Brightest clip-on tail light?
Old 11-15-22, 03:12 PM
icemilkcoffee
icemilkcoffee's Avatar
Quoted: 1562 Post(s)
Liked 1,734 Times in 974 Posts
I am looking for the brightest clip-on light out there. On my Nishiki Linear, I don't have enough seatpost to mount the usual seatpost mounted lights. I can only clip on a tail light on my saddle bag:
Right now I have a Specialized Stix on there, but I need something bigger and brighter than that.
icemilkcoffee is offline
Old 11-15-22, 04:20 PM
Milton Keynes
Milton Keynes's Avatar
Quoted: 2281 Post(s)
Liked 1,710 Times in 936 Posts
I don't know if this is the brightest, but this is the one I just bought: https://www.amazon.com/dp/B01HEF6R9Q...roduct_details. It's pretty bright, very hard to look directly at the light when it's on full brightness. It should be seen for some distance.
I didn't really have room on my seat post either, but the rubber mounting clip allows mounting on the seat stay, which is where I put it.
Milton Keynes is offline
Likes For Milton Keynes:
Old 11-15-22, 04:37 PM
wolfchild
Quoted: 4227 Post(s)
Liked 2,488 Times in 1,286 Posts
Planet Bike Superflash is pretty bright and it can be mounted on a chainstay or seatpost.
wolfchild is offline
Likes For wolfchild:
Old 11-15-22, 05:45 PM
Quoted: 18420 Post(s)
Liked 15,564 Times in 7,333 Posts
You want to be seen riding that thing?
Seriously…Will a clamp not fit around the downtube? If not, there are lights that can me attached to stays, as noted above.
P.S. There is a lighting forum here.
Likes For indyfabz:
Old 11-15-22, 06:02 PM
jon c.
Quoted: 1591 Post(s)
Liked 1,020 Times in 572 Posts
I don't know if it's the brightest, but the Cygolite 350 is very bright and clips onto a saddlebag
jon c. is offline
Likes For jon c.:
Old 11-15-22, 07:05 PM
icemilkcoffee
A-ha! Good find!
Likes For icemilkcoffee:
Old 11-15-22, 07:13 PM
thin_concrete
Achtung!
thin_concrete's Avatar
Bikes: 60.1, Marvel
Quoted: 515 Post(s)
Liked 268 Times in 161 Posts
Yeah - I use the Cygolite 350 and it’s great. Very happy with how long it holds its charge and its brightness.
thin_concrete is offline
Likes For thin_concrete:
Old 11-15-22, 07:40 PM
Camilo
Quoted: 1109 Post(s)
Liked 1,200 Times in 760 Posts
This one is probably as bright as they come. It was the brightest I saw when I looked last summer. It's easy to compare lumens, so find one that you like.
Cygolite Hypershot 350 Bike Taillight | REI Co-op
Camilo is offline
Old 11-15-22, 08:45 PM
veganbikes
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,994 Times in 2,665 Posts
Dinotte makes a light that is only for daytime use it is so bright they make you check a box making sure you understand it is for daytime use only, this is not that light but I have heard is quite bright and has a lot of mounting options: https://store.dinottelighting.com/ne...tery-p111.aspx
My go to would be the Big Cobber from Knog but I don't know it would work in your mounting situation though probably would easily mount to the seat tube as you have space but you would have to give it a go. It is a very bright one as well.
veganbikes is offline
Likes For veganbikes:
Old 11-15-22, 08:54 PM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
I agree with veganbikes: get a taillight that's rated for daytime use. The Bontrager Flare comes to mind.
As for the attachment, I'd probably just strap it to the frame; I've never had a clip-on that didn't fall off the saddlebag, and you've got plenty of room and ample visibility.
Rolla is offline
Likes For Rolla:
Old 11-15-22, 09:23 PM
veganbikes
Clark W. Griswold
If you are riding during the day and using the light only during the day then yes. I was simply stating that they make one brighter so bright in fact it is not for night time usage. I am not saying one should use something that bright at night. If they have to give you a warning there is a good reason. No need to blind people here we want them to see us not cause damage because if they can't see well that is rather dangerous for everyone.
