 28 mm, or get another model from Continental which are the Grand Sport Race. Looking at their specs, they seem to be identical aside from the tread pattern and the presence of a puncture belt on the Grand Sport Race, which also costs around 4 USD more than the Ultra Sport where I live. The puncture belt is NyTech and I haven't read anything about how it performs.
Unless someone can convince me to still get the GP5000s or other tires, these two are the tires I'm considering at the moment. Thanks a lot!
P.S. Schwalbe Pro Ones are 12 USD cheaper than the GP5000s but still, that's a single tire for two Ultra Sport III tires.
Quoted: 3032 Post(s)
Liked 1,198 Times
Just put some Continental GP5000 on my new road bike. Had them on the last road bike as well. No regrets.
Look around online...you can find Continental GP5000 for about $45 each. The Tubeless version will be about $65
Likes For prj71:
Bikes: SL8 Pro, TCR beater
Quoted: 1006 Post(s)
Liked 588 Times
28mm Schwalbe Pro One. Much better than the Conti crap.
My OEM Giant/Cadex tires were great, but not as close as the Pro One.
Quoted: 20810 Post(s)
Liked 9,456 Times
Sunshine
Quoted: 11028 Post(s)
Liked 7,576 Times
The Ultra Sport III is both inexpensive and has good rolling resistance. At the limited budget you are talking about($20/tire), just get those tires and call it a day. Anything else will probably be worse for rolling resistance.
...or just use the 25mm tires and save up for faster rolling 28mm tires. The 15' section of road you highlight is bad, but immediately following it looks perfectly fine. Just pick your line.
Likes For mstateglfr:
Likes For prj71:
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
However, they do make a broad range of tyres, according to what you need: speed, durability, grip, price, etc. This is true of all tyre manufacturers - look at Michelin, Vittoria, etc.
I've got Conti UltraSports on one bike, and find them pretty darn good overall; however, if I compare them to the Vittoria Corsa G+ on another bike, they aren't as nice (fast, light, grippy); but the Vittorias are 2x the price.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
For robustness I like the Michelin Power Protection+, which comes in up to 28mm and has a high TPI casing with bead-to-bead Kevlar, and laughs off embedded flints and glass (I still take them out before riding). They’re way more robust than the GP5K, but slower. And not tubeless, which I couldn’t tell from your OP if you found important.
Quoted: 6257 Post(s)
Liked 4,860 Times
Is that picture of the road just one patch you go through or is that most all your ride?
When you say that your 28 mm Giant's felt dead, did you try different PSI's in them? With any tire, I'd try everything between max PSI and min PSI to find what feels the best to me.
Liked 1,198 Times
In all fairness...the giant tires suck. I know what he means when he says they feel dead. As do the Bontrager line of tires that Trek puts on their bikes.
Likes For prj71:
Yep. I don't know but they just feel sluggish when turning and are very heavy, probably because they're wire bead. The casing seems to be thinner than the Ultra Sport, too, even if the latter is more worn. The difference in road dampening between 25 and 28 mm, though, is noticeable, hence why I want to bite the bullet and get 28 even before my current pair wear out. But yeah, it seems wasteful.
Quoted: 883 Post(s)
Liked 729 Times
32mm on those type of roads will not be calcuably slower. And if you don't ride a lot, you won't be wearing out a premium tire like the GP5K. Definitely worth it. I have a pair on one of my bikes (tubeless version) and love them. I also currently have a set of Schwalbe Pro One 25mm tubeless (not the new version) on a different bike and they seem fine, but by many accounts GP5Ks last longer than other tires in its performance category unless you ride in conditions where sidewall cuts are a concern.
Quoted: 988 Post(s)
Liked 1,653 Times
In the future you might want to consider a cheap wheel set that you use on your torn up roads with your wider tires and save your fast wheel set for those special rides...
Edit: Sorry, in reviewing the post I see you have disk breaks. I believe this makes it harder to switch out wheel sets like we used to.
Likes For zandoval:
Liked 9,456 Times
Quoted: 1463 Post(s)
Liked 1,488 Times
Just tossing my vote in the hat for Conti GP5000's. They are not the cheapest, but well worth it.
I have 28mm tubed version on one bike and 32mm tubeless on the other. The 32mm tubeless is an awesome setup that gives me a fast rolling supple road tire that can still handle summer/dry/hardpack gravel.
Thanks for all your replies! I forgot to mention I only have a cheap entry-level endurance bike (Giant Contend 2) as my road bike, but I don't know if that changes the story. So far there are more people recommending the GP5Ks.
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
If you want budget budget tires, I have Kenda Kwests on my commuter bike in 25c. They aren't as supple as the GP4ks that I have on my road bikes, but at $20ea, you wouldn't expect them to be. They've been great for flat resistance, so ideal for a round-town bike.
Likes For Leinster:
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 458 Times
https://www.bicyclerollingresistance.com/specials/best-road-bike-tires
I think the Ultra Sport III sound like they meet your needs. Bicycle Rolling Resistance lists them as the recommended affordable tire. As well, 32's will likely be a better choice for rough roads. Less chance of damaging a rim.
Also, 32's generally have lower rolling resistance than a 28 at equal pressure, and similar resistance at a similar comfort level.
Good luck!
Good luck!
Liked 9,456 Times
Are you checking online prices?
GP5000 imo is worth 2 Ultra Sport tires, more actually. I have tried the US $20 crap tires and they do not work for me. Lousy flat protection. For $42 online, I easily pay more for a much better quality tire.
What's better? 2 lousy tires or 1 good tire? With a good quality tire, you'll spend more time riding than fixing flats.
Also, I don't know if it's just me but feels weird to put a racing tire on an endurance bike with only Claris on it?
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
Ive had Michelin Lithion 2s that I thought were good for the price
Quoted: 2432 Post(s)
Liked 641 Times
I always buy pretty expensive tires. Bought a new bike a little over a year ago and it came with Conti Ultrasport's that you can buy for less than $30. They were so good I just kept them on until they wore out. They rode fine and I didn't get one puncture. If I was smart I would just buy those, but I'm not
Likes For Lazyass:
