Mirrors, Mirrors, Mirrors
Bikes: Brompton and Dahon Curve D3
Quoted: 23 Post(s)
One of the things I have had the most difficulty with is finding the right mirror for my bike. I have been using a mirror lately that attaches onto your grip with a Velcro strap. The mirror itself can be adjusted to any angle or position. But the problem with it and most mirrors in general is that they are convex. Its great if you want a wide field of view, but its terrible for viewing anything that's coming from behind because by the time you see a car, for example, its right on top of you. What you see is a tiny image which appears to be a long way back and then a second or two later its practically right on top of you. I have searched and searched, but I just can't find a similar type of mirror that isn't convex. I have tried helmet mirrors and I don't like them at all, or for that matter the type that sticks on your glasses. Is there any mirror out there that doesn't have a convex lens?
Thanks for your help guys.
Cheers
Wayne
Cheers
Wayne
Which glass mounted mirrors did you try? I had success with this one but not with few others
https://amzn.com/B000BDJP66
The trick is to set them such that a slight turn left of your head will give you a good view.
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
Which glass mounted mirrors did you try? I had success with this one but not with few others https://amzn.com/B000BDJP66 The trick is to set them such that a slight turn left of your head will give you a good view.
I use this one. It is not convex. I use different helmets. This works good for me.
https://www.messengermirror.com/
Fred "The Real Fred"
master of bottom licks
Quoted: 111 Post(s)
I use Cateye bar end mirrors. They're not flat but they're also not as convex as most seem to be.
Bikes: Brompton H6L-X, Dahon Curve D3
Quoted: 56 Post(s)
-HANK RYAN-
Norman, Oklahoma USA
Quoted: 23 Post(s)
Cheers
Wayne
Quoted: 111 Post(s)
Quoted: 23 Post(s)
I like you set up. The Bike Friday is a great looking machine. I like the idea of putting those bar extenders on, but I don't know if they will work on mine as the bars are more the traditional style and not straight like yours. I see where you have mounted the Contour cam. Perfect location. One of these days I might get one of those myself, but my wallet has to gain quite a bit more weight first. I'm heading out soon to check on those mirrors and I'll also check out if I can put those bar extenders on as well.
Cheers
Wayne
Quoted: 321 Post(s)
Liked 7 Times
Blackburn helmet mirror. I have tried a few down the years and this one is a keeper. It takes a bit getting used to but once you have, it is second nature to scan the road behind you.
Quoted: 23 Post(s)
Picked up two Schwinn Deluxe Mirrors today. It fits over the grip with a Velcro strap like my other model, but with this one the mirror itself is flat and not convex. Now I will be able to see oncoming traffic properly. Check it out here:
https://www.ebay.com/itm/Schwinn-Delu...item4d0fc46443
Cheers
Wayne
Quoted: 14 Post(s)
I am a big fan of the Bike Peddler Take-A-Look Eyeglass mirror. It gives a clear wide view, doesn't vibrate and works well whether I am riding in the drops or on top of the bars. It is very easy to quickly check behind me and it disappears when I don't need it - I don't even notice it is there. It is compact, lightweight and I can use it with any of my bikes. I have tried other types of mirrors over the years (handlebar mounted, helmet mounted) but prefer this one by far.
I have no idea if these are safe nor where to buy them. Interesting solutions though:
Glove mirror and wristband mirror
https://www.cgo.com.tw/~web_test/?ap=...712&mode=watch
https://www.cgo.com.tw/~web_test/?ap=...711&mode=watch
Quoted: 23 Post(s)
Cheers
Wayne
Quoted: 23 Post(s)
I keep coming back to look at your Bike Friday. Sweet looking bike. I just wish they didn't cost an arm and two legs -- well for me right now they do.
Bikes: Trek Elite 9.8
Tried that one and it never would stay adjusted. I have tried most of the mirrors out there. None is Perfect.
Quoted: 2497 Post(s)
Liked 740 Times
H
Quoted: 14 Post(s)
I like the judgmental tone Leisesturm - passion is good.
But I must say my flat 1 square inch mirror attached to my sunglasses works incredibly well.
Bikes: Dahon Mu uno, Dahon P18 Visc
I use a Zefal Cyclop mirror on my Dahon P18 Visc it folds down nicely and does not get in the way when the bike is folded up.
Quoted: 23 Post(s)
Cheers
Wayne
That's looks like a nice mirror and still enable you to use a bar end. I have been shopping for bar ends and a mirror that would fit on the end of it. When attaching the mirror to the end of the handlebar grip, can the mirror frame (not the mirror itself) be turned so that its pointing down? If so, that might just be the one I would like to use. Also, I'm sure its a convex mirror, but I'm hoping the curve is not too pronounced. I have a mirror that I'm not using anymore because the convex curve was so drastic that you didn't see a car, as an example, in the mirror until it was right on top of you.
Cheers
Wayne
Cheers
Wayne
I don't find the mirror to convex. I should point out that I have poor vision on my right hand side and this is the best mirror I've found to help me in traffic.
This mirror can be used on the left & right hand side I hope this picture helps.
Quoted: 23 Post(s)
Cheers
Wayne
Quoted: 317 Post(s)
Just to share this info on a mirror said to be suited for Brompton: https://www.foldingbikeguide.co.uk/br...ar-view-mirror