Old 11-15-22, 09:57 PM
Troul
Troul's Avatar
Liked 2,979 Times in 1,920 Posts
I like to wake up the neighbors with a hyperflash red taillight. They love it!
-Oh Hey!
Troul is offline
Likes For Troul:
Old 11-15-22, 10:00 PM
Koyote
Quoted: 6972 Post(s)
Liked 10,968 Times in 4,692 Posts
That one has low battery life.
OP, just use a seatpost mount and attach a light to the seat tube, right above the seat stays and below the top tube. It’ll work fine.
Koyote is offline
Likes For Koyote:
Old 11-16-22, 01:24 AM
redshift1
Quoted: 70 Post(s)
Liked 55 Times in 36 Posts
Light and Motion also do some bright ones ( at least the ones I bought ten years ago (still) are. )
I think mine's the Viz 180 Pro or similar. Looks the same.
https://lightandmotion.com/collections/bike
redshift1 is offline
Old 11-16-22, 08:00 AM
BobbyG
BobbyG's Avatar
Quoted: 1364 Post(s)
Liked 1,678 Times in 827 Posts
IMHO you will be more visible in traffic with any light if it is mounted up high on the back of your helmet. Then it can be sen better above car hoods.
BobbyG is offline
Likes For BobbyG:
Old 11-16-22, 09:53 AM
urbanknight
Over the hill
urbanknight's Avatar
Quoted: 998 Post(s)
Liked 1,206 Times in 692 Posts
I think Indyfabz means the seat tube (as indicated by Rolla), and I can at least verify that a number of brands have clamped just fine to the seat tube on my bikes, and other brands even have optional mounts for the stays.
It's like riding a bicycle
urbanknight is offline
Old 11-16-22, 10:55 AM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 1173 Post(s)
Liked 927 Times in 612 Posts
Is "brightest" actually the best choice ?
Homebrew01 is offline
Likes For Homebrew01:
Old 11-16-22, 11:04 AM
icemilkcoffee
Yes that is what a logical person would do. But this frame is in really great shape and this bike in general has been the bike I fiddle with more than any of my other bikes, so it feels wrong for me to strap anything to the frame. Yes. Illogical I know.
I used to wear a helmet like that. Until one time my wife followed me and told me that the light did nothing most of the time because when I am leaning forward the light is pointing up in the sky.
I would go as far as to say that no bike light is bright enough in broad daylight. Actually there are two problems- too dim and too small. The latter is probably the bigger issue.
Old 11-16-22, 11:53 AM
Yes. Brain fart. Thank you.
Old 11-16-22, 12:22 PM
Speedskater
Speedskater's Avatar
Bikes: Bob Jackson, Trek & Sampson
Quoted: 56 Post(s)
Liked 24 Times in 14 Posts
A tail light on a saddlebag needs a wide-angle lens mostly in the vertical direction. It's hard to maintain position on a saddlebag.
A helmet light presents a much larger positioning challenge.
Speedskater is offline
Likes For Speedskater:
Old 11-16-22, 12:42 PM
Milton Keynes
Or best yet, do what I do... have a taillight on the back of the bike and a light on the back of your helmet.
Old 11-16-22, 12:47 PM
BobbyG
BobbyG's Avatar
That's what I do.
BobbyG is offline
Likes For BobbyG:
Old 11-16-22, 02:05 PM
urbanknight
Over the hill
Quoted: 998 Post(s)
Actually that's fair. I definitely got minor scuffs on my seat tube, and I can understand a collector not wanting that on their vintage baby.
Old 11-16-22, 02:37 PM
veganbikes
Clark W. Griswold
Except not so much and your head is moving the bike is going in the direction it is going. I want drivers behind me to see where my bike is going not where my head is going. Having a secondary light on the helmet is fine but a light that can be super high and sometimes not be facing traffic is not as ideal.
Old 11-16-22, 02:54 PM
urbanknight
Over the hill
Quoted: 998 Post(s)
Exactly how far does your head stray from your bike while riding?
