Mirror mirror
Bikes: 1983 Fuji Touring Series IV, Masi Volumetrica 3VC
Mirror mirror
Hi all:
I've been trying to use a helmet mirror (I don't remember the brand or model) for commuting for about the last year. I've come to the conclusion that it basically doesn't work. If I adjust the position inboard enough to easily see, my rear view is blocked by my shoulder when in the drops or on the hoods. If I wear a backpack, it is utterly useless. If I adjust the mirror outboard to provide a clear view, I can't really look directly at it without really straining my eyes, so I end up not using it. When I finally do get it into the sweet spot, I invariably bump it when donning, doffing, or carrying my helmet, necessitating another aggrivating round of adjusting.
So, what works? In my searches I've found some bar-end mirrors, but my bike has bar-end shifters. I also use grab-ons, and would rather not cut that to fit around a clamp. But, I realize I may have to compromise on that, or switch to bar tape. Also, how practical are bar-mounted mirrors as far as steering to aim the mirror? Is there some other option, like arm or hand mount?
Thanks in advance,
John.
Thanks in advance,
John.
https://www.mirrycle.com/
I use an STI-mounted Mirrycle, they also have models that mount to traditional brakes (brake line coming out of the top). Depends on your setup.
It's great. The initial adjustment is a bit finnicky, and the view can be partly blocked when I'm wearing a bulkier coat, but it's enough to provide the situational awareness that makes riding in the city much easier. My head will sometimes bob slightly to get the right angle, but I've never felt the need to steer to aim what I'm looking at.
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
I use a helmet mount but I ride upright (hybrid bike). For me a bar mounted mirror is useless because I'm so far from it, but when you're in the drops you'd be closer to a bar mirror. It's possible a bar mounted mirror is right for you, or perhaps both; the bar mount when you're in the drops, a head mounted mirror when you're not.
Work: the 8 hours that separates bike rides.
Intrepid Bicycle Commuter
Bikes: 1976 Motobecane Grand Jubile, Austro Daimler 'Ultima', 2012 Salsa Vaya, 2009 Trek 4300, Fyxation Eastside, State Matte Black 6, '97 Trek 930 SHX, '93 Specialized Rockhopper, 1990 Trek 950
Quoted: 76 Post(s)
Liked 94 Times
I feel your pain. I'd been using bar end shifters and a helmet mounted mirror until recently. I hated the helmet mirror. I tried a ton of different models, and none of them were very good. Horribly geek looking too.
I recently switched over to a Retroshift setup, thus moving my bar end shifters to the brake hoods. Awesome setup. Much better than traditional bar end mounting, if you spend most of your time on the hoods.
So I'm now able to start playing with drop bar end mirrors. I don't hate the Sprintech so far. It does get knocked out of position, but positioning is much more forgiving than my old helmet mirrors. The mirror practically disappears on the bike also.
Conservative Hippie
Count me as another who gave up helmets mounted mirrors. I use a Blackburn Road Mirror on my road bike:
Mounts on the brake hood.
https://www.performancebike.com/bikes...38_-1___400246
Conquer Cancer rider
Bikes: Fun bike, city bike, Bike Friday, Brompton (also fun bikes)
Quoted: 18 Post(s)
I tried that Blackburn, but found it added too much bulk to the bars and I couldn't reach the brakes properly. Still looking for a solution that works.
Zero gallons to the mile
Forgot to mention, I'm still using my 80's vintage brake levers, so no STI-specific parts are likely to work. Retroshift + Sprintech looks like a good solution, but I really like my bar ends, and that's another $130 I'd rather not spend. It's not clear from the website how the Blackburn mirror is attached. Is it just held on with Velcro? Thanks for the ideas, guys. Keep 'em coming.
I've tried many of the mirrors sold over the past 20 years.
Bar mirrors always seem to get in the way, and they don't transfer easily from one bike to another. Also, they usually provide an inferior rear view to helmet mirrors. I wish there was one that worked well.
I've used a Cycleaware Reflex helmet mirror for about eight years now. It's not perfect but it's the best I've found. I got my last one from Amazon for about $13.
https://www.amazon.com/Cycleaware-Ref...leaware+reflex
Bikes: Fuji touring, old Fuji mountain bike, Currie Peak
I'm a huge fan of the efficient velo tools helmet mirror.
https://www.amazon.com/Safe-Zone-Bicy.../dp/B003LVHZ4O
It's significantly larger than most helmet mirrors, so its field of view is good. The big advantage of helmet mirrors is that with a small sweep of my head I can see everything behind me.
One advantage that bar end mirrors has is that they are much more durable than a helmet mirror, plus I just need to know basic info on what's going on behind me, and not in being able to read the U.S. Constitution at a 100 yards.
Thanks, I had not seen the EVT mirror before, may try this next go round (when current one gets scratched up enough).
I'd actually considered making my own mirror before, shaped like the Reflex (vertical oval), but larger, using a cheap Walmart-sourced plastic mirror. Never got around to it.
This might make me reconsider a helmet mirror. I've wondered if I might improve my situation by using a larger mirror farther away from my eyes. This lets me swivel my head slightly to get it farther out and around my bulk, but with similar field of view. If you look closely at the photos of the VT mirror on the Amazon site, the flexible arm is made of coolant delivery hose made by Loc-Line. If I need to lengthen the arm I can buy additional segments for $6/ft.
Is the VT mirror convex or flat?
Quoted: 32 Post(s)
Take a Look Mirror installed on the glasses. I tried the helmet too and for me I had the same issue as you but installed on my glasses, it was perfect.
Quoted: 32 Post(s)
Quoted: 76 Post(s)
Liked 94 Times
On the Retroshift, they look like they are meant for downtube shifters, rather than bar ends. Correct? I do have the original downtube shifters that came with my Fuji.
On the Sprintech mirror, it looks like one would bang their knee on it when dismounting. Is this a problem?
Quoted: 76 Post(s)
Liked 94 Times
https://retroshift.com/support/
No more than bar end shifters. You just don't really notice as much.
I agree with this... the Take a Look Mirror claims that it can be attached to the helmet visor but that doesn't work. It's designed for glasses and VERY effective installed on glasses. It's easy to install if you need to switch glasses (takes maybe 10-20 seconds tops to put them on the glasses and adjust them). I've never tried a handlebar mirror but the fact that you can simply pivot your head slightly with the TAL glasses mirror to scan what's behind you makes it difficult for me to believe there's a handlebar mirror that can trump them.
Bikes: Fred cycles
Quoted: 34 Post(s)
Liked 18 Times
I like the Zefal Spy mirror. Wraps around the lower end of the drop. Small and highly convex, good enough for seeing large objects that are coming up fairly close behind.
Nashbar shows a non-stock item but at least there's a good photo here. Lots of photos on Google but Nashbar was the best for having the recognizable site plus a good photo.
https://www.nashbar.com/bikes/Product...&top_category=
Fat Guy on a Little Bike
Bikes: Two wheeled ones
Quoted: 1254 Post(s)
Liked 345 Times
I know others love them, but I just don't care for mirrors. I don't find them helpful...knowing there's a guy behind me isn't likely to stop him from hitting me. Am I supposed to pull over at the first sign of a car? I ride mostly in the city, there's ALWAYS a car behind me. It's a distraction and useless weight IMO.
One thing I did was cut a small piece from a rubber band and placed that in the socket then installed the mirror to make a tighter fit.
Bikes: Old steel GT's, for touring and commuting
Quoted: 39 Post(s)
I love my EVT Safe Zone helmet mirror. Rarely gets knocked out of position, nice BIG mirror, and the mount has enough flexibility for me to be able to position it to see over my shoulder. I do ride fairly upright though. They're a little pricey (circa $40) but really look built to last. I use mine nearly every day, and after more than six months it shows no signs of wear. Can't recommend it highly enough, totally worth the money. I'll never ride without a mirror again. Bar end mirror was too far away etc, and I was leery of smaller helmet mounted mirrors. The stem on the Safe Zone is pretty long too, which I think helps get it into the ideal position.
